Page 1 of 3 1 2 3
Did I just break a sprag? Update 2 #2668828
06/22/19 09:07 PM
06/22/19 09:07 PM
W. Pa
U
usp4u Offline OP
usp4u  Offline OP
U
W. Pa
Never broken one before.....full weight e body with drag radials, 402 small block, 727, turbo action fmvb, 3.91
Pulled out on street, poked it...car went sideways, I lifted, and poked it again.
ZIIIIIZZZZZZZZZZ
car moves under own power but any throttle produces more ZIIIIIIZZZZZZZZ.
not what I needed on a car I planned to drive to Carlisle in two weeks
down
Pulled trans, everything looks fine........then I had an epiphany.....loose converter, Mancini low gear pack, sticky tires, old OEM gear set..
I'll bet I stripped the ring n pinion. That would explain motion in all gears, but ziiiiiiiiizzzzz upon throttle. I heard it under the shifter, but that could be gear noise resonating up the driveshaft.
I had a meeting tonight and couldn't work on it...tomorrow night I'll pull the diff, and ill bet it is hurt.
Pulled axles and diff...
1/4 inch of splines were ripped off the right side axle
Re: Did I just break a sprag? [Re: usp4u] #2668833
06/22/19 09:15 PM
06/22/19 09:15 PM
Boise
Moparteacher Online content
Moparteacher  Online Content
Boise
Put it in manual low. If it goes then ya busted sprag.
Re: Did I just break a sprag? [Re: Moparteacher] #2668856
06/22/19 10:37 PM
06/22/19 10:37 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
They all go in manual low ?
Re: Did I just break a sprag? [Re: CSK] #2668858
06/22/19 10:40 PM
06/22/19 10:40 PM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
time for a powerglide
Re: Did I just break a sprag? [Re: dart games] #2668867
06/22/19 11:07 PM
06/22/19 11:07 PM
W. Pa
U
usp4u Offline OP
usp4u  Offline OP
U
W. Pa
That would be a gross way to live. No thanks.
Really just hoping anyone could tell me if this sounds like a sprag or not.
Re: Did I just break a sprag? [Re: usp4u] #2668875
06/22/19 11:22 PM
06/22/19 11:22 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
You said fmvb...., full manual valve body ? .... no go in first gear but it will move in second ? Probably a busted sprag BUT NOT the end of the world .... replace the sprag -
Re: Did I just break a sprag? [Re: usp4u] #2668876
06/22/19 11:23 PM
06/22/19 11:23 PM
ZIIIIIZZZZZZZZZZ
down
My advice is when in doubt, check it out wrench Don't find out later after it explodes that you hurt it enough to hurt you work wrench
Re: Did I just break a sprag? [Re: usp4u] #2668881
06/22/19 11:29 PM
06/22/19 11:29 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I just fixed one that had a partially failed roller clutch after breaking a rear. He was also starting his burnouts in low. Car drove OK with no noise. Had a TCI transbrake valvebody (LBA I assume). Guy brought it to me after I suggested it should be checked, even though the car drove fine. Half of the springs were crushed and the fingers were folded over. Would not have survived another hard hit.
Stock drum 727? I would treat it like a grenade with the pin out until it was looked at. Gasket kit and time are cheap.
Re: Did I just break a sprag? [Re: CMcAllister] #2668885
06/22/19 11:35 PM
06/22/19 11:35 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Two guys above have valid observations...,,,
Drop the pan ... there should be spring trash in there too
Re: Did I just break a sprag? [Re: dOc !] #2668895
06/23/19 12:17 AM
06/23/19 12:17 AM
W. Pa
U
usp4u Offline OP
usp4u  Offline OP
U
W. Pa
just dropped the pan. zero trash.
the car will move in all gears........until you touch the throttle. then ZZZIIIIIIIIIIZZZZ from under the tunnel.
I did find two bolts convertor that were backing off. but that cant be it
and yes, "fmvb" = turbo-action forward manual valve body (forward to allow my slap-stik to work, no LBA) been in for about 10 years and 8k miles.
Re: Did I just break a sprag? [Re: usp4u] #2668897
06/23/19 12:26 AM
06/23/19 12:26 AM
W. Pa
U
usp4u Offline OP
usp4u  Offline OP
U
W. Pa
slip yoke splines are perfect. as are trans output splines.
car was perfect for 87 miles today, then I nailed it, spun, lifted, and tipped back in......why I was thinking sprag.
All in low gear and nitto 555r tires.
Re: Did I just break a sprag? [Re: CSK] #2668910
06/23/19 01:59 AM
06/23/19 01:59 AM
Boise
Boise
Missed the part about RMVB. Woopise.
Re: Did I just break a sprag? [Re: Moparteacher] #2668916
06/23/19 02:56 AM
06/23/19 02:56 AM
W. Pa
U
usp4u Offline OP
usp4u  Offline OP
U
W. Pa
It's not rmvb......it is fmvb.
Re: Did I just break a sprag? [Re: usp4u] #2668932
06/23/19 06:44 AM
06/23/19 06:44 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My bet is hard part failure. The sprag won't disable 2nd, 3rd, or rev. Stripped input shaft hub or broken planetary.
Doug
Re: Did I just break a sprag? [Re: dvw] #2668976
06/23/19 10:08 AM
06/23/19 10:08 AM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Doug
I agree... Or cracked a drum...
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: Did I just break a sprag? [Re: racerhog] #2668986
06/23/19 10:43 AM
06/23/19 10:43 AM
moparx Offline
moparx  Offline
methinks you need to get that thing out and on the bench now. you still have lots of time before carlisle to go through it.
don't put it off and give it a chance to BITE you ! tsk it will not treat you with a "love tap" if it gets it's chance.
beer
Re: Did I just break a sprag? [Re: usp4u] #2669006
06/23/19 11:49 AM
06/23/19 11:49 AM
MR_P_BODY Offline
MR_P_BODY  Offline
How many rpms were you running at the time you hit it... MOST times
when a sprag gives out is when you get off the pedal then hit it again..
I blew a rear end in the race car but it didnt hurt the sprag.. I pulled the
trans for a check but it was fine.. the getting back on it after letting off
is what can hurt it... its that slap of the rollers that can break the roller
case.. in a manual VB its hard to tell if you cracked it.. pull it now while
you have the time... good luck
wave
Re: Did I just break a sprag? [Re: usp4u] #2669024
06/23/19 01:05 PM
06/23/19 01:05 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Does that include Reverse or just the forward gears? In any case, it needs to come out, no easy external fix.
Re: Did I just break a sprag? [Re: John_Kunkel] #2669032
06/23/19 02:13 PM
06/23/19 02:13 PM
W. Pa
U
usp4u Offline OP
usp4u  Offline OP
U
W. Pa
All gears including reverse
Re: Did I just break a sprag? [Re: usp4u] #2669034
06/23/19 02:17 PM
06/23/19 02:17 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Short answer: Remove transmission and have it checked out. twocents
72 Plymouth Roadrunner 11.08@123.25
Page 1 of 3 1 2 3
