Re: Cam for 505 stroker
[Re: General 68]
#2921572
05/12/21 11:09 AM
05/12/21 11:09 AM
Posts: 27,467 So Cal
autoxcuda
So Cal
Yes. I have one now. For previous poster: European 98 octane. Should be the same as premium in the US. Wonder how they converts? I thought there was better high octane gas in Europe than US ?
[Re: autoxcuda]
#2921595
05/12/21 11:51 AM
05/12/21 11:51 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
Yes. I have one now. For previous poster: European 98 octane. Should be the same as premium in the US. Wonder how they converts? I thought there was better high octane gas in Europe than US ? In Europe they use the RON rating. In the US we use the average of the RON and MON ratings. 98 octane in Europe is roughly equivalent to 93 rating here.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: General 68]
#2921680
05/12/21 01:57 PM
05/12/21 01:57 PM
Posts: 3,021 NY
B1duster
NY
Yes. I have one now. For previous poster: European 98 octane. Should be the same as premium in the US. So no problem with detonation using that Hughes 232/236-110 ?
[Re: 3hundred]
#2921821
05/12/21 07:14 PM
05/12/21 07:14 PM
autoxcuda
So Cal
Yes. I have one now. For previous poster: European 98 octane. Should be the same as premium in the US. Wonder how they converts? I thought there was better high octane gas in Europe than US ? In Europe they use the RON rating. In the US we use the average of the RON and MON ratings. 98 octane in Europe is roughly equivalent to 93 rating here. I think there is one gas station within a 10 miles radius of me that has 93 octane. Everything else is 91 octane California blend tops. 93 would definitely help.
[Re: General 68]
#2922247
05/13/21 09:26 PM
05/13/21 09:26 PM
Posts: 1,899 MYRTLE BEACH SOUTH CAROLINA
ek3
Looking for a street friendly hydraulic flat tappet Cam for a 440/512 stroker. CR 9,8:1, Stage 4 iron heads, 1,6 rockers, Indy dual plane intake, 2" headers, 3" x-pipe. Manual trans Want lots of low end torque and vacuumn for power brakes. Heavy car, 4200lb, mostly street driven. Any experience with Hughes Engines cams? Looking at the SEH2832BL-10 or SEH3236BL-10 or Are they too much? i used the seh3236bl3-14 [ 114 lobe sep- ] installed @ 110 C/L iron 915's stock---- 10-25-1 compression . stock 6 pack w factory dist . manifolds ... hp was 522 peak @ 5500rpm torque was 586lbs@5200rpm... it was lean by a good bit too..... the 114 l/s makes it idol near stock @ 900 rpm.. very smooth barely notice a lope ... torque is over 500 @3500rpm....................
