Gen 2 / 426 hemi exhaust rocker ratio check info
#2667860
06/20/19 08:27 AM
06/20/19 08:27 AM
Posts: 17,915 S.E. Michigan
ZIPPY
S.E. Michigan
In the past I collected a few sets of Mopar Performance P4529706AB stock replacement exhaust rockers. My 572 mockups had all been done with the same pair which both measured at 1.5225 ratio. .609 lift on a .400 lobe without any deflection (light checking spring). After reading the horror stories here regarding ratios being all over the place I was interested to check some more and see what I could find. I'm partially through the second set (have tested 10 so far). The worst ones are 1.52. The best ones are 1.5225. In every instance where I thought I had identified something a 1.51 or less, I found an error with either lash adjustment, indicator setup or both. And in every case when those errors were corrected, the rocker ratios measured at least 1.52. Note I have no current affiliation with MP, only several years of past work history. If these parts were junk, I'd say so. They're actually quite good....or at least, these particular ones that I have are rather decent. ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif) I might go and check some more of them just because, but I see how this is probably going to go, and may spend my spare time doing something more productive I will check a few once I get it set up with the springs I am going to use and so on, and try to get an idea of deflection and so on.
Rich H.
Esse Quam Videri
Re: Gen 2 / 426 hemi exhaust rocker ratio check info
[Re: ZIPPY]
#2667899
06/20/19 10:19 AM
06/20/19 10:19 AM
Posts: 15,976 Chilliwack B.C. Canada
RUNCHARGER
I'm the luckiest guy around too I think. I've read the horror stories and have been checking the stock style Hemi rockers in my engines for over 20 years and always found them to be pretty darn close as well.
Sheldon
[Re: RUNCHARGER]
#2667903
06/20/19 10:38 AM
06/20/19 10:38 AM
ZIPPY
S.E. Michigan
I'll also say this is with an import indicator and only .001 resolution, which prevents me from seeing much of anything in between 1.52 and 1.5225 because with this combination there is only .001" difference in valve lift between the two.
I do have other (USA) indicators with higher resolution, but they all have shorter travel than my gross lift so they wouldn't be useful here.
Rich H.
Esse Quam Videri
[Re: BradH]
#2667949
06/20/19 12:08 PM
06/20/19 12:08 PM
ZIPPY
S.E. Michigan
Im looking forward to the detective work as well.
Though I imagine I should be able to observe some sort of a loss from angled pushrods, how it shakes out is Another thing.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2667963
06/20/19 12:39 PM
06/20/19 12:39 PM
Posts: 4,457 Washington
madscientist
Washington
I'm with Brad. When you load them with springs they will lose some ratio. I've checked Hemi rockers. All were under 1.5 but they were very consistent. I have checked many MP W2 rockers and all of them were 1.5 or a skosh higher with spring load. IIRC, they were 1.58 with checker springs. The Norris stainless rockers for W2 heads I had would measure 1.66 with soft springs and 1.60 with spring load.
[Re: quickd100]
#2668238
06/21/19 07:37 AM
06/21/19 07:37 AM
ZIPPY
S.E. Michigan
I kept going and finally found some that are different. Found a few 1.53s and one 1.5475.
So I'm beginning to see sometimes the target is missed....Im probably lucky these aren't horribly bad, And the error is mostly in my favor.
Although tedious, there's no other way to know.....
Maybe I'll keep going and cherry pick the highest ratio of the bunch.
If the Indy rockers had more clearance to the tube in the head (Victor), this wouldn't be needed....
Rich H.
Esse Quam Videri
[Re: Cab_Burge]
#2668669
06/22/19 11:06 AM
06/22/19 11:06 AM
ZIPPY
S.E. Michigan
I rounded up another set of MP, a set of stock used wide pads, and a set of Indy. There might be another set of MP coming my way in the future but this seems like enough testing for now. I feel I know what I'm talking about with these parts I've checked.
The very worst one is a 1.49 wide pad, the very best one is a 1.56 MP.
There are enough in-between to make closely matched sets, which is the goal (beyond knowing what's what).
The Indy's are consistent at a little over their advertised ratio, but don't fit the Victor heads Very well. I decided I'm going to run Indy roller intake and MP exhaust on this 572.
Rich H.
Esse Quam Videri
[Re: DoubleD]
#2669264
06/24/19 08:55 AM
06/24/19 08:55 AM
ZIPPY
S.E. Michigan
Nice stuff, but I will probably never go that way unless there's a very substantial discount involved.
Chuck did give me the opportunity to have a close-up look at those + a really good quote, but the rest of the vehicle needs attention more.
Rich H.
Esse Quam Videri
[Re: DoubleD]
#2669389
06/24/19 02:19 PM
06/24/19 02:19 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
When you are ready to put the big boy pants on....... I've seen the good Big Boy heads, they ain't from Eddy ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) Take a look at the BAE # 8 heads with the really good rocker arm girdle and rocker arms ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) I wish that I could afford to use them, but I can't ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif) The Eddy Victors are way better than stock stuff though ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: DoubleD]
#2669485
06/24/19 06:30 PM
06/24/19 06:30 PM
Cab_Burge
Aren't all the Goodwin hemi motors made on their own blocks with a different bore spacing than the stock Mopar 426 blocks? As far as a all out race motor, N/A or power adder, I think you need to have a billet block these days to make them live at the power levels guys are making now ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) I don't like aluminum blocks for N/A, let alone billet blocks ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) But sometimes you need to use what works the best if you want to compete heads up against the rest of the racers ![work work](/ubbthreads/images/graemlins/custom/work.gif)
[Re: 73DAD]
#2669688
06/25/19 08:51 AM
06/25/19 08:51 AM
ZIPPY
S.E. Michigan
Thanks for taking the time to measure these & post the results for us. I'm really glad somebody appreciates it, thanks for saying so. I consider myself very fortunate to have been given a guided tour of T&D products already, by the professional who made all the decisions on Double's engine. High level knowledge and the time taken to show me a thing or two will be remembered for a long, long time. Other stuff is easily dismissed
Rich H.
Esse Quam Videri
[Re: A727Tflite]
#2670083
06/26/19 08:46 AM
06/26/19 08:46 AM
ZIPPY
S.E. Michigan
I didn't attempt to perform those sort of measurements with any level of precision, because I feel I lack the expertise to make any changes to that area.
Knowing that others do have the expertise to change or correct that, though, I'd be greatful to learn how that is done (even if I never try it personally).
I did look reasonably close at pushrod-to-tube clearance, since that was the main driver to the whole exercise, and since all were checked on the same two lifter bores/same head arrangement. It seemed to me pushrod clearance (or the lack therof) was fairly consistent in each group or type of rocker, which led me down the path of believing in the possibility the pushrod side could be the better of the two. The thought was, maybe the valve side of the rocker, maybe even the exact curvature of the pad, might the more inconsistent or "difficult to get right" area. (?)
These are just gut feelings that developed right after the "Actually, I can't do anything about that" thought crept in, and I decided not to pursue the exact reasons why each one arrived at a different ratio.
Rich H.
Esse Quam Videri
