Re: ACC Custom Carpets - UPDATE [Re: 68Cbarge] #2668000
06/20/19 01:34 PM
06/20/19 01:34 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Wanna real battle installing carpet. Try Trim Parts brand. You have been warned
Re: ACC Custom Carpets - UPDATE [Re: gtx6970] #2668017
06/20/19 02:27 PM
06/20/19 02:27 PM
Mass
charge70 Offline
charge70  Offline
Mass
I agree with this statement completely.I purchased a Trim Parts carpet for my 4 speed 70 B-body.There was so much extra material on top of the tunnel I had to try to take a slice out of the carpet.Long story short,that POS went into the trash can and I installed a different brand carpet.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: ACC Custom Carpets - UPDATE [Re: charge70] #2668032
06/20/19 03:54 PM
06/20/19 03:54 PM
cbusters Offline
cbusters  Offline
I ordered an ACC with extra material on all sides and had zero issues. Cut the gas pedal into the corner of the heel pad and used bank money bags full of lead in the low corners and let it sit for a couple days. Easiest way to cut it is with a utility knife with hook blades. Cuts from the back very easy. Used 1/2 conduit heated with a propane torch for all the holes.
Re: ACC Custom Carpets - UPDATE [Re: cbusters] #2668072
06/20/19 05:50 PM
06/20/19 05:50 PM
O
oldjonny Online content OP
Don't argue with me.
oldjonny  Online Content OP
O
Like the heated conduit idea!
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
Re: ACC Custom Carpets - UPDATE [Re: oldjonny] #2668145
06/20/19 09:48 PM
06/20/19 09:48 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
I havnt ordered carpet in several years but was looking the other day for my 72 Satellite and saw the mass backing. Can someone please post a pic of it. In the past the carpet came with jute backing on strategic areas with ACC or Trim Parts. Can you still order with jute?
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: ACC Custom Carpets - UPDATE [Re: mopargem] #2668155
06/20/19 10:02 PM
06/20/19 10:02 PM
O
O
You CAN still order with plain back. The Mass Backing is about $40 or $60 more (Can't remember how much). Its a thick rubbery coating that is bonded to the back prior to them putting the insulation on. As I said previously, if the mold was correct to form, I can see how this would be better as it holds its shape for sure. In my case, with the poor quality, I think it was a hindrance.
Re: ACC Custom Carpets - UPDATE [Re: mopargem] #2668160
06/20/19 10:16 PM
06/20/19 10:16 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The mass backing is just a heavy rubber binder, think of it as having a layer of Dynamat applied to the carpet, IMHO I prefer the mass backing, last few carpets that I did for myself and customers rides, I specified mass backing on ACC carpets...
here's 2 ACC carpets showing their undersides for comparison, the top ACC carpet circled in red is just the standard nylon binder and jute backing, the 2nd ACC carpet circled in yellow is mass backed with jute backing
Mike
Re: ACC Custom Carpets - UPDATE [Re: oldjonny] #2668162
06/20/19 10:20 PM
06/20/19 10:20 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Oldjonny, I'm just curious, did you have dynamat or a similar product adhered to the floors prior to your carpet installation?
Mike
Re: ACC Custom Carpets - UPDATE [Re: DAYCLONA] #2668218
06/21/19 04:20 AM
06/21/19 04:20 AM
O
O
Mike
I did not put anything else down prior. Car started out as a 100% original, 1-owner, with nothing changed...but, the carpet was way, way nasty from time. So, the carpet was supposed to just be a re-fresh. Lots more to the story now from when I started this, but the car will be on the road soon and I will post some pictures up.
Re: ACC Custom Carpets - UPDATE [Re: oldjonny] #2669966
06/25/19 09:35 PM
06/25/19 09:35 PM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
Going back to Showtime Restorations (Motorparts South) I do not know who supplies them but there carpets FIT!! I just installed another one in a 74 charger 4-speed car, it fit the tunnel great with approximately 8 inches of excess around the perimeter. Just trying to help, hope all the issues work out for everyone.
Re: ACC Custom Carpets - UPDATE [Re: gtx6970] #2675531
07/08/19 12:54 PM
07/08/19 12:54 PM
Olympia, Washington
tallzag Offline
tallzag  Offline
Olympia, Washington
ACC bought out Trim Parts carpet line so who knows what is what anymore. Lots of consolidation going on in the resto industry right now, Trim Parts bought out First Place auto who had the best whiskers. Trim Parts did sell PUI which was absolute junk so hopefully they are using the First Place stuff instead.
Rocket Restorations
