Re: Lowered my timing by 3 degrees
[Re: AndyF]
#2666523
06/16/19 02:37 PM
06/16/19 02:37 PM
Posts: 4,701 On the parachute mount
n20mstr
It might not want timing to get the car moving, he might be making more power with less timing and overpowering the tires. I'd keep the timing at the lower number and try to get it too hook. t This was my first thought. Mph is the indication of the power your making, et is just the application of that power. You running a slick, it prob spinning . Work on your suspension now
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2666533
06/16/19 02:49 PM
06/16/19 02:49 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
It might not want timing to get the car moving, he might be making more power with less timing and overpowering the tires. I'd keep the timing at the lower number and try to get it too hook. t This was my first thought. Mph is the indication of the power your making, et is just the application of that power. You running a slick, it prob spinning . Work on your suspension now It's dead hooking, no spinning at all. I run a bias slick. So do I leave it at 32* or put at 35* ? Air fuel is dead on at 12.8 at WOT.
[Re: 383man]
#2666549
06/16/19 03:41 PM
06/16/19 03:41 PM
Posts: 43,342 Bend,OR USA
Cab_Burge
And I picked up almost 3 mph but my ET. dropped by 1.5 tenths. ???? I am thinking he meant .015. One and a half thousandths. Ron One and a half hundreds = .015 ![work work](/ubbthreads/images/graemlins/custom/work.gif) , one and half thousands should be written as .0015, not .015 ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) Dang details anyways ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif)
[Re: Cab_Burge]
#2666564
06/16/19 04:07 PM
06/16/19 04:07 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
So do I leave it at 32* or put at 35* ? Are those the only choices?
[Re: Cab_Burge]
#2666566
06/16/19 04:14 PM
06/16/19 04:14 PM
Sammy
Wind Gap,Pa.
And I picked up almost 3 mph but my ET. dropped by 1.5 tenths. ???? I am thinking he meant .015. One and a half thousandths. Ron One and a half hundreds = .015 ![work work](/ubbthreads/images/graemlins/custom/work.gif) , one and half thousands should be written as .0015, not .015 ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) Dang details anyways This is just one outing that I'm showing how my ET goes up with the higher timing but mph drops. This is my new engine going from W8 heads. Both engines showed the same results. The less timing equates to more MPH . The engine dyno made most HP @ 35 degrees. You cant measure MPH on the dyno. 60 foot is a tad weaker with 32 degrees timing.
[Re: Sammy]
#2666588
06/16/19 05:36 PM
06/16/19 05:36 PM
Posts: 4,457 Washington
madscientist
Washington
It might not want timing to get the car moving, he might be making more power with less timing and overpowering the tires. I'd keep the timing at the lower number and try to get it too hook. t This was my first thought. Mph is the indication of the power your making, et is just the application of that power. You running a slick, it prob spinning . Work on your suspension now It's dead hooking, no spinning at all. I run a bias slick. So do I leave it at 32* or put at 35* ? Air fuel is dead on at 12.8 at WOT. As fast said, are those your only choices? I think you need to test some. Run just 60 foot times and set the timing for your best 60's. Then start backing timing out of it and run the 1/4. My best guess is, like most N/A cars with decent chassis, your car will like more timing in low gear and want it backed down in high gear, or maybe pull it out in second. Guys pulling timing and going quicker in 60 feet with N/A combos usually need chassis tuning. This nonsense that less timing is always better is just that. If it wants more timing in low gear, give it more timing. Look at the plugs and let them tell you if you are wrong or not.
[Re: madscientist]
#2666617
06/16/19 06:54 PM
06/16/19 06:54 PM
Posts: 11,769 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
High gear retard is a real thing and is used by those looking to get the last bit of performance. Was being done years ago by class racers, etc. You can do it electronically or put a switch on the shifter and do it with an MSD retard box, depending on your ignition. Or just set the timing where it gives the results you're looking for - go fast, repeat 60s, not run the engine on "kill".
[Re: Sammy]
#2666854
06/17/19 11:51 AM
06/17/19 11:51 AM
Posts: 19,391 Las Vegas
Al_Alguire
Las Vegas
IMO I would ADD some timing in low gear and then begin to pull it back on each gear change. Adding timing at the hit will help burn the fuel that accumulates from being on the two step. Further adding timing will help the engine make more power with the lower load it has in first gear and increase efficiency. If it is a three speed I would pull back a couple degrees in second and in high go back to base or where it makes the best MPH. In the end you will have to experiment to find the ideal place for timing to be. Not unusual for timing to be changed from the dyno for many reasons. Increased altitude, moisture in air or two very common reasons. You need to find a curve that accelerates the car the best. That's generally is more down low then up top.
[Re: fast68plymouth]
#2666915
06/17/19 02:02 PM
06/17/19 02:02 PM
Sammy
Wind Gap,Pa.
So do I leave it at 32* or put at 35* ? Are those the only choices? Fastest ET was at 35* Fastest MPH is at 32*
[Re: Al_Alguire]
#2666916
06/17/19 02:04 PM
06/17/19 02:04 PM
Sammy
Wind Gap,Pa.
IMO I would ADD some timing in low gear and then begin to pull it back on each gear change. Adding timing at the hit will help burn the fuel that accumulates from being on the two step. Further adding timing will help the engine make more power with the lower load it has in first gear and increase efficiency. If it is a three speed I would pull back a couple degrees in second and in high go back to base or where it makes the best MPH. In the end you will have to experiment to find the ideal place for timing to be. Not unusual for timing to be changed from the dyno for many reasons. Increased altitude, moisture in air or two very common reasons. You need to find a curve that accelerates the car the best. That's generally is more down low then up top. Getting my laptop plugged in to my 7531 MSD Box and was wondering if you have ever done this timing curve before? Not sure when to start pulling timing out.
[Re: Sammy]
#2666927
06/17/19 02:36 PM
06/17/19 02:36 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Add switches to your shifter.
[Re: Sammy]
#2666948
06/17/19 04:04 PM
06/17/19 04:04 PM
Al_Alguire
Las Vegas
Yes I have been awhile on the 31 box as been using a Grid for a few years. But I am seem to recall the ability to add/subtract timing based on gear changes. It senses the RPM drop on the shift and will trigger the stage, which is a number you may need to tailor to your car. Guess I need to brush up on my 7531 stuff been like 8 years
[Re: Al_Alguire]
#2666953
06/17/19 04:24 PM
06/17/19 04:24 PM
Al_Alguire
Las Vegas
Now I remember why I switched to the Grid, WAY more user friendly. Anyway here is a video, you would have start with however much advance you want to begin with and enter retards from there. With a grid you just ad to the base on the scree and don't have to touch the distributor/crank trigger. In the 31 you will have to add the timing to the distributor/crank trigger and subtract from there https://www.youtube.com/watch?v=Er-z-uyW0Us
[Re: Cab_Burge]
#2667044
06/17/19 10:35 PM
06/17/19 10:35 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
And I picked up almost 3 mph but my ET. dropped by 1.5 tenths. ???? I am thinking he meant .015. One and a half thousandths. Ron One and a half hundreds = .015 ![work work](/ubbthreads/images/graemlins/custom/work.gif) , one and half thousands should be written as .0015, not .015 ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) Dang details anyways Yes you are right as I meant one and a half thousandths but did write it wrong as it should be as you put it .0015. Sorry about that. Ron
