Re: Advice on cleaning a rusty MSD Distributor
[Re: hemi-itis]
#2666060
06/15/19 12:23 AM
06/15/19 12:23 AM
Posts: 20,204 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Sad that an MSD looks like that after 2 years! That’s not the distributors fault.
[Re: WS68SSC]
#2666085
06/15/19 04:30 AM
06/15/19 04:30 AM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
MSD doesn't properly coat any of the internal parts. I've cleaned and coated the ferrous parts with a rust converting spray that turned them black. I also drilled a couple large holes in my cap, and made sure the rotor was properly phased, which required an expensive adjustable rotor turned to nearly full travel to correct the phasing issue.
The venting and phase alignment helps reduce the ozone issue mentioned in the post directly below this.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2666098
06/15/19 07:46 AM
06/15/19 07:46 AM
Posts: 2,938 A shed in England
Tig
A shed in England
Pretty much the norm for MSD or any distributor for that matter, Oxygen is ionized into ozone by the high voltages and ozone is highly corrosive. I just keep mine oiled and squirt some rust inhibitor in there from time to time.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: sgcuda]
#2666200
06/15/19 02:23 PM
06/15/19 02:23 PM
Posts: 11,819 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Glass bead, small wire brush, maybe easier and cheaper to just throw new parts in it, including a pick up. Vent the cap. Hit it all with WD40 once in a while.
[Re: CMcAllister]
#2666312
06/15/19 08:12 PM
06/15/19 08:12 PM
Posts: 2,086 CA
crackedback
CA
Brass brush. I wipe them with a little bit of PB blaster on a rag.
I clean them and coat em as well. Just cheap [censored] stuff from MSD for not treating the materials properly for the job they will do.
[Re: crackedback]
#2666351
06/15/19 11:48 PM
06/15/19 11:48 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
That add a buck to the price! ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
[Re: moparx]
#2666537
06/16/19 02:52 PM
06/16/19 02:52 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
Not really sure what caused that. This one had been sitting on my workbench for over 10 years, recently found cleaning...
[Re: Rapid588]
#2667071
06/18/19 01:37 AM
06/18/19 01:37 AM
Posts: 995 Boynton Beach, Fl
Rapid588
Boynton Beach, Fl
![[Linked Image]](http://pic90.picturetrail.com/VOL2182/1270089/24838211/414240371.jpg) I again disassembled them, wire brushed the steel parts to bare metal, and shot each component, including the weights (which had been rusted solid on the shaft) with a light coat of epoxy PPG primer that I was using for something else at the time. I had some 2 part Sharkhide (brand) acid cleaner and sealer that I also had laying around that I used for the the aluminum distributor body as it also had badly corroded, then I assembled with new magnetic pickup, rotor, and the correct marine distributor cap that does NOT have the small black vent cap on top like the regular automotive ones have (coast guard regs.... no vent/spark hazard from a vented cap). I also sprayed inside a very light mist of Gibbs Spray on everything including the reluctors and pickups before closing it up I just took dizzy's out a couple weeks ago after running them again for about 8 months to redo some intake gaskets and this is how they still look.... I was kinda shocked as there is minimal corrosion after doing these simple mods. (the rough aluminum look is from the previous corrosion). My theory, at least on a marine application, even though there is no water or spray mist getting in the bilges, when the hot engines are shut off after a day of use.... including running them with fresh water for 15 minutes to flush, as the distributors cool off they are sucking humid air in as they cool down, which is causing the massive rusting problems. I think that by this coating of all the inside components (there is minimal or no coating from MSD on these components whatsover) and possibly by NOT using the vented type caps (some air does still come in through cap edges i am sure) I think I found a solution of the corrosion/rusting that most ALL marine MSD users face...... I originally did a search how to combat this, and found TONS of automotive users were complaining of the same rusting issues on their MSD's
93 Dodge Stealth - Supercharged 526ci Hemi 93 Dodge Daytona Top Sportsman injected 588 Hemi - plus a lil NOS 67 Hemi GTX (may the 4speed with you!)
[Re: WS68SSC]
#2667097
06/18/19 07:47 AM
06/18/19 07:47 AM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
You do know that those parts, the pick up coil and reluctor are ford parts don't you?? parts store stuff
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
