Re: SMALL BLOCK FIRING ORDER SWAP [Re: Cab_Burge] #2665722
06/14/19 07:34 AM
06/14/19 07:34 AM
Quote
a custom built crankshaft could remedy the issues,
& on a side note there was something in FABO (iirc) about redrilling an oiling hole or holes in the crank journals to duplicate the chebby cranks (SB's iirc) OE routeing for much better very high RPM operation.
Re: SMALL BLOCK FIRING ORDER SWAP [Re: Cab_Burge] #2665733
06/14/19 08:38 AM
06/14/19 08:38 AM
Queensland Australia
moparmacka Offline OP
My head hurts......
Re: SMALL BLOCK FIRING ORDER SWAP [Re: fast68plymouth] #2665734
06/14/19 08:40 AM
06/14/19 08:40 AM
Thanks mate. I will take that on board.
Re: SMALL BLOCK FIRING ORDER SWAP [Re: Cab_Burge] #2665789
06/14/19 11:45 AM
06/14/19 11:45 AM
Washington
madscientist Offline
Washington
Originally Posted by Cab_Burge
I've spent hours writing down different firing orders based on which two pistons are at TDC at the same time, when you do the 4/7 swap all you have accomplished is to move the problem from the driver side rear block to the front passenger side of the block, correct work
1843
6572 Standard Mopar V8 and early Chevy V8 firing order.
The 7-4 swap =1873
6542 shruggy
if you change it to:
1543
6872 you then change the two cylinders firing in line from each other to the passenger side two rear cylinders, correct work scope whiney
I'm done for tonight on this but a custom built crankshaft could remedy the issues, correct devil whistling
It's not so much that you are moving 5 and 7 from firing next to each other. It's better to have 2 and 4 fire next to each other, as the cooling of the front cylinders is better. Again, that is about the least of why it's done.
Changing the FO moves the firing pulses and the engine should be noticeably smoother. The 4 cylinder swap firing order AFAIK came on early Cadillacs and they are butter smooth.
IIRC there are 8 possible firing orders for a V8. The 4 cylinder swap is the best but it's damn hard to get cam cores for a Chrysler with that swap.
Re: SMALL BLOCK FIRING ORDER SWAP [Re: moparmacka] #2665884
06/14/19 04:06 PM
06/14/19 04:06 PM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
There's some very timely information that just came out related to this ... go to https://www.enginelabs.com/engine-t...jamora-answers-your-tech-questions-pt-1/ and read question #6
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: SMALL BLOCK FIRING ORDER SWAP [Re: rumblefish72] #2665961
06/14/19 07:48 PM
06/14/19 07:48 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Excellent article on 4/7 swaps. Also, great info on the EZ roller lifters.
Re: SMALL BLOCK FIRING ORDER SWAP [Re: sgcuda] #2666053
06/15/19 12:00 AM
06/15/19 12:00 AM
The next article on wideband O2 sensors and high overlap cams was very interesting. I had heard about how self-learning ECUs could think idle was lean due to lots of unburnt oxygen and add fuel when the extra oxygen actually was coming from the overlap. And in another article, they showed what the computer would due if you had a bad spark plug wire (it added fuel). EFI is neat but you have to understand what the sensors are telling you and how the system is reacting!!
