Re: Overheats at speed [Re: moparx] #2661568
06/02/19 03:29 PM
06/02/19 03:29 PM
Australia
O
ozymaxwedge Offline OP
O
Australia
Originally Posted by moparx
is the hood sealed to the core support ? that will maximize the air going through the radiator opening instead of just "spilling over" the top of the support.
are your electric fans aftermarket, or some type of OEM ? if aftermarket, i have found them to be optimistic at best on amount of airflow. i ONLY use OEM fans in EVERY electric fan application. they are far and above ANY aftermarket fan made. be warned, however, they require many amps to operate, so an upgraded electrical system is a must.
they also consider high speed airflow, so their shrouds are designed for airflow at speed, while the aftermarket fans and shrouds are not.
lastly, puller fans are way more efficient than pusher fans.
please keep us updated.
beer
I have 3 different hoods, one on at the moment is a glass cowl style hood that would not be sealing much at all, it’s on there to hide the twin 950’s on the tunnel ram from the police 🙄 maybe there is something in this because it is all of a sudden a bit hotter than before.
Fans are Ford something and suck like crazy
1963 Plymouth Max Wedge
1971 Barracuda
Re: Overheats at speed [Re: ozymaxwedge] #2662503
06/05/19 08:23 AM
06/05/19 08:23 AM
Australia
O
O
Australia
Update,,,
Purchased a temp gun, ran the car at home up to 210 and had my son shooting all the right spots with the gun, on the brass fitting that the sensor is in, on the front of the ali heads and even let the pressure out of the radiator and checked the temp of the water, 170 was the highest reading we could get while the gauge was showing 210, had already replace the sender so the gauge is *ucked yeah ??
1971 Barracuda
Re: Overheats at speed [Re: ozymaxwedge] #2662577
06/05/19 11:05 AM
06/05/19 11:05 AM
moparx Offline
moparx  Offline
sure looks like it from here ! [i finally got the pair of x-ray glasses from the comic book add i ordered all those years ago to "see through" women's clothing ! :biggrin
without going back through the thread, was that even mentioned to try an IR gun ? that's usually the first thing i do with heat issues.
i'm so dumb sometimes ! spank and i get dumber the older i get..........
beer
Re: Overheats at speed [Re: ozymaxwedge] #2662621
06/05/19 12:13 PM
06/05/19 12:13 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by ozymaxwedge
Update,,,
Be aware that the IR temp guns should only be used as an indicator as they need to be calibrated for the surfaces they are reading. being off by 40 degrees is unlikely unless you have a bad gun or heavily coated surfaces.
The only way to know for sure what the temp is doing is to used a thermocouple probe installed a closely as possible to the thermostat housing. The probe is then coupled to a digital meter that will read accurately to a 1/10 of a degree or better. They also respond very quickly. I use this method exclusively when chasing temp issues. One can probably get an entire setup for less than 100.00. A lot of digital volt meters now come with this feature/accessory. You can also buy extensions for the probe lead that will allow you to place the meter in the car so you can watch it as you drive. Also make sure you get the correct probe and extension types as there are two different ones. Type J and Type K. Mixing the probes, leads, meter will skew the readings.
In my testing I have found more than one "name brand" gage to be doing exactly what yours appears to be. It is also typical for them to go farther out of whack the warmer the coolant gets.
beer
Re: Overheats at speed [Re: TJP] #2662996
06/06/19 10:17 AM
06/06/19 10:17 AM
moparx Offline
moparx  Offline
then, it can boil down to [yes, pun intended ! laugh2] just how hot is "hot" ?
"hot" to me is 220+ with coolant loss in old stuff, while that temperature in newer vehicles is just running temperature.
with a good cooling system, i would rater see 205-210, than 160-170. but that's just me.
along with the elevated temperature however, the tune MUST be optimized for best results, or bad things WILL happen.
if one doesn't take the effort to do so, or can't for whatever reason, then it's imperative to keep the temps low.
wild swings from idle to cruse need to be looked at because a steady temperature is best.
just my opinion, your mileage may vary.
beer
Re: Overheats at speed [Re: moparx] #2663008
06/06/19 11:01 AM
06/06/19 11:01 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
"over heating" is kinda relative . . . . when the FIRST "Pacific Nationals" (mopars at the strip now) were held in Vegas, in AUGUST, it was HOTTTT outside for sure, think like 110 F in the shade !!! . . . anyhow, I drove my 300Hurst with the AC thumping out cold air, at speed on the highway - was running 205-210 F getting up to 240F at the top of hills, but cooling back down to the 205-210 . . . was not pushing anything out of the rad . . . was factory rad/shroud/t-stat and I had put mechanical temp gauge on the car. Sure it was hot, but no pinging or adverse effects to the old 440 - and NO WAY I was going to NOT use the AC !! . . . .and today - the cars are running at the 205-210 F temps as "normal" . . .
Re: Overheats at speed [Re: a12rag] #2663433
06/07/19 11:13 AM
06/07/19 11:13 AM
moparx Offline
moparx  Offline
if i understand thermostats correctly, they are not fully open until 10-15 degrees above their rating. in other words, a new car stat coming with a 205 degree rating will not reach full opening until 215-220 degrees.
if i understand heat transfer correctly, the larger the difference in temperatures between the coolant and the surrounding material[s] [the radiator structure], the better the heat transfer, thus the better the cooling system will operate.
back in the day, a common factory T-stat was a 180-195 unit, so it is conceivable it was not fully open until 215 degrees.
i too, used to be a believer in keeping temperatures in the 160-175 degree range, but i have had much better running success utilizing higher temperatures than lower ones, so that is my preference now.
still, there is more to it than just placing a piece of cardboard in front of the radiator to bring the temperature up. laugh2
beer
Re: Overheats at speed [Re: a12rag] #2663664
06/07/19 11:49 PM
06/07/19 11:49 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Originally Posted by a12rag
. . . . when the FIRST "Pacific Nationals" . . .
I was there, it was crazy hot on the gravel infield of the race track.
On the cooling, if the car cools back down when you slow down, then most likely it is a water pump or air flow problem. If it will not cool down unless you shut it off and let it cool, it is likely getting air locked. Still a flow problem but caused by trapped air in the system. When I first got my Coronet, it would do that at high speed and not recover, but it had a bad head gasket.
Re: Overheats at speed [Re: 451Mopar] #2664896
06/11/19 09:02 PM
06/11/19 09:02 PM
Australia
O
O
Australia
OK guys, got home from work and fitted a new temperature gauge, AutoMeter #4454 ( $360 Aussie FFS ) , car now running at 180 with a 190 maximum @ 3500 rpm on Highway.
YES !!!!!!!!!!!!!!!!
Thanks for your help.
1971 Barracuda
Re: Overheats at speed [Re: ozymaxwedge] #2664901
06/11/19 09:14 PM
06/11/19 09:14 PM
You sound stoked (my best Australian!).
Re: Overheats at speed [Re: RapidRobert] #2664925
06/11/19 10:06 PM
06/11/19 10:06 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
RR ..... we should take up a COLLECTION for our Aussie member .... 360$ for a water temp gauge ??!!
Re: Overheats at speed [Re: dOc …] #2665019
06/12/19 08:08 AM
06/12/19 08:08 AM
Yes somebody sure came out ahead on that one.
Re: Overheats at speed [Re: ozymaxwedge] #2665021
06/12/19 08:13 AM
06/12/19 08:13 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I admire your dedication!
And do agree with FFS, that seems crazy.
Unfortunately not the first time I've seen Autometer with pricing way out of line.
Rich H.
Esse Quam Videri
Re: Overheats at speed [Re: ZIPPY] #2665092
06/12/19 11:29 AM
06/12/19 11:29 AM
moparx Offline
moparx  Offline
glad it was an easy fix ! up
beer
Re: Overheats at speed [Re: moparx] #2665398
06/13/19 05:51 AM
06/13/19 05:51 AM
Australia
O
O
Australia
beer
Hahahaha, I replaced everything else first .....
1971 Barracuda
Re: Overheats at speed [Re: ozymaxwedge] #2665432
06/13/19 09:32 AM
06/13/19 09:32 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
worki wonder witch guage is bad.
Re: Overheats at speed [Re: bonefish] #2665568
06/13/19 04:25 PM
06/13/19 04:25 PM
SW CO
HemiSportFury Online content
HemiSportFury  Online Content
SW CO
A man with two watches never knows what time it is.
On the other hand, a stopped clock it right twice a day.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60
'57 Belvedere 2dr sedan, current project in process
'19 Cherokee Trail Hawk Elite
'03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
Re: Overheats at speed [Re: BigBlockMopar] #2665742
06/14/19 09:00 AM
06/14/19 09:00 AM
houston, mo
johnnmo Offline
johnnmo  Offline
houston, mo
The two most common things I find when a car overheats at speed are this.
One lower hose collapsing, and too lean in the fuel. Check the plug color!!
