39-47 Dodge wc truck suspension torque specs? #2665344
06/12/19 10:37 PM
06/12/19 10:37 PM
N.Wilkesboro,NC
DusterKrazy Offline OP
N.Wilkesboro,NC
Does anyone here know the torque specs for anything suspension related on the 39-47 Dodge WC 1/2 ton trucks? ..stock straight axle front suspension of course..Thanks
Re: 39-47 Dodge wc truck suspension torque specs? [Re: DusterKrazy] #2665638
06/13/19 08:50 PM
06/13/19 08:50 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I don't have the info for the 39-47, but I do have a factory service manual for a 54 Dodge truck. I would expect the 39-47 specs to be the same.
All the torque specs are based on the bolt size and thread count.
Drag link ball stud nut 1/2"-20 45-75 ft/lbs
Tie rod end ball stud nut 1/2"-20 45-75 ft/lbs
9/16"-18 45-75 ft/lbs
Tie rod clamp bolt 5/16"-24 10-15 ft/lbs
Steering knuckle flange
bearing screws 1/2"-13 25-27.5 ft/lbs
Spring clamp bolt nuts 1/2"-20 62-69 ft/lbs
Hope this helps. i have them all spaced out pretty on my computer, but this is what you get here. Gene
Re: 39-47 Dodge wc truck suspension torque specs? [Re: poorboy] #2698842
09/19/19 12:37 AM
09/19/19 12:37 AM
N.Wilkesboro,NC
N.Wilkesboro,NC
Thanks! up
