Re: Car won't start hot - Vapor lock? [Re: Sniper] #2664884
06/11/19 08:31 PM
06/11/19 08:31 PM
The Historic Hudson Valley
MONC Offline OP
MONC  Offline OP
This should work, no?
THERMOQUAD SPACER
Not sure how that is better than a FEL-PRO 60273, which is 1/6th the price. However, either one will affect your stock choke linkage setup since they will space the carb up more.
Agreed Sniper, seemed quite expensive.
The FEL PRO you listed seems to be only the base gasket though, not a spacer.
In 71 the TQ base gasket was thin. In 78 it was about 1/4" thick same as that spacer, that's the Felpro 60273
Ok gotcha.
Forgot to reply about the choke linkage comment.
So will the spacer not work with it then?
Mopar
Or
No
Car
Re: Car won't start hot - Vapor lock? [Re: MONC] #2664937
06/11/19 10:34 PM
06/11/19 10:34 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
My problem seemed like vapor lock but the pump just wasn't getting fuel through, wasn't leaking so it must have been a one way valve or whatever they use
Re: Car won't start hot - Vapor lock? [Re: MONC] #2665005
06/12/19 07:05 AM
06/12/19 07:05 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Ok gotcha.
It'll work, but you may need to lengthen the rod coming up from the choke well. Just needs looked at and addressed if there is an issue is all.
Re: Car won't start hot - Vapor lock? [Re: Sniper] #2665050
06/12/19 09:23 AM
06/12/19 09:23 AM
MONC Offline OP
MONC  Offline OP
Ok gotcha.
Ok , understood.
Mopar
Or
No
Car
Re: Car won't start hot - Vapor lock? [Re: MONC] #2665100
06/12/19 11:47 AM
06/12/19 11:47 AM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
Thanks for the link vdriver.
Chris, I popped the cap right after it wouldn't start hot, for any pressure, and there didn't seem to be any.
adding vent lines seems like a lot of work than I want to tackle right now on the car.
I am going to start with a phenolic spacer once I figure out which carb/ intake set up I have at what spacer I need.
I hear that, no reason to fix a problem you easily ruled out. I'm with you on the spacer at this point, as a solution to fuel bowl boil (as was pointed out early on).
Re: Car won't start hot - Vapor lock? [Re: BcudaChris] #2665117
06/12/19 12:32 PM
06/12/19 12:32 PM
MONC Offline OP
MONC  Offline OP
Yeah will keep you posted, thanks for the feedback.
Mopar
Or
No
Car
