Re: Car won't start hot - Vapor lock?
[Re: Sniper]
#2664884
06/11/19 08:31 PM
06/11/19 08:31 PM
Posts: 3,674 The Historic Hudson Valley
MONC
Not sure how that is better than a FEL-PRO 60273, which is 1/6th the price. However, either one will affect your stock choke linkage setup since they will space the carb up more. Agreed Sniper, seemed quite expensive. The FEL PRO you listed seems to be only the base gasket though, not a spacer. In 71 the TQ base gasket was thin. In 78 it was about 1/4" thick same as that spacer, that's the Felpro 60273 Ok gotcha. Forgot to reply about the choke linkage comment. So will the spacer not work with it then?
Mopar Or No Car
[Re: MONC]
#2665005
06/12/19 07:05 AM
06/12/19 07:05 AM
Posts: 6,289 nowhere
Sniper
nowhere
Ok gotcha. Forgot to reply about the choke linkage comment. So will the spacer not work with it then? It'll work, but you may need to lengthen the rod coming up from the choke well. Just needs looked at and addressed if there is an issue is all.
[Re: Sniper]
#2665050
06/12/19 09:23 AM
06/12/19 09:23 AM
MONC
Ok gotcha. Forgot to reply about the choke linkage comment. So will the spacer not work with it then? It'll work, but you may need to lengthen the rod coming up from the choke well. Just needs looked at and addressed if there is an issue is all. Ok , understood.
Mopar Or No Car
[Re: MONC]
#2665100
06/12/19 11:47 AM
06/12/19 11:47 AM
Posts: 403 Colorado front range
BcudaChris
Thanks for the link vdriver.
Chris, I popped the cap right after it wouldn't start hot, for any pressure, and there didn't seem to be any. adding vent lines seems like a lot of work than I want to tackle right now on the car. I am going to start with a phenolic spacer once I figure out which carb/ intake set up I have at what spacer I need. I hear that, no reason to fix a problem you easily ruled out. I'm with you on the spacer at this point, as a solution to fuel bowl boil (as was pointed out early on).
