Page 3 of 3 1 2 3
Re: Trick Flow sb heads [Re: Mopar Mitch] #2663677
06/08/19 12:51 AM
06/08/19 12:51 AM
AndyF Offline
AndyF  Offline
Originally Posted by Mopar Mitch
Not to draw away from original poster's intentions, but... what I'd like to see is comparisons between Eddy vs Trick Flow. I'm building a 410 with CR about 9.5-10 (Hughes kit, engine partially built)... camshaft (flat hyd) still to be determined ...wanting wide range rpms especially strong mid-range and ability to run strong higher rpms (I do pylon AX, HSAX and road course lapping sessions).
My purchase is on-hold until ~mid-summer or end of this summer, maybe into early 2020... maybe the EDDYs are simply established and proven.
The Trick Flow heads might be too new to tell but based on the little bit that I know now I'd say the engine you are describing would be better off with ported Edelbrock heads. If you're willing to go with a solid flat tappet cam and rev the engine up past 6000 rpm then maybe the Trick Flow heads would be a better deal. The porting on the Trick Flow heads is super nice but the extra volume in the runner might kill off too much torque for what you want to do.
Re: Trick Flow sb heads [Re: B3422W5] #2663678
06/08/19 12:52 AM
06/08/19 12:52 AM
AndyF Offline
AndyF  Offline
Originally Posted by B3422W5
Will be available to buy in a couple of weeks
They have been produced and are sitting around assembled at Trick flow
They plan to dyno a set yet this month on a 408 test mule. Didnt think to ask Howard how the 408 was setup
Heads should be from 1900-22/2300 bucks fully assembled
The top range will have quality solid roller springs and ti retainers installed.
Intake is going to lag behind by a little bit
Did Trick Flow ever dyno that 408? I haven't seen any published numbers from Trick Flow yet.
Re: Trick Flow sb heads [Re: AndyF] #2663680
06/08/19 01:10 AM
06/08/19 01:10 AM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
Those heads look really good and if OOB they are flowing over 300 they work too! I bot a new set of eddys MRL worked over and he only got 280 out of them.
A Comp 292H flat hyd cam runs pretty good in a 10-1 stroker with enough head. It comes on around 2500. That is what I was running in the 416 before I switched to a solid roller and those new eddy's. Have not ran it yet with the new heads.
Re: Trick Flow sb heads [Re: AndyF] #2663713
06/08/19 07:58 AM
06/08/19 07:58 AM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Not that i have heard
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Trick Flow sb heads [Re: Mopar Mitch] #2663732
06/08/19 09:22 AM
06/08/19 09:22 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I would go with the Trick Flow. I once ran the Indy 360-1 ported flowing 325@.700 with a large roller cam 268* .700 lift and I had no problem with low or mid power. I did run a loose vert@5400 stall. Not sure what's required in stall for your style of racing, but if you can run 8" similar to mine I don't see a problem with Trick Flow. My 67 Barracuda with a 408 ran 10.38@130 at 3300lbs on pump gas(11.3:1), so it was about 580+hp. Best top speed in quarter was 131 on drag radial. I would be willing to bet the Trick Flow heads have much better flow numbers down low and mid lifts than my Indys had. Hope this helps
Re: Trick Flow sb heads [Re: mopar dave] #2665163
06/12/19 02:25 PM
06/12/19 02:25 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Not seeing 302 cfm.
Out of the box.
.100=75cfm
.200=136cfm
.300=201cfm
.400=251cfm
.500=280cfm
.600=283cfm
.700=283cfm
.800=283cfm
Modified port and chamber
.04 removed from common wall from .15 behind intake face to behind headbolt buldge.
Raised roof .175 tapering to nothing right at the guide boss.
TF 2.08 X 8Mmm valve and 8 mm guide.
Widen comb. chamber to 4.06 and move back chamber on intake side
.100=80cfm
.200=151cfm
.300=219cfm
.400=263cfm
.500=291cfm
.600=293cfm
.700=290cfm
.800=290cfm
Still trying to tickle it's belly to get around 310 at .650
Valve job from TF was hanging off the edge of the valve on the supplied 2.02 valve.
Flow test was done with 2.08 valve and guide change with valve seat as it came from TF
seating on inside edge of 45 on 2.08 valve. So valve job to center seat in 45 will probably pick up 1 to 2%
A 2.055 valve would center the valve with valve job as shipped from TF
Not complaining. I think these are as good as the best ported eddys out there, out of the box. Plus with a different port entry plate as TF uses they may make 300cfm. Just posting what I have observed. Dan
Re: Trick Flow sb heads [Re: qwkmopardan] #2665178
06/12/19 02:41 PM
06/12/19 02:41 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Thanks for the info.
Would you happen to have used a 300cfm test plate on that bench at some point?
As I’m sure you’re well aware...... different benches often = different numbers.
Did you test the exhaust?
Re: Trick Flow sb heads [Re: fast68plymouth] #2665261
06/12/19 07:05 PM
06/12/19 07:05 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Exhaust on un-modified chamber was avg 5cfm less than TF flow chart. On modified chamber it ran 5-8 cfm more than advetised, as there is .06 more room on the shrouded side. Exh. port flows so good I will not change it at all. Exh. was 250cfm at .700". My old 587 cast iron heads couldn't muster 190 cfm, with a pipe and car ran 9.60s so I see no need to do anything to exh, except to put in a 1.60 8mm stem valve over the 1.57--11/32 valve supplied to save a little weight..
An interesting note, the TF ford 2.08 x 8mm intake valve weighs 109.5 grams, which is what I bought to put in the TF mopar head vs the as shipped 2.02 valve that weighs 123 grams. Bigger and lighter. Sure seems like a win--win scenario.
Re: Trick Flow sb heads [Re: qwkmopardan] #2665282
06/12/19 07:51 PM
06/12/19 07:51 PM
AndyF Offline
AndyF  Offline
The exhaust might flow too well for most off the shelf cams.
Re: Trick Flow sb heads [Re: qwkmopardan] #2665288
06/12/19 08:20 PM
06/12/19 08:20 PM
Washington
madscientist Offline
Washington
Why would you make the exhaust valve bigger?
Re: Trick Flow sb heads [Re: madscientist] #2665307
06/12/19 09:00 PM
06/12/19 09:00 PM
So. Burlington, Vt.
So. Burlington, Vt.
When you flowed the ex did you use the same size flow tube TF did?
Re: Trick Flow sb heads [Re: fast68plymouth] #2665491
06/13/19 12:53 PM
06/13/19 12:53 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
So it looks like OOTB the TF small block head flows very similar numbers to what a BIG BLOCK Edelbrock or even a mildly cleaned-up W2 flowed when they were first introduced. Pretty impressive IMO for a true bolt-on head even if it takes a little bit of clean-up and an inexpensive 2.055" valve ( I presume they are 11/32 stem +~.100 SBC valves) to get a true 300CFM.
If your .400 lift numbers are anything close to 260-265 on a wedge motor it's going to be a really good broad torque street head, the valve stays open at .400 or above for a lot more useable duration than it does at .500 or .550.
Sometimes I think it would be good if Mopar guys would be thankful and realize just how far the aftermarket has come for a market that is probably 1/5th the size of the total SBC/BBC market.
Look like just the right size for any 390+cube Small block, probably a better overall value than a Victor in that to really wring all the power out of that head you're typically going to overstress a stock 59 degree block, not to mention all of the piston/valvetrain/header flange mods and expenses required to get there.
WIZE
In Car:
Re: Trick Flow sb heads [Re: Streetwize] #2665512
06/13/19 01:36 PM
06/13/19 01:36 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
( I presume they are 11/32 stem +~.100 SBC valves) Valves are 5.200 length. TF uses same lenghth valve in some ford and LS applications. I am putting the Ford 2.08 intakes in mine. Also 1.60 Exh for the Ford in mine. They are 8mm stem instead of 11/32" so are a little bigger but lighter.
Re: Trick Flow sb heads [Re: fast68plymouth] #2665514
06/13/19 01:38 PM
06/13/19 01:38 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
[When you flowed the ex did you use the same size flow tube TF did?] 1 7/8" tube was used. Same as TF uses
Re: Trick Flow sb heads [Re: madscientist] #2665515
06/13/19 01:44 PM
06/13/19 01:44 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
[Why would you make the exhaust valve bigger?] Just to save a little weight. Valve opening and closing 60+ times a second, valve weight reduction could only help. I run solid flat tappet cam so adding spring pressure not an option.160/370 spring pressure.
Re: Trick Flow sb heads [Re: qwkmopardan] #2665555
06/13/19 03:46 PM
06/13/19 03:46 PM
So. Burlington, Vt.
So. Burlington, Vt.
I’ll be interested in hearing what your car does with those heads.
I think your car works well enough so it’ll be a good test for them.
Re: Trick Flow sb heads [Re: fast68plymouth] #2744086
02/17/20 10:01 PM
02/17/20 10:01 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
Anything new to update or add on these heads?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Trick Flow sb heads [Re: Stroker Scamp] #2744134
02/18/20 12:51 AM
02/18/20 12:51 AM
plainwell,michigan
1fastaspen Offline
1fastaspen  Offline
plainwell,michigan
got a set going on a 422 for our duster
75 duster 440 in the works
71 pro street cuda
Page 3 of 3 1 2 3
