Re: pulled axle and thrust button fell out,now what?
[Re: BDW]
#2663798
06/08/19 02:52 PM
06/08/19 02:52 PM
Posts: 15,995 RI Deep in the rust belt
chargervert
I would think that without the thrust buttons ,cornering would put a tremendous amount of side load on the axle bearings.
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
[Re: BDW]
#2663919
06/09/19 04:22 AM
06/09/19 04:22 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
Is that really a must have? With the axles in, where can they go? Unless using green bearings, yes, is a must. With axles in they can't go anywhere, but the thrust buttons ( or thust block when open diff ) makes both axles keep conected keeping the axle assembly axial play with stock bearimgs being adjusted in just passenger side
[Re: A727Tflite]
#2663921
06/09/19 04:27 AM
06/09/19 04:27 AM
NachoRT74
Valencia, España
Maybe the ring and pinion will find the roll pin for you. I think any hardware store could get a same diameter roll pin. Is not really specific for it. Stock one gets a punched shape just to get a limit when installing but is not really needed.
[Re: chargervert]
#2663922
06/09/19 04:32 AM
06/09/19 04:32 AM
NachoRT74
Valencia, España
I would think that without the thrust buttons ,cornering would put a tremendous amount of side load on the axle bearings. The axles will be getting in and out freely no matter the adjuster position, getting bearings out of the race, damaging inner seal and whatever else related to the axial play... drums against brakes assembly plate, pads etc. aside that, when axle bearings are not set into the race correctly, the axles will be getting up and down, side to side... moving out of the center. ( I heard you on the broomstick trick, but, damn! I found hard to get the roll pin and holes matched in that way! )
[Re: NachoRT74]
#2663928
06/09/19 07:10 AM
06/09/19 07:10 AM
Posts: 4,727 Florida
BDW
Is that really a must have? With the axles in, where can they go? Unless using green bearings, yes, is a must. With axles in they can't go anywhere, but the thrust buttons ( or thust block when open diff ) makes both axles keep conected keeping the axle assembly axial play with stock bearimgs being adjusted in just passenger side I understand the thrust buttons are needed. My question was: Is the “roll pin” really needed, If the axles are in, where can the “thrust buttons” go?
[Re: NachoRT74]
#2663933
06/09/19 07:48 AM
06/09/19 07:48 AM
Posts: 6,250 nowhere
Sniper
nowhere
Maybe the ring and pinion will find the roll pin for you. I think any hardware store could get a same diameter roll pin. Is not really specific for it. Stock one gets a punched shape just to get a limit when installing but is not really needed. I think you missed the point that the roll pin may get between the gears and tear it up. Do it right.
[Re: Sniper]
#2664081
06/09/19 04:49 PM
06/09/19 04:49 PM
NachoRT74
Valencia, España
Maybe the ring and pinion will find the roll pin for you. I think any hardware store could get a same diameter roll pin. Is not really specific for it. Stock one gets a punched shape just to get a limit when installing but is not really needed. I think you missed the point that the roll pin may get between the gears and tear it up. Do it right. sure, but I meant the punched shape end/head is not needed once is installed. Any roll pin fitting tight into the holes will make the job
[Re: BDW]
#2664084
06/09/19 04:56 PM
06/09/19 04:56 PM
NachoRT74
Valencia, España
Is that really a must have? With the axles in, where can they go? Unless using green bearings, yes, is a must. With axles in they can't go anywhere, but the thrust buttons ( or thust block when open diff ) makes both axles keep conected keeping the axle assembly axial play with stock bearimgs being adjusted in just passenger side I understand the thrust buttons are needed. My question was: Is the “roll pin” really needed, If the axles are in, where can the “thrust buttons” go? interesting question since I have allways found it gets broken in halfs ( each half inside each button ) making work freely instead like one piece one against the other. Maybe yes maybe not... maybe is just for installation purpouse. I have allways found the thrust buttons should be made in another way and fit tighter into the gears cross somehow. They get WAY LOT OF ROOM around once installed what mostly sure makes to break the roll pin easier. Will never understand that. Maybe thrust buttons should be made somehow being a male and female piece. Just thinking out loud
