Re: 3600-3700 lbs car to run 9.50's? [Re: Bob_Coomer] #266180
03/27/09 05:08 PM
03/27/09 05:08 PM
pa
572charger Offline
572charger  Offline
pa
yeah like chip says go fill it up at the nearest gas station drive to the track, race all day, be faster than 90% of the cars at the track , then drive it to dinner ! but its made to run on the spray !! no compession no gear no convertor !!!! still runs 9.60s on motor !!!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: 3600-3700 lbs car to run 9.50's? [Re: 572charger] #266181
03/27/09 05:26 PM
03/27/09 05:26 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
and how much do these engines cost?
dont get me wrong i am not putting down your stuff,OK!
Re: 3600-3700 lbs car to run 9.50's? [Re: blownzoom440] #266182
03/27/09 05:55 PM
03/27/09 05:55 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
mine...... about $25K
but mes gots a wittle .664", 272 @ .050 street roller
Re: 3600-3700 lbs car to run 9.50's? [Re: Bob_Coomer] #266183
03/27/09 05:55 PM
03/27/09 05:55 PM
Oregon,USA
RAT PATROL Offline
RAT PATROL  Offline
Oregon,USA
Well if Al Alguire drove my car it would be in that weight range. OOOOPS did I say that out loud? Okay, add a few hundred pounds carry the 2, add a couple tenths for driver.....(talent) no that's not the word I'm looking for here. I could be in that ballpark somewhat.
Re: 3600-3700 lbs car to run 9.50's? [Re: Defbob] #266184
03/27/09 06:00 PM
03/27/09 06:00 PM
ELYRIA,OH
ELYRIA,OH
i figured it was in that range.
Re: 3600-3700 lbs car to run 9.50's? [Re: Bob_Coomer] #266185
03/27/09 06:19 PM
03/27/09 06:19 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
I also know what happens when you loose a roller lifter, despite what people say...they can and will come apart.
. They are simple, and dont fly apart on you. With the cam specs I am looking at with this solid flat cam, the spring pressures would be pretty high with the same size roller.
I had a long discussion with Dwayne about a solid vs. roller on the street. I had talked myself out of a roller and was gonna get another flat tappet. Fine, you dont have to deal with checking the lifters on a regular basis, with a roller. As you mentioned, you will need some serious spring pressure with that flat tappet. A bunch of spring pressure on a cast core, over time (who knows how long) might equal breaking the core.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: 3600-3700 lbs car to run 9.50's? [Re: Von] #266186
03/28/09 09:01 AM
03/28/09 09:01 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
FWIW I just found out I've been running 9.70's @ 3850lb on 7 cylinders
Re: 3600-3700 lbs car to run 9.50's? [Re: Tig] #266187
03/28/09 09:29 AM
03/28/09 09:29 AM
MR_P_BODY Offline
MR_P_BODY  Offline
LOL... over on this side of the pond we try to run 8
cylinders
Re: 3600-3700 lbs car to run 9.50's? [Re: MR_P_BODY] #266188
03/28/09 12:24 PM
03/28/09 12:24 PM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
cylinders
Well I have to give those C***y guys a fair fight and there I go thinking I was giving them two chances by keeping it heavy and N/A!
When this motor gets fixed they're all just gonna have to jet up their nitrous kits
