Page 2 of 3 1 2 3
Re: Why is it so hard to choose a valve cover [Re: kowalski440] #2661161
06/01/19 10:38 AM
06/01/19 10:38 AM
michigan
6pakdakota Offline
6pakdakota  Offline
michigan
Originally Posted by kowalski440
I ran the MP cast ones with the fins and logo milled off. Came out looking stock-ish when painted, if you didn't look too close!
I might try that. It looks great
Re: Why is it so hard to choose a valve cover [Re: 6pakdakota] #2661173
06/01/19 11:20 AM
06/01/19 11:20 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I don't know about yinz guys, but I look for made in the USA first thing.
Re: Why is it so hard to choose a valve cover [Re: TonyS451] #2661232
06/01/19 02:25 PM
06/01/19 02:25 PM
TN
68rtcharger Offline OP
TN
Originally Posted by TonyS451
Originally Posted by A39Coronet
Indy no logos with moroso blue gaskets for me...haven't leaked since input them.on three years ago.
Same set up for me and zero leaks. Would be nice if they came with a breather set up, but I guess everyone likes to do their own thing w that.
I really like these covers and several of you on here recommend and run them. Where is the best place to purchase these?
Re: Why is it so hard to choose a valve cover [Re: 68rtcharger] #2661233
06/01/19 02:29 PM
06/01/19 02:29 PM
TN
TN
Re: Why is it so hard to choose a valve cover [Re: CMcAllister] #2661467
06/02/19 10:48 AM
06/02/19 10:48 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Bustin’ out the pittsburgh speak!
I didn’t know the MP cast covers had a reputation for leaking. I would have bought them but they’re expensive.
Re: Why is it so hard to choose a valve cover [Re: radar] #2661481
06/02/19 11:23 AM
06/02/19 11:23 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I thought it was yunz, not yinz. biggrin
Re: Why is it so hard to choose a valve cover [Re: 6pakdakota] #2661488
06/02/19 11:33 AM
06/02/19 11:33 AM
SE Indiana
K
kowalski440 Offline
kowalski440  Offline
K
SE Indiana
Thanks! FTR, they both leaked a couple drops at the firewall corners when started, but quit when warmed up (could prob fix it by snugging those corners down a bit more due to heat cycling- heads were aluminum also). I ran the orange silicone gaskets sold by Marsh Superperformance. Also used an ARP stud kit (2 sbc kits).
Need a thinwall deep socket due to angles on a couple. Breather is an Edelbrock item.
Re: Why is it so hard to choose a valve cover [Re: radar] #2661549
06/02/19 01:49 PM
06/02/19 01:49 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I'm in the deep south of PA so "yinz" or "y'all" are both acceptable.
Re: Why is it so hard to choose a valve cover [Re: CMcAllister] #2661551
06/02/19 01:53 PM
06/02/19 01:53 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Stock
Re: Why is it so hard to choose a valve cover [Re: nss guy] #2661970
06/03/19 08:03 PM
06/03/19 08:03 PM
TN
TN
Originally Posted by nss guy
Stock
Very Nice!!
Re: Why is it so hard to choose a valve cover [Re: nss guy] #2662050
06/03/19 10:46 PM
06/03/19 10:46 PM
Are those the real 1964 M.W. covers or the stock non M.W. with the decals? work grin
I can't see both intake manifold sides of those covers is the reason I have to ask whiney
Re: Why is it so hard to choose a valve cover [Re: Cab_Burge] #2662141
06/04/19 09:01 AM
06/04/19 09:01 AM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
I doubt they are original mw vc's. I had them powercoated and cleared, same with the intake.
Re: Why is it so hard to choose a valve cover [Re: nss guy] #2662146
06/04/19 09:09 AM
06/04/19 09:09 AM
an8sec70cuda Offline
Always been a fan of the Indy cast covers w/o their logo on them. I milled the logo off of mine.
The ones from Summit looks just like the Indy covers, so I'd try them.
I also like the old school M/T and Cal Custom covers...have a pair of each hanging on the wall to use on something in the future possibly.
Never been a fan of the fabricated valve covers personally. They look cheap to me for some reason, even though the good ones are pricy.
Here's a pic of the Indy covers after milling off the logo...
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Why is it so hard to choose a valve cover [Re: an8sec70cuda] #2662246
06/04/19 01:09 PM
06/04/19 01:09 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Cast/rigid covers are best for sealing... but they are heavy... I currently use them (Edlebrock)... but have considered getting some light-weight stamped aluminum covers... I think Morosso has offered them... probably saves maybe 2-3-4 pounds off the front-end... but would then absolutely check for flatness, especially at the bolt holes.. and probably use some bolt-load spreading washers at each bolt hole to prevent metal distortion.... and good quality cork-rubber gaskets (Fel-Pro's Cork-Lam... having metal middle shim with top/bottom cork-rubber... I like those the best... keeps their shape and lasts a long time!)... good for conformability.
Re: Why is it so hard to choose a valve cover [Re: kowalski440] #2662915
06/06/19 01:58 AM
06/06/19 01:58 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Nice work as you did a great job on them and they look good. Ron
Re: Why is it so hard to choose a valve cover [Re: nss guy] #2662916
06/06/19 01:59 AM
06/06/19 01:59 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Stock
You gotta love the stock look and they look great ! Ron
Re: Why is it so hard to choose a valve cover [Re: 68rtcharger] #2662930
06/06/19 05:41 AM
06/06/19 05:41 AM
Norway
cudaerik Online content
cudaerik  Online Content
Norway
Good good results with the fabricated aluminium valve covers from 440 Source in combination with the Moroso blue rubber gaskets with the steel core
[/url]
[url=https://www.summitracing.com/int/parts/mor-93055]
1970 Plymouth Cuda, 512cid on 230 400 block, 5 speed manual.(TKO 600)
1970 Dodge Charger 500, 446cid, 5speed manual.(TKO 600)
1969 Plymouth Roadrunner, 383cid, 5speed manual (Tremec TKX)
Re: Why is it so hard to choose a valve cover [Re: an8sec70cuda] #2662998
06/06/19 10:23 AM
06/06/19 10:23 AM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
I did the same thing but took it one step further and milled off the indy logo on the intake also.
Re: Why is it so hard to choose a valve cover [Re: Airwoofer] #2663004
06/06/19 10:47 AM
06/06/19 10:47 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I also like the look of the cast covers best....
Ditto on the logo delete option on all mine....no logo unless it was free....and nobody gives away free stuff anymore.
Re: Why is it so hard to choose a valve cover [Re: 383man] #2663005
06/06/19 10:48 AM
06/06/19 10:48 AM
SE Indiana
K
kowalski440 Offline
kowalski440  Offline
K
SE Indiana
Thanks! I was wanting a stock look without the leaks of the steel covers. Will do the same again when I do another motor, for sure!
Page 2 of 3 1 2 3
