Re: HOW TO TELL IF ITS A 440 6-PACK BLOCK
#266118
03/26/09 08:01 PM
03/26/09 08:01 PM
Posts: 3,131 across the river from Portland...
472 R/T SE
My buddy is doing a semi restoration on a '70 Charger R/T SE. The motor was a warranty piece that's never been out of the car, obvious by the fact the block is bare metal whereas the heads, intake, oilpan, bellhousing are orange. Strangest thing is there were 7 six pack rods and one standard.
[color:"purple"] HELP SUPPORT THE REGISTRIES.All cars matter. 1970 Charger Registry I like to sleep For I'm walking in my dreams. Live life like every DAY is your last! Chrysler R/T Club[/color]
[Re: DPelletier]
#266121
03/26/09 11:13 PM
03/26/09 11:13 PM
Posts: 2,928 A tad North of Indy
Blown71X
super gas
super gas
A tad North of Indy
which is why the term "six pack rods" is the biggest misnomer in Mopar history.
The best statment i`ve read in months
And the ONLY good use for those 36+ year old stupid heavy "big" rods
Rick
[Re: mccannix]
#266124
03/27/09 08:56 AM
03/27/09 08:56 AM
Posts: 75,126 A Banana Republic near you.
JohnRR
The bulletin reads in part: "A new piston will be incorporated into production on the 440 C.I.D. standard engine late in 1971 production.This piston is lighter than the early piston so requires a new crankshaft. Severe engine vibration will result if the early crankshaft or piston is used in these engines. The engines will be identified with the letter "C" on the identification pad on the top, adjacent to the left block and tappet rail as follows:" ....shows engine serial pad with stampings and goes on to list pn's for pistons and crank.
very INTERESTING , for years the mASSES have been drinking Galen's koolaide and saying that the C denoted special crankshaft for 440-6 engines ... NOT
[Re: Blown71X]
#266125
03/27/09 08:58 AM
03/27/09 08:58 AM
JohnRR
Rick
[Re: moparply]
#266127
03/27/09 10:23 AM
03/27/09 10:23 AM
JohnRR
Does the stamped date on the engine ID pad by the distributor on a 440 refer to the build of the short block or the long block? At what point did Chrysler stamp the spec. info on that pad?
I guess it depends on the particular build , if it was a complete engine then it would be of the long block , if it was a partial enngine then it was of the short block ...
[Re: JohnRR]
#266130
03/27/09 12:24 PM
03/27/09 12:24 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
easy it will have one of these on top of it.
And these under that!
[Re: 62maxwgn]
#266132
03/27/09 12:46 PM
03/27/09 12:46 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
yes how could I forget those???
