gauge cluster connector terminals - where to buy #2661057
05/31/19 09:10 PM
05/31/19 09:10 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Where can a person buy the terminals that fit the round connector that plus into the back of the gauge cluster?
Re: gauge cluster connector terminals - where to buy [Re: Stanton] #2661143
06/01/19 09:40 AM
06/01/19 09:40 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
would help to know what car/cluster... however they use to be molex terminals
Re: gauge cluster connector terminals - where to buy [Re: NachoRT74] #2661150
06/01/19 09:59 AM
06/01/19 09:59 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
'69 b body - non rally cluster. The ones in the main round connector.
Re: gauge cluster connector terminals - where to buy [Re: Stanton] #2661210
06/01/19 12:50 PM
06/01/19 12:50 PM
Maryland
MoparMike1974 Offline
Maryland
Molex .093 fit the pins good. Not sure if they will lock into the housing. I can check today.
https://www.twistywristarcade.com/093-connectors/325-terminal-093-female-14-20awg-tin.html
Re: gauge cluster connector terminals - where to buy [Re: MoparMike1974] #2661228
06/01/19 01:58 PM
06/01/19 01:58 PM
Maryland
Maryland
Yes, looks like they will work.
Re: gauge cluster connector terminals - where to buy [Re: MoparMike1974] #2661268
06/01/19 04:48 PM
06/01/19 04:48 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
AWESOME !! Thanks. Even managed to find them in Canada !!
Re: gauge cluster connector terminals - where to buy [Re: Stanton] #2661405
06/02/19 04:39 AM
06/02/19 04:39 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
If you really want to make them tight tight, put them in a vice and squeeze them just a little. Make them oval. If you look at the factory female plugs, they are a little ovaled. I could not believe that a new harness from H&S did not have these on. I had to find them locally and replace the "female connectors" they had on. Pretty lame for a $500 part.
Re: gauge cluster connector terminals - where to buy [Re: 70HemiGTX] #2661497
06/02/19 11:47 AM
06/02/19 11:47 AM
moparx Offline
moparx  Offline
i too, have used the .093 molex connectors. those, and the .125 connectors are also used in the column to main harness connectors.
there is also a dedicated molex terminal crimper, but if one takes care, the crimp can be done using a weatherpak crimper.
buy quality connectors with a few extras to practice with. whatever you do, DON'T buy one of those eleventybillion piece kits that include the crimping pliers, from those import stores that are made of CHINESIUM. ! shake_head
beer
Re: gauge cluster connector terminals - where to buy [Re: moparx] #2662175
06/04/19 10:25 AM
06/04/19 10:25 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Yes. A quality crimping tool is a must!
