Re: Bypass Radiator trans cooler??
[Re: modelmakerinc]
#2660957
05/31/19 01:46 PM
05/31/19 01:46 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
If the aftermarket cooler is a decent sized one, I don't see a problem at all doing that.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: Sniper]
#2661003
05/31/19 05:49 PM
05/31/19 05:49 PM
Posts: 16,831 Between Houston & Galveston TX
SattyNoCar
While sniper is correct regarding temps and transmission fluid, given your location (Florida), I don't see an issue. I had a factory trans cooler off a cop car that was as big as an AC condenser, took up the entire space in front of the radiator. From the factory, the fluid went thru the radiator first, then the cooler. When the trans cooler in the radiator failed, I ran just the auxiliary cooler. I ran the transmission this way for over 100K miles without issue.
John
The dream is dead, long live the dream.......đŸ˜¥
[Re: Sniper]
#2661023
05/31/19 07:13 PM
05/31/19 07:13 PM
Posts: 2,345 west palm beach, florida
modelmakerinc
Thanks for the replies, after speaking with a few of my car friends and your input I am confident I will be fine with just the cooler and bypassing the radiator. The bigger issue with my set up was the 22" radiator only allowed for a 15" fan with a shroud.
The 26 will allow a 18" fan that was the original to the engine.
[Re: modelmakerinc]
#2661028
05/31/19 07:34 PM
05/31/19 07:34 PM
Posts: 3,089 Michigan
A727Tflite
The thermal by-pass is there for one purpose - get the fluid up to temperature as quick as possible.
Fuel economy first, then consistent shift quality next.
Cooling packages are so good now on factory cars and trucks and with lockup that it’s possible for fluid to run way to cold for much too long killing fuel economy. The by-pass speeds the heating up to prevents that.
With a non-lockup converter that’s not too likely for those in the sunbelt states (not too likely to stay cold).
In Super cold areas it’s possible for some fluids to gel in the aux cooler driving in ambients that are sub zero, trans fluid with Paraffin based additives at -15F.
The T bypass was/is especially needed there.
[Re: A727Tflite]
#2661080
05/31/19 10:50 PM
05/31/19 10:50 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Many people like me don't drive our muscle cars when its real cold out. I like to have the windows down when I drive my 63 because I enjoy it more like that so I don't drive it in very cold weather. Its usually at least 55 to 60 degree's out when I drive mine. And I have used only an aftermarket cooler mounted in front of my rad. I have been driving and racing mine like this since 2006 and its still working great and the fluid is a nice red color. In fact I just raced it about a week and a half ago and it still shifts perfect and still runs 10.70's and 10.80's all day as it has since I put this eng in in 2011. My point being since I don't drive in real cold weather its worked fine since 2006 with just an aftermarket cooler. Ron
[Re: 383man]
#2661086
05/31/19 11:37 PM
05/31/19 11:37 PM
Posts: 18,157 Mass
DAYCLONA
Mass
My point being since I don't drive in real cold weather its worked fine since 2006 with just an aftermarket cooler. Ron Same here, on the few automatic equipped vehicles I have, I prefer to run just a remote cooler, esp after loosing 2 transmissions over the years to the internal radiator trans coolers rupturing and mixing h20/antifreeze in the tranny...
[Re: modelmakerinc]
#2661197
06/01/19 12:26 PM
06/01/19 12:26 PM
Posts: 43,240 Bend,OR USA
Cab_Burge
If you decide to use the external cooler only install a good, accurate, tranny temp gauge in the pan so you know what the actual trans fluid temps are If it never gets above 160 F move it to a place that it will run from 160 to 240 F all the time Dominic,Thumperdart, did what you doing when he went to a aluminum radiator in his BB Dart, he had a small three row cooler mounted in front of the radiator and the trans temps in the summer in Victorville, CA in the Mohave desert never got above 140 F when he was beating on the car street racing it in town He moved so it was between the bumper and the radiator mounted horizontal to the street out of the main air flow and it ran from 160 to 220 F
