Re: Why is it so hard to choose a valve cover
[Re: kowalski440]
#2661161
06/01/19 10:38 AM
06/01/19 10:38 AM
Posts: 156 michigan
6pakdakota
michigan
I ran the MP cast ones with the fins and logo milled off. Came out looking stock-ish when painted, if you didn't look too close! I might try that. It looks great
[Re: 6pakdakota]
#2661173
06/01/19 11:20 AM
06/01/19 11:20 AM
Posts: 11,739 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I don't know about yinz guys, but I look for made in the USA first thing.
[Re: TonyS451]
#2661232
06/01/19 02:25 PM
06/01/19 02:25 PM
Posts: 228 TN
68rtcharger
TN
Indy no logos with moroso blue gaskets for me...haven't leaked since input them.on three years ago. Same set up for me and zero leaks. Would be nice if they came with a breather set up, but I guess everyone likes to do their own thing w that. I really like these covers and several of you on here recommend and run them. Where is the best place to purchase these?
[Re: 68rtcharger]
#2661233
06/01/19 02:29 PM
06/01/19 02:29 PM
Posts: 228 TN
68rtcharger
TN
[Re: CMcAllister]
#2661467
06/02/19 10:48 AM
06/02/19 10:48 AM
Posts: 1,682 Philadelphia
radar
Philadelphia
I don't know about yinz guys, but I look for made in the USA first thing. Bustin’ out the pittsburgh speak! I didn’t know the MP cast covers had a reputation for leaking. I would have bought them but they’re expensive.
[Re: radar]
#2661481
06/02/19 11:23 AM
06/02/19 11:23 AM
BradH
I don't know about yinz guys, but I look for made in the USA first thing. Bustin’ out the pittsburgh speak! I thought it was yunz, not yinz. ![biggrin biggrin](/ubbthreads/images/graemlins/custom/biggrin.gif)
[Re: 6pakdakota]
#2661488
06/02/19 11:33 AM
06/02/19 11:33 AM
Posts: 129 SE Indiana
kowalski440
SE Indiana
I ran the MP cast ones with the fins and logo milled off. Came out looking stock-ish when painted, if you didn't look too close! I might try that. It looks great Thanks! FTR, they both leaked a couple drops at the firewall corners when started, but quit when warmed up (could prob fix it by snugging those corners down a bit more due to heat cycling- heads were aluminum also). I ran the orange silicone gaskets sold by Marsh Superperformance. Also used an ARP stud kit (2 sbc kits). Need a thinwall deep socket due to angles on a couple. Breather is an Edelbrock item.
[Re: radar]
#2661549
06/02/19 01:49 PM
06/02/19 01:49 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I don't know about yinz guys, but I look for made in the USA first thing. Bustin’ out the pittsburgh speak! I didn’t know the MP cast covers had a reputation for leaking. I would have bought them but they’re expensive. I'm in the deep south of PA so "yinz" or "y'all" are both acceptable.
[Re: nss guy]
#2661970
06/03/19 08:03 PM
06/03/19 08:03 PM
Posts: 228 TN
68rtcharger
TN
[Re: nss guy]
#2662050
06/03/19 10:46 PM
06/03/19 10:46 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
Are those the real 1964 M.W. covers or the stock non M.W. with the decals? ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) I can't see both intake manifold sides of those covers is the reason I have to ask ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif)
[Re: nss guy]
#2662146
06/04/19 09:09 AM
06/04/19 09:09 AM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
Always been a fan of the Indy cast covers w/o their logo on them. I milled the logo off of mine. The ones from Summit looks just like the Indy covers, so I'd try them. I also like the old school M/T and Cal Custom covers...have a pair of each hanging on the wall to use on something in the future possibly.
Never been a fan of the fabricated valve covers personally. They look cheap to me for some reason, even though the good ones are pricy.
Here's a pic of the Indy covers after milling off the logo...
[Re: an8sec70cuda]
#2662246
06/04/19 01:09 PM
06/04/19 01:09 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Cast/rigid covers are best for sealing... but they are heavy... I currently use them (Edlebrock)... but have considered getting some light-weight stamped aluminum covers... I think Morosso has offered them... probably saves maybe 2-3-4 pounds off the front-end... but would then absolutely check for flatness, especially at the bolt holes.. and probably use some bolt-load spreading washers at each bolt hole to prevent metal distortion.... and good quality cork-rubber gaskets (Fel-Pro's Cork-Lam... having metal middle shim with top/bottom cork-rubber... I like those the best... keeps their shape and lasts a long time!)... good for conformability.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: kowalski440]
#2662915
06/06/19 01:58 AM
06/06/19 01:58 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I ran the MP cast ones with the fins and logo milled off. Came out looking stock-ish when painted, if you didn't look too close! Nice work as you did a great job on them and they look good. Ron
[Re: 68rtcharger]
#2662930
06/06/19 05:41 AM
06/06/19 05:41 AM
Posts: 87 Norway
cudaerik
Norway
Good good results with the fabricated aluminium valve covers from 440 Source in combination with the Moroso blue rubber gaskets with the steel core [/url] [url=https://www.summitracing.com/int/parts/mor-93055]
1970 Plymouth Cuda, 512cid on 230 400 block, 5 speed manual.(TKO 600) 1970 Dodge Charger 500, 446cid, 5speed manual.(TKO 600) 1969 Plymouth Roadrunner, 383cid, 5speed manual (Tremec TKX)
[Re: an8sec70cuda]
#2662998
06/06/19 10:23 AM
06/06/19 10:23 AM
Posts: 655 Huntsville, AL
Airwoofer
Huntsville, AL
Here's a pic of the Indy covers after milling off the logo... I did the same thing but took it one step further and milled off the indy logo on the intake also.
[Re: Airwoofer]
#2663004
06/06/19 10:47 AM
06/06/19 10:47 AM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
Here's a pic of the Indy covers after milling off the logo... I did the same thing but took it one step further and milled off the indy logo on the intake also. I also like the look of the cast covers best.... Ditto on the logo delete option on all mine....no logo unless it was free....and nobody gives away free stuff anymore.
[Re: 383man]
#2663005
06/06/19 10:48 AM
06/06/19 10:48 AM
kowalski440
SE Indiana
Thanks! I was wanting a stock look without the leaks of the steel covers. Will do the same again when I do another motor, for sure! I ran the MP cast ones with the fins and logo milled off. Came out looking stock-ish when painted, if you didn't look too close! Nice work as you did a great job on them and they look good. Ron
