Re: Sometimes racecars aren't fun [Re: tboomer] #2656838
05/19/19 11:35 AM
05/19/19 11:35 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Quote
My bet is that it is the head. But we'll see.
I totally get where you’re coming from....... but you have a Megablock, right?
Anytime there’s a MP part involved......... it always suspect imo.
I’m thinking....... head? Block?........ that’s a “pick em”.
I doubt it’s the gasket....... but you might luck out.
Re: Sometimes racecars aren't fun [Re: fast68plymouth] #2657025
05/19/19 09:12 PM
05/19/19 09:12 PM
birdtracker Offline
birdtracker  Offline
a friend of mine had his mega block crack in the #7 cylinder down at the bottom where it had been clearanced. Antifreeze in the oil. Birdtracker
Re: Sometimes racecars aren't fun [Re: fast68plymouth] #2657031
05/19/19 09:27 PM
05/19/19 09:27 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Originally Posted by fast68plymouth
Quote
Yes, it's a Mega Block. It is the later "supposed good style". Probably over 700 passes on it between me and Jim when he ran it.
Doug
Re: Sometimes racecars aren't fun [Re: dvw] #2657139
05/20/19 08:45 AM
05/20/19 08:45 AM
an8sec70cuda Offline
Wow, that sucks to drive so far to have to turn around and come home w/o making a run! Here's hoping for a easy fix!
Glad you found it before making a pass though...be a shame for something to happen to that car!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Sometimes racecars aren't fun [Re: dvw] #2657155
05/20/19 09:25 AM
05/20/19 09:25 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Oh crap. Hope the damage is minimal.
Rich H.
Esse Quam Videri
Re: Sometimes racecars aren't fun [Re: ZIPPY] #2657485
05/21/19 10:33 AM
05/21/19 10:33 AM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Bummer, hopefully it won't take much to get her back up and running.
72 Plymouth Roadrunner 11.08@123.25
Re: Sometimes racecars aren't fun [Re: Roughbird72] #2659606
05/27/19 12:04 PM
05/27/19 12:04 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Any luck on finding the problem?
Re: Sometimes racecars aren't fun [Re: Sammy] #2659834
05/28/19 05:17 AM
05/28/19 05:17 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Got it apart yesterday. Very little water in the pan, maybe 1-2 oz. It hadn't been run so it didn't mix with the oil. Checking the torque on the bolts they all were loose. I've never checked torque on disassembly before. But never had an issue either. Every stud I checked the moved 15 degrees at least. Pulled both heads as they both were loose. The was some pitting around the water jacket holes last time it was apart. Dropped the heads off at my Machinist. #6 chamber will get pressure checked. Going to weld up the pits and resurface both heads. The deck height on that rod is with-in .001" of install. Ill talk to Tom Molnar today about the rod for possible damage due to hydro-lock. Also going to call Mickey at Cometic . I used a different style torque wrench last time. Maybe I missed the setting?
Doug
Re: Sometimes racecars aren't fun [Re: dvw] #2659850
05/28/19 07:36 AM
05/28/19 07:36 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Doug
the Cometics are almost the same trouble as a copper gasket...lol
A lot of big name engine builders now are silicone the water jacket holes, some even the whole gasket !
Personally ive only had trouble sealing the upper part on my cometics, and that's because of the Indy block shape of the passages. A little silicone seemed to seal it up. but you can clearly see the passage is right on the embossment. On my sons smallblock, every water hole got a smear of red silicone. No leaks so far...but fingers crossed.
At one point I was draining my water every time I put the car back in the trailer to make sure there would be no water leaks...lol
....BAD A$$ STREET CAR.....
Re: Sometimes racecars aren't fun [Re: n20mstr] #2660723
05/30/19 07:27 PM
05/30/19 07:27 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Update; pinhole in the floor of the #6 intake port. That explains very little coolant in the oil vs the large coolant loss. Most went out the header. We'll get it welded up and back together.
Doug
Re: Sometimes racecars aren't fun [Re: dvw] #2660731
05/30/19 07:46 PM
05/30/19 07:46 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Doug
I glad to hear it wasn’t more serious. Are you going to make it to Pittsburgh this year
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Sometimes racecars aren't fun [Re: dvw] #2660742
05/30/19 08:24 PM
05/30/19 08:24 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Doug
Cool! Glad it wasn't catastrophic!
'63 Dodge 330
11.19 @ 121 mph
Re: Sometimes racecars aren't fun [Re: GY3] #2660782
05/30/19 10:21 PM
05/30/19 10:21 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
It sure could be a lot worse than it is, good luck with it.
