Page 2 of 3 1 2 3
Re: 1968 Charger....budget bomber [Re: ] #2690803
08/23/19 11:00 PM
08/23/19 11:00 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Originally Posted by Superfreak
"Budget paint job".........Look at the paint job Pat did on his charger, I would class that as budget so if you set up like he did then you will have no worries at all. I will be painting my car as well and setting up a make shift booth in my garage. (22'-7"x 25'x 12'-2")
LOL. I'm not even close to being in the same league as Pat. Pat has more skills and patience then me. Mine will be a satin or patina job.
1970 Barracuda B5 6.1 Hemi/6 speed
1969 Charger survivor in R6 383/727-wrecked 12/24/18
1968 Charger in original burgundy paint "Ribeye"
1968 Charger w/ 6.1L, TR-6060, 9"
1968 Roadrunner w/ 6.1L/6 speed
2011 Dodge Ram w/ 6.7L
Re: 1968 Charger....budget bomber [Re: 70B5Cuda] #2696333
09/10/19 10:05 PM
09/10/19 10:05 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
I spent about three hours knocking undercoating out of the wheel wheels and from the hump above the rear axle. I think I have about 3-4 more hours until it is completely finished.
Re: 1968 Charger....budget bomber [Re: ] #2708216
10/18/19 10:21 PM
10/18/19 10:21 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Finally found the time to remove the every last bit of the undercoating...
Re: 1968 Charger....budget bomber [Re: 70B5Cuda] #2708649
10/20/19 08:07 PM
10/20/19 08:07 PM
ontario canada kingston
aspenrt360 Offline
aspenrt360  Offline
too bad so much got cut out it looks like it was a very solid car all in all. great work by the way i am going to get myself one of t hose needle scalers!
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: 1968 Charger....budget bomber [Re: aspenrt360] #2767425
04/23/20 01:16 PM
04/23/20 01:16 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
I finally got back to this Charger. I sent it out to the media blaster...
Re: 1968 Charger....budget bomber [Re: 70B5Cuda] #2767462
04/23/20 02:47 PM
04/23/20 02:47 PM
Berlin, CT
SportFuryS/23383 Offline
Confused
Confused
Berlin, CT
I am following this with interest, as I love these years of the Chargers. You are doing a very nice job so far, keep up the good work. I am looking forward to seeing how this turns out. If you would like check out our build on a '66 Charger.
If You Ask Me This Whole World Has Gone To Hell- Creed Fisher
Proud Supporter Of LGBT (Liberty Guns Beer & Trump)
Re: 1968 Charger....budget bomber [Re: 70B5Cuda] #2767653
04/23/20 09:58 PM
04/23/20 09:58 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Originally Posted by 70B5Cuda
I finally got back to this Charger. I sent it out to the media blaster..[Linked Image]
Best time to install sub-rame connectors?
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: 1968 Charger....budget bomber [Re: DynoDave] #2768353
04/26/20 09:43 AM
04/26/20 09:43 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
I have been doing some real thinking about subframe connectors.....I haven't decided yet
The day after I got it back, it got sealed in epoxy. First three pics are bare metal. Last two are in primer
Re: 1968 Charger....budget bomber [Re: 70B5Cuda] #2771900
05/06/20 07:35 PM
05/06/20 07:35 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
New rear crossmember and rear valance...
New one piece trunk floor...
fitting a lower patch...
Re: 1968 Charger....budget bomber [Re: 70B5Cuda] #2775264
05/16/20 10:31 PM
05/16/20 10:31 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Floor pans are in....
Re: 1968 Charger....budget bomber [Re: 70B5Cuda] #2775559
05/17/20 07:43 PM
05/17/20 07:43 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Nicely done! up
DynoDave
Member # 12304
Re: 1968 Charger....budget bomber [Re: DynoDave] #2781542
06/04/20 10:03 PM
06/04/20 10:03 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Cabin floor spot welds all knocked down and dressed
Trunk floor is also in now
Re: 1968 Charger....budget bomber [Re: 70B5Cuda] #2781575
06/05/20 12:44 AM
06/05/20 12:44 AM
New Mexico
UCUDANT Online content
Troll Hunter
UCUDANT  Online Content
Troll Hunter
New Mexico
up Dang, Great job
Re: 1968 Charger....budget bomber [Re: UCUDANT] #2782998
06/08/20 07:44 PM
06/08/20 07:44 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Originally Posted by UCUDANT
up Dang, Great job
Thanks!
After some straightening, the driver's side quarter panel end cap fits greats now. before and after...
The driver's side quarter also had rust on in front of the rear wheel well. It was patched inside and out...
Re: 1968 Charger....budget bomber [Re: 70B5Cuda] #2783816
06/10/20 06:09 PM
06/10/20 06:09 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Just below the previous patch....also in front of the left rear wheel...
Re: 1968 Charger....budget bomber [Re: 70B5Cuda] #2784788
06/12/20 09:56 PM
06/12/20 09:56 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Right quarter needed some straightening...
Re: 1968 Charger....budget bomber [Re: 70B5Cuda] #2786507
06/17/20 06:06 PM
06/17/20 06:06 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
The area under the battery tray was rusty. Used a solid original donor...
Re: 1968 Charger....budget bomber [Re: 70B5Cuda] #2787340
06/20/20 09:53 AM
06/20/20 09:53 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
A previous owner cut out part of the passenger side wheel tub...apparently for a patch.
Re: 1968 Charger....budget bomber [Re: 70B5Cuda] #2787342
06/20/20 10:01 AM
06/20/20 10:01 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
The left quarter panel patch was AMD and needed trimming since it was too long-see the first picture.
Re: 1968 Charger....budget bomber [Re: 70B5Cuda] #2788122
06/22/20 03:07 PM
06/22/20 03:07 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Right quarter panel patch...
Page 2 of 3 1 2 3
