Budget 383 Build
#2659344
05/26/19 01:48 PM
05/26/19 01:48 PM
Posts: 156 michigan
6pakdakota
michigan
I am getting ready to put a 383 together for my 85 D100. The truck will be used as a daily driver during the summer and should weigh about 3900 pounds with driver. I would like the truck to run 12s and use some of the parts I have laying around collecting dust. Here is what I have to work with. .030 over 383 with flat top pistons .030 in the hole with no valve reliefs. It should be about 8.5:1. 346 heads mildly ported with 2.14/1.81 valves Factory rockers Weiand action plus intake 750 Holley 1 3/4 headers 727 trans with shift kit TCI Breakaway torque converter 8 3/4 rear end with 3.23, 3.91 or 4.10 gears I still need a new camshaft and would prefer a hydraulic flat tappet. Do you guys have any suggestions for a good shelf cam that will help me reach my goals and work with the pistons I have? Also if you see anything that might not work let me know and thanks in advance. Here is a picture of the truck it’s going in. It’s the one towing the trailer.
Re: Budget 383 Build
[Re: 6pakdakota]
#2659351
05/26/19 02:32 PM
05/26/19 02:32 PM
moparpollack
Lil Herman
Lil Herman
85086
If it's going to weight 3900 and run a high 12, buy a nitrous kit for it.
[Re: 6pakdakota]
#2659365
05/26/19 03:50 PM
05/26/19 03:50 PM
RapidRobert
The truck will be used as a daily driver during the summer and should weigh about 3900 pounds with driver. One of the (2) Summit house brand cams. 3.23 gears.
[Re: RapidRobert]
#2659395
05/26/19 05:07 PM
05/26/19 05:07 PM
Posts: 156 michigan
6pakdakota
michigan
The truck will be used as a daily driver during the summer and should weigh about 3900 pounds with driver. One of the (2) Summit house brand cams. 3.23 gears. The larger of the two summit cams doesn’t seem too bad. Do you know if these are a quality piece? I wouldn’t mind more lift, but I’m not sure if I would have clearance issues.
[Re: 6pakdakota]
#2659444
05/26/19 08:22 PM
05/26/19 08:22 PM
RapidRobert
The truck will be used as a daily driver during the summer and should weigh about 3900 pounds with driver. One of the (2) Summit house brand cams. 3.23 gears. The larger of the two summit cams doesn’t seem too bad. Do you know if these are a quality piece? I wouldn’t mind more lift, but I’m not sure if I would have clearance issues. I have one, not yet used. Several people have recommended em with no issues so I pulled the trigger on one for a mild build. Not sure if you have enough P/V clearance or not but .030" IS pretty close to the top.
[Re: RapidRobert]
#2659490
05/26/19 10:23 PM
05/26/19 10:23 PM
Posts: 43,283 Bend,OR USA
Cab_Burge
The lobe separation angle and lift and duration at from 30 degrees BTDC to around 15 ATDC on the intake valves makes the valve get close to the piston tops A cam ground on a 105 LSA with 260 degrees @.050 installed at 105 LSA will have less V to P clearances than the same lobe put on a cam with 110 LSA installed at 110 on the intake lobes in the same motor
[Re: 6pakdakota]
#2659552
05/27/19 09:14 AM
05/27/19 09:14 AM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
It doesn’t look like a 12-sec package to me, but you have the parts and the plan........ and it will run what it runs.
[Re: 6pakdakota]
#2660127
05/28/19 07:56 PM
05/28/19 07:56 PM
Posts: 4,210 New York
polyspheric
New York
The combination of short stroke and long rods (n = 1.88:1) means the piston is very close to the deck around TDC which limits lift. This narrows your choice of which cam has enough .050" duration (like 240) but low lift or wide LSA. Your static CR is low for any hot cam. Your deck clearance is too loose for good quench/turbulence.
Boffin Emeritus
