J nut for battery tray supports #2659262
05/26/19 07:11 AM
05/26/19 07:11 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Has anyone found a source for the correct nut found on the battery tray supports on a 69 b body? They are on other cars as well I referring to the ones that do not come to a complete closing all the way to the end. They are not U nuts like fender nuts. I think the ones on the inner fender through the bottom of the tray are different and they are U nuts. I have pictures at the shop. RT specialties does not show the correct ones. If I really want to get picky, I could try and find the to odd bolts that connect on the bottom of the battery tray to the inner fender. The have are pointed and self tapping. I bet those are impossible to find. They are always rusted to death, even in Texas.
Re: J nut for battery tray supports [Re: fastmark] #2659294
05/26/19 10:04 AM
05/26/19 10:04 AM
cbusters Offline
cbusters  Offline
Re: J nut for battery tray supports [Re: cbusters] #2659312
05/26/19 11:22 AM
05/26/19 11:22 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
This is the one. Part no 6023 171
Re: J nut for battery tray supports [Re: fastmark] #2659517
05/27/19 01:38 AM
05/27/19 01:38 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
AMKproducts.com has this one, Chrysler part number 6023169, 1/4-20. Their part number B-11980. See:
https://www.amkproducts.com/bulk-fasteners-listing/?codeforlookup=7126
And scroll down to B-11980.
Also a similar one in 5/16-18, B-11993.
Re: J nut for battery tray supports [Re: kentj340] #2659526
05/27/19 06:41 AM
05/27/19 06:41 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
That looks like it. Thanks much.
Re: J nut for battery tray supports [Re: kentj340] #2659554
05/27/19 09:19 AM
05/27/19 09:19 AM
WV
Little Detroit Offline
WV
Little Detroit Restorations - Largest selection of OEM Mopar Fastners in stock. checkout the website, littledetroitrestoratios.com
Re: J nut for battery tray supports [Re: Little Detroit] #2659584
05/27/19 10:45 AM
05/27/19 10:45 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Re: J nut for battery tray supports [Re: a12rag] #2659849
05/28/19 07:34 AM
05/28/19 07:34 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Great info guys, as usual. I made a big order at amk, but it certainly looks like little Detroit has some good products as well. May order some from them as well. None of this stuff is cheap anymore, that’s for sure. The thing I have found in all my parts cars is that not all cars had the same j nut/ bolt in the same spot.
