Factory Carpet Heel Pad 1971 GTX #2657395
05/20/19 11:55 PM
05/20/19 11:55 PM
A727Tflite Online content OP
A727Tflite  Online Content OP
Can anyone share what the factory heel/foot pad looks like on a 1971 GTX?
Rectangular, or rectangular with a cutout, or ?
A picture would be better yet.
Legendary is telling me what I got is correct but it does not match the carpet I took out of my car, mine is factory original.
Re: Factory Carpet Heel Pad 1971 GTX [Re: A727Tflite] #2657460
05/21/19 09:44 AM
05/21/19 09:44 AM
New York
rarefish Offline
rarefish  Offline
New York
When I was restoring my 1971 GTX way back in 1988. I ordered a ACC carpet set from Legendary and it came in with the 70 and earlier retangular heel pad.
I sent it back because the original heel pad that came in the car was the E-body style one. That is the one with the cutout notch in the upper right corner.
My understanding is that the 1971 and later B-bodies had the E-body style heel pads.
Re: Factory Carpet Heel Pad 1971 GTX [Re: rarefish] #2657613
05/21/19 03:46 PM
05/21/19 03:46 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I have seen 10 original cars with the E body heel pad. ACCs standard pad is not E body, but they can make one with that pad if you ask. Get a discount code from Year One and specify a E body pad when you order. That is what I did.
Re: Factory Carpet Heel Pad 1971 GTX [Re: 71birdJ68] #2657797
05/21/19 10:51 PM
05/21/19 10:51 PM
Has anyone ever seen a replacement carpet come with diecut cutouts for the console brackets and such?
The carpet in my car has those diecut cutouts and based on what I know about the car and for as long as I have k own it - it’s the original carpet.
My carpet heel pad is rectangular without a cutout. Car was built 6/71.
Another thought - did the 72 get a different heel pad than 71 ?
Re: Factory Carpet Heel Pad 1971 GTX [Re: A727Tflite] #2659222
05/26/19 12:18 AM
05/26/19 12:18 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
This was the original carpet to a β€˜71 GTX I owned several years back. They placed one heel pad over another, must have been a defect.
Re: Factory Carpet Heel Pad 1971 GTX [Re: 70440+6bbl] #2659292
05/26/19 09:39 AM
05/26/19 09:39 AM
Thanks for the reply - can you take another picture with the pad down on the carpet the way it was when you got the carpet?
If I understand you correctly the top pad was rectangular without a cutout at the top left?
What is the build date of your car?
Re: Factory Carpet Heel Pad 1971 GTX [Re: A727Tflite] #2660440
05/29/19 07:39 PM
05/29/19 07:39 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
This is the best picture I could find of the carpet and heel pad. The SPD was C17 and built at the St.Louis plant.
Re: Factory Carpet Heel Pad 1971 GTX [Re: 70440+6bbl] #2660523
05/30/19 06:11 AM
05/30/19 06:11 AM
Thanks - same pad as mine. up
Re: Factory Carpet Heel Pad 1971 GTX [Re: A727Tflite] #2660597
05/30/19 12:05 PM
05/30/19 12:05 PM
home of the Buckeyes
Butterscotch71 Offline
Lost Title
Lost Title
The heel pad on my 71 runner (survivor) is rectangular as well. 12/8/70 scheduled production date, St Louis.
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
Re: Factory Carpet Heel Pad 1971 GTX [Re: Butterscotch71] #2662328
06/04/19 06:38 PM
06/04/19 06:38 PM
Ok, new information as of today.
Legendary tells me now that the bench seat 4 speed car gets a different heel pad than a console 4 speed car.
Can anyone pipe in on this - BS or does it have merit.
Re: Factory Carpet Heel Pad 1971 GTX [Re: A727Tflite] #2662329
06/04/19 06:42 PM
06/04/19 06:42 PM
Lost Title
Lost Title
Mine is a bench 4spd
Re: Factory Carpet Heel Pad 1971 GTX [Re: Butterscotch71] #2662333
06/04/19 07:02 PM
06/04/19 07:02 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I always thought a four speed with buckets got the "E" body pad and a 4 speed with bench got the rectangle, is this correct??
Ron
Re: Factory Carpet Heel Pad 1971 GTX [Re: RJS] #2662660
06/05/19 02:11 PM
06/05/19 02:11 PM
Canada
demon Offline
demon  Offline
Canada
Ron
That would make sense. The E body 4 speed, and B body with buckets and 4 speed used the same floor and rearward mounted shifter hump. The B body with bench seat 4 speed used the forward mounted hump, similar to the 66-70 floor, so they may have carried the earlier carpet and heel pad on. I question how well the 66-70 type carpet would fit though, since the floors were a bit different in shape. Probably not enough to be a problem though.
However, in all my automatic transmission 71-72 B bodies, they have all had the E body type heel pad with the corner notch.
Re: Factory Carpet Heel Pad 1971 GTX [Re: demon] #2662741
06/05/19 05:43 PM
06/05/19 05:43 PM
Spoke with Legendary today in fact - going to just go with the notched heel pad based on replies here and from some 71 B Body experts. My guess is it had the wrong carpet installed or they only had this carpet available.
This car appears to be built in late June β€˜71 at St. Louis, trim panels have dates of June 8, looking for other date coded items to narrow it down.
Another anomaly is it has all black seat belts, all matching date codes that have never been removed based on the condition of the anchor bolts. even though the car has blue interior.
