225/70/15 On a 15 x 8 ? #2659059
05/25/19 11:17 AM
05/25/19 11:17 AM
London, England
JFChallenger440 Offline OP
London, England
Does this fit ok on the front ? Thanks
Re: 225/70/15 On a 15 x 8 ? [Re: JFChallenger440] #2659068
05/25/19 11:56 AM
05/25/19 11:56 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
twocents NO!
most 15x8.0" wheels are ~9" wide (outside to outside of flanges)
a 225 wide wheel (in a perfect world) has a 225mm / 25.4 = 8.9" section width (widest section of tire) would be wider on a 8" rim
most 225/70/15 tires have ~6.8" of tread width
there's the narrow tire/wide wheel "concept" taken to its extreme
Re: 225/70/15 On a 15 x 8 ? [Re: 6bblgt] #2659080
05/25/19 12:28 PM
05/25/19 12:28 PM
London, England
London, England
So a 235/70/15 would be ok ?
Re: 225/70/15 On a 15 x 8 ? [Re: JFChallenger440] #2659086
05/25/19 12:40 PM
05/25/19 12:40 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
235/70/15 is pretty tall at ~28", what are you putting them on?
you already have the 15x8" wheels? what backspace?
Re: 225/70/15 On a 15 x 8 ? [Re: 6bblgt] #2659089
05/25/19 12:45 PM
05/25/19 12:45 PM
London, England
London, England
70 Satellite, 4.5" Backspace Weld Draglites
Ideally I would prefer 225/70/15 on the front but not sure if they will fit a 15 x 8 rim ?
Re: 225/70/15 On a 15 x 8 ? [Re: JFChallenger440] #2659109
05/25/19 01:48 PM
05/25/19 01:48 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
225/70/15 front,15x7 275/60/15 rear,15x8.
Re: 225/70/15 On a 15 x 8 ? [Re: JFChallenger440] #2659110
05/25/19 01:50 PM
05/25/19 01:50 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
if it were mine, I'd run 245/60/15 twocents I know you probably don't want "wide" tires on the front, but with an 8" wheel I think you are sort of "stuck"
here's a 245/60/15 on a 15x7.0" (4.0" backspace, I think) wheel on the front of a '69 Road Runner
what's your ride height? what's on the rear?
moparts 245-60-15 on 15x7 1969 RR.jpgmoparts 245-60-15 on 15x7 1969 Road Runner.jpg
