Re: Why does everyone hate the 4.7 V8?
[Re: GODSCOUNTRY340]
#2655607
05/15/19 07:38 AM
05/15/19 07:38 AM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
I cant stand ohc v8s....that said it is what it is some good some junk just like everything thease days good luck
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
[Re: moparsquid]
#2656346
05/17/19 05:42 PM
05/17/19 05:42 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
Just don't let them over heat. My grand daughter didn't realize that my Durango's plastic filler T had cracked. Kept driving until is "smoking" and "sounding funny". When the 4.7 gets too hot, the valve seats tend to drop releasing spring pressure holding the rockers in place. They go bouncing around under the valve cover wreaking all kinds of havoc.
[Re: Scott Carl]
#2656354
05/17/19 06:07 PM
05/17/19 06:07 PM
Scott Carl
Omaha, Nebraska
$500 for two used heads later and she ran like a top...................until my grandSon spun a bearing doing neutral drops. Yeah I know, I know. No grief please LOL I've learned my lesson. He's going to help me pull the engine now and put in a crank kit (at least). I'll update when we get it done. Yeah the 4.7 (and the 3.7 V6, which is very similar) has its quirks, but, as said, if well cared for, runs really nice. That being said, WIKN, I wish I'd looked for a 5.2 Durango.
[Re: savoy64]
#2656553
05/18/19 12:40 PM
05/18/19 12:40 PM
Posts: 8,668 Buford, GA
I_bleed_MOPAR
Buford, GA
4.6 ford fits right in and get better mpg and has more power----just funnin----most 4.7 failures are valve train issues in my book... Funny you should say that. I ran across an '05 1500 QC 4x4? with a 351/C6 furd in it, on FB Marketplace. Only thing I can figure out is he blew the Hemi (or 4.7 if it was still available in '05 rams) and had the furd sitting there. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
#2657611
05/21/19 03:40 PM
05/21/19 03:40 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
As long as the engine is well cared for (oil and filter changes, spark plugs as needed) it should be A-OK. BUT... let the oil changes be ignored... and the return passages gradually become clogged and restrictive... welcoming progressive oil starvation and proper flow throughout the engine. This "family" of engines shares this potential problem more-so than certain other engines.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#2657749
05/21/19 08:43 PM
05/21/19 08:43 PM
Posts: 10,563 Freeport IL USA
poorboy
Freeport IL USA
As long as the engine is well cared for (oil and filter changes, spark plugs as needed) it should be A-OK. BUT... let the oil changes be ignored... and the return passages gradually become clogged and restrictive... welcoming progressive oil starvation and proper flow throughout the engine. This "family" of engines shares this potential problem more-so than certain other engines. That almost sounds like the Mopar tag line. The reality is these motors are designed for a 150K life span, some don't make it that far, others go farther. How it was taken care of has some effect, but that doesn't change the fact the motor was designed to die at 150K. Back in the old days, that 150K was probably acceptable because most vehicles didn't make it that far, but by today's standards, 150K should be "just broken in" not "just about broke." I buy used vehicles, several of the modern Mopar motors leave a lot to be desired, this is not the "old Chrysler" for sure. I won't buy anything with the old 2.7, or anything with the 4.7 because most are on their death bed by the time they come into my price range. I really don't foresee a modern car in my future, I'll rebuild the old stuff. Gene
[Re: poorboy]
#2657798
05/21/19 10:52 PM
05/21/19 10:52 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
. The reality is these motors are designed for a 150K life span, some don't make it that far, others go farther. How it was taken care of has some effect, but that doesn't change the fact the motor was designed to die at 150K. Back in the old days, that 150K was probably acceptable because most vehicles didn't make it that far, but by today's standards, 150K should be "just broken in" not "just about broke." I had a 2002 Ram 1500 with this engine. It ran fine but was a slug. Gutless. The mileage was not great, maybe 17 freeway on flat ground. I ran it up to 163,000 miles and sold it when I bought a 2006 Ram 1500 4wd 5.7. The 2006 got better mileage and made more power! The 2002 though...Spark plug changes were easy...Straight down through the intake! They had an interesting oil filter drainage trough too....I wish the 383-440 engines had something similar!
[Re: poorboy]
#2657981
05/22/19 12:11 PM
05/22/19 12:11 PM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
As long as the engine is well cared for (oil and filter changes, spark plugs as needed) it should be A-OK. BUT... let the oil changes be ignored... and the return passages gradually become clogged and restrictive... welcoming progressive oil starvation and proper flow throughout the engine. This "family" of engines shares this potential problem more-so than certain other engines. That almost sounds like the Mopar tag line. The reality is these motors are designed for a 150K life span, some don't make it that far, others go farther. How it was taken care of has some effect, but that doesn't change the fact the motor was designed to die at 150K. Back in the old days, that 150K was probably acceptable because most vehicles didn't make it that far, but by today's standards, 150K should be "just broken in" not "just about broke." I buy used vehicles, several of the modern Mopar motors leave a lot to be desired, this is not the "old Chrysler" for sure. I won't buy anything with the old 2.7, or anything with the 4.7 because most are on their death bed by the time they come into my price range. I really don't foresee a modern car in my future, I'll rebuild the old stuff. Gene I remember reading on the hemi when it came out in the early 2000s. I learned the term "Specific Engineering." Built to last to a certain mileage and sometimes not made to be rebuilt as in not enough meat for an overbore..
Keep old mopars alive.
[Re: Mopar Mitch]
#2658000
05/22/19 01:15 PM
05/22/19 01:15 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
As long as the engine is well cared for (oil and filter changes, spark plugs as needed) it should be A-OK. BUT... let the oil changes be ignored... and the return passages gradually become clogged and restrictive... welcoming progressive oil starvation and proper flow throughout the engine. This "family" of engines shares this potential problem more-so than certain other engines. This is the 2.7 you are thinking of, they get water in the oil that makes massive amounts of sludge that plug the return passages, I have torn apart tons of 4.7s and the worst sluged ones did not have enough to plug an oil return passage.
[Re: HotRodDave]
#2658097
05/22/19 05:25 PM
05/22/19 05:25 PM
Posts: 2,512 God's Country Maryland
GODSCOUNTRY340
I was asking because my son was looking at a 2002 Dakota with a 4.7 with 160,000 miles. I suggested he look for something with a 5.2 or 5.9, he wanted a gas engine. He ended up buying this, it's an '01 2500 with a 5.9 magnum, 6 speed manual with 180,000. He needs it as a shop truck so the flatbed will work out great.
[Re: BeEtLeJuIcE !]
#2658289
05/23/19 07:38 AM
05/23/19 07:38 AM
Posts: 788 Plymouth, MI
HotRod20
Plymouth, MI
Had a Chrysler exec demo Ram 1500 with the 4.7 got rid of it at 90K miles when the lifters starting rattling at every stop light.After much research from mechanics at Dodge dealerships, I was told the oil passages and internal design of this engine was flawed from day one, but Auburn Hills decided not to drop production but let it fly. Kind of like built in failure engineering. Sell the vehicles, repair em' later...
HotRod20
