Magnum rocker arm alignment #265778
03/25/09 12:39 AM
03/25/09 12:39 AM
Mesa , Az
Jambbii Offline OP
Jambbii  Offline OP
Mesa , Az
So I am building a 360 magnum engine with edelbrock heads for my friend. This is my first time playing with one of these engines. Anyways I am having issues with the rocker arms aligning up strait with the top of the valve stem. They seem crooked but only on one cylinder head. Is it ok if I offset the guide plates a little bit by pulling the studs and ovaling out the holes?
Thanks,
Josh
70 Challenger
1960 Town Wagon P Pump 24v cummins project
06 Mega 3500 Drw 2wd
12 Durango R/T
18 Power Wagon
67 A100
Re: Magnum rocker arm alignment [Re: Jambbii] #265779
03/25/09 09:58 AM
03/25/09 09:58 AM
Caldwell. Id
E
edbux Offline
edbux  Offline
E
Caldwell. Id
Look on hughes. I remember seeing a write up on your issue in the tech section.
web page
1967 Dart 270 360/727
