pics from the weekend
#2654953
05/13/19 12:27 PM
05/13/19 12:27 PM
Posts: 13,492 Marion, South Carolina [><]
an8sec70cuda
Had a street car shootout this weekend up at Fayetteville. Lost in the semis b/c the transbrake didn't hold...rolled the beams. Thinking it was due to low voltage/weak battery. First passes on the car since freshening up the motor and trans. Ran real good (new best), but I need some more passes to get the suspension dialed in. Pulling right and wheelstanding as I get more aggressive w/ the launch. Had a great time though.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
Re: pics from the weekend
[Re: gsmopar]
#2655005
05/13/19 02:48 PM
05/13/19 02:48 PM
an8sec70cuda
It went 5.64 at 126 mph w/ a soft 1.35 sixty foot. I got after it a lil harder and did a wheelstand, had to pedal it, went 5.81 at 123 mph w/ a 1.43 sixty foot on the back tires. Slowly sneaking up on it and tightening up the shocks. Just need more test passes, but it ought to run good once I get it sorted out. Thanks yall!
[Re: an8sec70cuda]
#2655029
05/13/19 04:01 PM
05/13/19 04:01 PM
Posts: 20,272 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Very nice!!! Glad you got back out again
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
[Re: n20mstr]
#2655047
05/13/19 04:33 PM
05/13/19 04:33 PM
Posts: 8,686 Buford, GA
I_bleed_MOPAR
Buford, GA
Nice, Chip. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: 11secdart]
#2655100
05/13/19 07:01 PM
05/13/19 07:01 PM
Posts: 864 lancaster,california
johnnycuda
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: 340Cuda]
#2655294
05/14/19 10:45 AM
05/14/19 10:45 AM
Posts: 11,786 Portage,michigan
B3422W5
Portage,michigan
Always been of of my favorite cars and posters on here Nice job Chip
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: an8sec70cuda]
#2655459
05/14/19 06:12 PM
05/14/19 06:12 PM
Posts: 20,272 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Chip did you end up going with Viking rear shocks. Something went haywire on my Duster sitting from October to last weekend and it was heading left on every pass running a 6.07 and a 6.06 on my first time trail and first round. 2nd round it was so bad I got out of it. I know I need rear shocks as they are probably 20 years old and on the car when I bought it so I will check everything over tomorrow and take some shock measurements so I can update. Going to check rear tire circumference tomorrow, wheelbase measurements, and my ladderbar setting as I have two races this weekend. There is also a guy on Facebook that comes highly recommended for shocks too
