Lowering 2005 ram 2500 4X4
#2655084
05/13/19 06:19 PM
05/13/19 06:19 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
So I have an 05 hemi 2500 4x4 and hate climing in and out of it to put cylinder heads and things in and out of the bed and my pee pee is not so small that I need a truck 47 feet in the air, can I just pull those silly factory spacers out of the rear leaf spring packs to lower it an inch or two? What about the front, what is the best way to lower it a little to match?
Re: Lowering 2005 ram 2500 4X4
[Re: HotRodDave]
#2655295
05/14/19 10:47 AM
05/14/19 10:47 AM
Posts: 554 Mesa , Az
Jambbii
Mesa , Az
Yeah you can on the back. I did on my 06 3500. The front, not so sure. Might have to try a few different springs. I know there are a fair amount of diesel drag trucks that are 4wd and lowered might want to try and see what they did. You can always cut a coil out of it.
70 Challenger 1960 Town Wagon P Pump 24v cummins project 06 Mega 3500 Drw 2wd 12 Durango R/T 18 Power Wagon 67 A100
[Re: Jambbii]
#2655682
05/15/19 12:43 PM
05/15/19 12:43 PM
HotRodDave
Kalispell Mt.
No idea on the front? What about a pair from say a hemi regular cab 3/4 ton? Would they let my 4 door set just a little lower or are they the same rate and length?
[Re: Jambbii]
#2656147
05/16/19 10:45 PM
05/16/19 10:45 PM
Posts: 16,515 On the run…
BloFish
On the run…
Yeah you can on the back. I did on my 06 3500. The front, not so sure. Might have to try a few different springs. I know there are a fair amount of diesel drag trucks that are 4wd and lowered might want to try and see what they did. You can always cut a coil out of it. Can you post a pic so I can see the ride height?
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
