Re: /6 To 360 Magnum Parts and Labor Checklist [Re: sharpie] #265526
03/26/09 01:14 PM
03/26/09 01:14 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
those look to be the summit shorties that didn't work for IMGTX in his E body--IIRC in his car the collector hit the steering shaft.
I'm debating if I want to try these edelbrock 66013 headers in my 5th ave
they're slightly longer and might take care of the clearance issue IMGTX had, and they're coated stainless...the downside is they're $460, or $30 more than bare dougs headers (but $130 cheaper than the coated dougs D453's)
2017 Grand Cherokee Overland
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: patrick] #265527
03/26/09 02:01 PM
03/26/09 02:01 PM
Ontario, Canada
8
84Stepside Offline
84Stepside  Offline
Ontario, Canada
do they still make those .525 lift springs?
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: 84Stepside] #265528
03/26/09 03:34 PM
03/26/09 03:34 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
don't forget the nose extension for the camshaft
Daniel
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: Wedgeman] #265529
03/26/09 04:27 PM
03/26/09 04:27 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
Patrick, though I don't have it in the car right now, it looks like these headers will dump lower than where the steering shaft is. Only time will tell though.
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: sharpie] #265530
03/26/09 05:14 PM
03/26/09 05:14 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
im in the process of the swap right now. I used just regular old a body headers in my dart. They seem to work well, but I have not fired it up yet. I do have to reroute the power steering hose. I have manual brakes so no booster to worry about.
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: blk00rt] #265531
03/26/09 05:45 PM
03/26/09 05:45 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
yeah hooker/flowtech/tti long-tubes work fine. I was generously given the shorties for free, so I was going to try to use those.
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: sharpie] #265532
03/26/09 10:03 PM
03/26/09 10:03 PM
Gloucester,VA STOP MOVING HERE
RangerDan440 Offline OP
well I took some very rudimentary measurements and looking at the car, I think I might be able to make the truck manifolds work (remember I have manual steering and brakes so Im at an advantage for space)
Anyone ever have issues with motor mount shims?
I may be able to pull this off with only having to buy the Schumacher mounts
68 Valiant 408
69 Charger 318
69 Cougar 351W
70 Torino GT 351C
71 Country Squire 351W
71 Road Runner 440+6
71 Satellite sedan 318
73 Duster 318
73 Challenger 383
77 Grand Prix 455
83 Malibu 9C1 383
84 Delta 88 403
87 Grand National
96 Ram 360
09 Crown Vic
10 Challenger R/T M6
15 Challenger Hellcat M6
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: RangerDan440] #265533
03/26/09 11:41 PM
03/26/09 11:41 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
I just used Schumacher mounts. They come with everything you need. They mount using the LA tabs on the block. I have yet to buy my torque strap, but will be doing that from them soon as well.
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: Wedgeman] #265534
03/27/09 06:20 AM
03/27/09 06:20 AM
Oakdale CT
gdonovan Online sleepy
gdonovan  Online Sleepy
Oakdale CT
Daniel
I have the bolt & washer part of the HUG 7011 kit if anyone wants it for $19 shipped, decided to go electric.
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: Wedgeman] #265535
03/27/09 06:31 AM
03/27/09 06:31 AM
Oakdale CT
Oakdale CT
Gary,
Don't know about the Jeep ones....what would fit is a 68-70 340 style driver's side manifold, the one going upward.....you know ?
Daniel
Yes that would be best but in researching the issue there is two problems.
1) People report a port mismatch at the bottom causing an exhaust leak (either right away or when the gasket burns through due to so little meat being there)
2) Cost of the early "header" manifold.
The older manifolds are nice looking but the cost to power ratio is not there for me and dyno reports back that up.
If I can fit the 92 magnum manfolds in they go toe to toe with the 68-70 340 in regards to flow and there are no sealing issues. If I have to go with the jeep manifolds (which arrived yesterday, I'll take pics today) then at best I'll lose a few hp and live with that.
I'm too old to be changing gaskets every year, I want to assemble the car and go and make it as idiot proof (trouble free) as possible.
Great dyno shoot out on manifolds here-
http://www.moparmusclemagazine.com/techa...aust/index.html
I intend to compile a lot of information on my website so in the future there is a guide for these conversions.
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: RangerDan440] #265536
03/27/09 06:33 AM
03/27/09 06:33 AM
Oakdale CT
Oakdale CT
When I shoved a 360 in my GTX for a bit I had no problems.
I wonder where the hell that engine is now? The mind goes...
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: gdonovan] #265537
03/27/09 08:54 AM
03/27/09 08:54 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Gary,
Daniel
jeep manifolds have been discussed before and are a no-go. the jeeps move the starter to the pass side of the engine, so the drivers side jeep manifold dumps right on top of the starter in a normal LA configuration.
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: patrick] #265538
03/27/09 09:31 AM
03/27/09 09:31 AM
Oakdale CT
Oakdale CT
With both style starters?
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: gdonovan] #265539
03/27/09 05:01 PM
03/27/09 05:01 PM
Oakdale CT
Oakdale CT
Picture one manifolds- 92, 96 and 96 Jeep
Re: /6 To 360 Magnum Parts and Labor Checklist [Re: gdonovan] #265540
03/27/09 05:02 PM
03/27/09 05:02 PM
Oakdale CT
Oakdale CT
Same thing different side
