Page 2 of 3 1 2 3
Re: Spray bar valve cover [Re: Cab_Burge] #2653668
05/09/19 11:30 AM
05/09/19 11:30 AM
Sidney,Ohio
challenger1320 Offline
Sidney,Ohio
Cab they make two differant adjusters one for pushrod oiling and one for spraybar, if you have pushrod oiling the adjuster is solid so it pressure oils the rocker shaft, if you have sprayber it is hollow so oil can bleed to the rocker shaft. I don't think it is a good idea to run hollow adjusters with pushrod oiling. I would run solid adjusters and let the spraybar cool the valve springs.
Re: Spray bar valve cover [Re: challenger1320] #2653671
05/09/19 11:37 AM
05/09/19 11:37 AM
This set of Jesel rockers have no oil holes for the rocker tips or axles whiney
They came with the heads along with the spray bar covers, the ratio on the box says there 1.55 ratio shruggy
I hope to race the motor this weekend at our local 1/8 mile track with out the spray bar covers do to no provision for the vacuum pump fittings, yet whiney
I'll look at the rockers and valve springs after the first day and decide if I will run it the second day luck
Re: Spray bar valve cover [Re: Cab_Burge] #2653695
05/09/19 01:01 PM
05/09/19 01:01 PM
Sidney,Ohio
Sidney,Ohio
I hope it doesn't burn up pushrod tips. T&D told me not to run there rockers that way.
Re: Spray bar valve cover [Re: Cab_Burge] #2653696
05/09/19 01:02 PM
05/09/19 01:02 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
Kool, let us know how that setup works out
for you Cab. popcorn
Re: Spray bar valve cover [Re: Stanton] #2653800
05/09/19 06:58 PM
05/09/19 06:58 PM
New York
polyspheric Offline
polyspheric  Offline
New York
So if the pressure in is 50 psi in a .028 in3 line (3/16" ID), the pressure does NOT drop between the first and second set of holes? How about if the first hole is .028"? The line after that has the same pressure as the hole, and equal to 50% of the line in.
The delivery rate is a function of the hole area X the square root of the pressure differential.
Boffin Emeritus
Re: Spray bar valve cover [Re: polyspheric] #2653819
05/09/19 07:39 PM
05/09/19 07:39 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
I think you misunderstand what's being said here - although (my bad) I did leave out the word "combined" thinking people would be smart enough to assume that!:
" the "combined" area of the holes is equal to or smaller than the feed line they will all squirt the same amount (or pretty damn close to it)."
Re: Spray bar valve cover [Re: Stanton] #2653835
05/09/19 08:37 PM
05/09/19 08:37 PM
New York
polyspheric Offline
polyspheric  Offline
New York
You didn't understand what I wrote.
Hydraulic engineering (Archimedes) figured this out 2 millennia ago in designing aqueducts.
Boffin Emeritus
Re: Spray bar valve cover [Re: polyspheric] #2653861
05/09/19 10:34 PM
05/09/19 10:34 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
Ok smarty-pants .... just tell him what size to drill the friggin holes !!
Re: Spray bar valve cover [Re: Stanton] #2653886
05/10/19 12:10 AM
05/10/19 12:10 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Equal hydraulic pressure at all points only occurs in a closed system without leaks.
Boffin Emeritus
Re: Spray bar valve cover [Re: Stanton] #2653902
05/10/19 03:40 AM
05/10/19 03:40 AM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
Oops, ok what he said then. popcorn
Re: Spray bar valve cover [Re: polyspheric] #2653913
05/10/19 06:55 AM
05/10/19 06:55 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I remember reading a comment that in a dead-end system (line enters cover at one end) most of the oil will go to the closest valve, and that to balance out the delivery the closest holes should be smallest, but how much?
My Indy valve covers were fitted with spray bars for the Jesel rockers. Oil lines were fed into the center of the valve cover. Helps eliminate end to end pressure drop and bleed off.
Re: Spray bar valve cover [Re: polyspheric] #2653955
05/10/19 09:46 AM
05/10/19 09:46 AM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
So when you plumb an oil pressure gauge in at the rear of the block, what its really telling you is the first main bearing is getting ridiculously high pressure and the last lifter in the left bank is getting virtually none
Re: Spray bar valve cover [Re: Stanton] #2654113
05/10/19 06:38 PM
05/10/19 06:38 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
You'll need at least a dremel with a tiny collet to drill such a tiny hole.
Re: Spray bar valve cover [Re: Stanton] #2654137
05/10/19 07:41 PM
05/10/19 07:41 PM
sgcuda Offline
sgcuda  Offline
Take a look at the heating duct work in a warehouse. You will notice how the duct diameters get smaller towards the end of the run. That keeps the airflow up when exiting the vents. Liquid works the same way.
Re: Spray bar valve cover [Re: sgcuda] #2654166
05/10/19 09:13 PM
05/10/19 09:13 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
Seems to me the pressure drop inside the valve cover if any would be insignificant
in such a short distance. shruggy I'm just saying.
Re: Spray bar valve cover [Re: sgcuda] #2654168
05/10/19 09:15 PM
05/10/19 09:15 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
Quote
My lawn sprinkler system has the same size line feeding the whole system. The last sprinkler sprays just as far as the first.
Re: Spray bar valve cover [Re: Stanton] #2654169
05/10/19 09:16 PM
05/10/19 09:16 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
Quote
Agreed
Re: Spray bar valve cover [Re: Stanton] #2654191
05/10/19 10:28 PM
05/10/19 10:28 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Quote
And the holes are microscopic by comparison.
Kevin
Re: Spray bar valve cover [Re: Twostick] #2654571
05/12/19 12:15 PM
05/12/19 12:15 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Another way I've made spray bars is by using thick wall tubing. I use a paper thin Dremel cutting wheel and cut a slice into the tubing that just barely cracks through. Doing it that way makes a fan jet of oil. 1 properly position slice covered a pair of rockers.
Re: Spray bar valve cover [Re: Panty Dropper] #2654650
05/12/19 03:30 PM
05/12/19 03:30 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Originally Posted by Panty Dropper
Hey Guys,,, Just curious, but where can you purchase a set of BBM Valve covers already set up???
I am wanting to go with paired Rockers and get away from my T&D Shaft set up...]
Thanks in advance..
shock scope spank popcorn
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Page 2 of 3 1 2 3
