Re: Guys, teach me about 340 blocks
[Re: CMcAllister]
#2653633
05/09/19 10:11 AM
05/09/19 10:11 AM
Posts: 192 Gravataí, RS, Brazil
360tripleblack77
I was thinking to keep everything simple and buy a Scat 418 Forged crank, H-Bean rods and forged flat top Icon pistons to give around 11.5 / 12.0 of CR. My guess is that I can make around 650 - 680 HP on this engine since Victor Heads has a very good flow numbers.
'77 Brazilian Dodge Charger R/T - Street Car Footbrake, Pump Gas, SB Mopar 360" N/A 3300lbs, Leaf Spring + Assassin Bars Best 1/8 mile ET 1.50 60' / 4.31 330' / 6.73@102.54mph
[Re: 360tripleblack77]
#2653636
05/09/19 10:23 AM
05/09/19 10:23 AM
Posts: 52,972 Romeo MI
MR_P_BODY
You had it sonic checked.. what was the wall thickness after it was machined.. I had a wall crack even at .030 over and they sonic checked good.. it just had 1 thin area on #6cyl and it was just a tiny spot
[Re: MR_P_BODY]
#2654010
05/10/19 12:45 PM
05/10/19 12:45 PM
360tripleblack77
You had it sonic checked.. what was the wall thickness after it was machined.. I had a wall crack even at .030 over and they sonic checked good.. it just had 1 thin area on #6cyl and it was just a tiny spot Yes, was sonic checked and the thinner spot that we found is .158" on rear of cylinder 5 .
