74 Stepside
#2653007
05/07/19 02:26 PM
05/07/19 02:26 PM
Posts: 16,161 Mesa, Arizona
dart4forte
Mesa, Arizona
Back in January I came upon a Stepside for sale in Stockton, CA. Id been looking for quite some time given that Dodge short bed trucks in the Phoenix area are highly sought after. Anyway, came upon thos on CL. 74 Dodge stepside, 318 with a 4 speed conversion, 9 1/4 rear, 15x6 Steelies, bench seat etc. Anyway, started making changes and updates.
Overall the truck is mechanically sound. Brakes are good, engine runs good, has headers that need gaskets etc.
Scored a Little Red bucket seat setup which I had done. I’ve stripped the intake, fuel pump, water pump, alternator off with new parts ready to go on. Plan is to upgrade the cooling, install a Performer intake and a carter 9636, Carter fuel pump and a Powermaster 95 amp alternator. Already installed a Crackbacked HL relay setup.
The clutch appears to be pretty good however the Trans is a bit hard to downshift. It’s a 4 speedOD. As far as cosmetics, those can wait. I did score some aluminum slots which I think look good on these trucks. The front of the cab roof has some issues which I’ll address later.
Here’s a couple of pics so far
Abe Lincoln
Re: 74 Stepside
[Re: dart4forte]
#2653011
05/07/19 02:37 PM
05/07/19 02:37 PM
dart4forte
Mesa, Arizona
I plan to lower it a bit, not too crazy. Going to install the B100 van lower control arms which have a sunken spring well. I also scored a truck 8.75 with axles which I’ll do the axle flip. The front suspension is shot so with all the fresh bushings etc. in had that will be updated when Lower it.
Abe Lincoln
Re: 74 Stepside
[Re: dart4forte]
#2653014
05/07/19 02:45 PM
05/07/19 02:45 PM
dart4forte
Mesa, Arizona
Here’s the seat and interior so far. I did score some metal door panels which I’m having powder coated in a textured black. The doors were hillbilly painted black so I need to get that addressed. Doors also need hinge pins which I’ll take care of this week.
Abe Lincoln
Re: 74 Stepside
[Re: dart4forte]
#2653017
05/07/19 02:52 PM
05/07/19 02:52 PM
dart4forte
Mesa, Arizona
The engine and engine compartment had a lot of oil residue, mainly from leaky valve covers. So far the pan gasket and the rear main is not leaking. Once I button up everything I’ll give it another wash.
Much to my relief it appears the motor is a reman.the previous owner told me it had a motor replaced about a year ago. When I popped the intake I found that the lifter valley extremely clean and it appears to bea later model 318 in that it has the bosses for roller lifter spider retainers.
I checked the brakes when I put the wheels on and they are good. Just is out on that MC. The fluid really needs flushing
An AC system is in the plans for this fall. Im also pondering a GenIII conversion.
Abe Lincoln
Re: 74 Stepside
[Re: abodyjoe]
#2654365
05/11/19 03:54 PM
05/11/19 03:54 PM
dart4forte
Mesa, Arizona
As far as I know they are not being re-popped. Found mine through a truck friend of mine. I may have another pair by July. They are up in the NW along with other truck parts ill be picking up.
Abe Lincoln
Re: 74 Stepside
[Re: basketcase]
#2654366
05/11/19 03:54 PM
05/11/19 03:54 PM
dart4forte
Mesa, Arizona
very nice! Love the look of the slots...makes me want a set for mine.
I have two other sets if interested. PM me.
Abe Lincoln
Re: 74 Stepside
[Re: abodyjoe]
#2654368
05/11/19 03:57 PM
05/11/19 03:57 PM
dart4forte
Mesa, Arizona
whats the part numbers on those mirrors? i don't see them on their site.. Actually there are two part numbers. One on the base and the other on the mirror.
Abe Lincoln
Re: 74 Stepside
[Re: dart4forte]
#2654627
05/12/19 01:44 PM
05/12/19 01:44 PM
Posts: 11,081 Berlin, N.J.
abodyjoe
Berlin, N.J.
As far as I know they are not being re-popped. Found mine through a truck friend of mine. I may have another pair by July. They are up in the NW along with other truck parts ill be picking up. ok. i thought you got them from LMC
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt. www.MoparMisfits.com
Re: 74 Stepside
[Re: abodyjoe]
#2654742
05/12/19 08:05 PM
05/12/19 08:05 PM
dart4forte
Mesa, Arizona
No, got them from a buddy. Finding the actual mirror was a PITA. The posts are also hard to find as well.
Abe Lincoln
Re: 74 Stepside
[Re: dart4forte]
#2655373
05/14/19 02:41 PM
05/14/19 02:41 PM
dart4forte
Mesa, Arizona
A little update. New manifold, carb, water pump, alternator, hoses and belts. Heater box will becoming out to make way for a new aftermarket AC.
Abe Lincoln
Re: 74 Stepside
[Re: Californian]
#2662441
06/04/19 11:38 PM
06/04/19 11:38 PM
dart4forte
Mesa, Arizona
Had a little set back. Got everything running when I notice the dampner wobbling. Took everything back off and removed the dampner
Abe Lincoln
Re: 74 Stepside
[Re: dart4forte]
#2701678
09/28/19 11:20 AM
09/28/19 11:20 AM
dart4forte
Mesa, Arizona
Well, been awhile since I updated this thread so here goes. In May a buddy of mine transported my truck up to Washington to my buddies shop. There it sat in line waiting it’s turn to get the top addressed. I went up in June and got a chance to drive around.
Anyway, the lift became available two weeks ago so they went ahead and rolled it in. They decided to not wait for me to get up there next month so they went ahead and did the front end. The past two days they decided to do the axle flip. Meanwhile, while getting so other work done the fab guy skinned the roof off the diner and prepped it install on my truck.
First two pics are the results of the front end rebuild and lowering using the van lower control arm. Front sits pretty good.
Second pic is the results of the axle flip. A bit too low so I need to figure out how to raise it about two inches.
Abe Lincoln
Re: 74 Stepside
[Re: dart4forte]
#2701683
09/28/19 11:30 AM
09/28/19 11:30 AM
dart4forte
Mesa, Arizona
As you can see the top has been addressed. The original top had been repaired due to rust. We went back and forth on how to make the repair. We looked at patching it but that would of taken too much time.
Abe Lincoln
Re: 74 Stepside
[Re: dart4forte]
#2701686
09/28/19 11:38 AM
09/28/19 11:38 AM
dart4forte
Mesa, Arizona
My buddy has a parts truck so he went ahead and skinned the top off of it. I’ll be taking a clean cab up to him to replace the cab he used for my truck.
Once the top was off my truck it was apparent the rot was confined to the front. Kinda odd since it’s a central California truck so rot in that area is unusual. We think water somehow got in and eventually pooled in the front. Since it will be now kept in Arizona that shouldn’t ever be a problem again.
We used raptor as a rust preventative
Abe Lincoln
