Re: Electrical Gremlin 69 Charger R/T [Re: RapidRobert] #2652976
05/07/19 01:17 PM
05/07/19 01:17 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
The firewall side (not being replaced) side has the female terminals.
The terminals, if needing replacement, are closest to Packard 58 not 56, in most of the cars I've looked at (late 60s). Some call these Ford/Chrsyler terminals.
https://www.repairconnector.com/products/Universal-GM-Chrysler-Ford-Female-Terminal-Connector-20%252d18-AWG.html
https://www.repairconnector.com/uni...ale-terminal-connector-14-12-awg-5-pack/
http://www.texasindustrialelectric.com/_packard_terminals.asp
https://www.mouser.com/Aptiv/Automotive-Connectors/Series-58/_/N-1z0zlezZ1ehb5Z1y9jlfy
https://picocanada.com/en/products/181 (canada)
Get a proper crimper for "open barrel" terminals. Astro-pneumatics is cheap and has interchangable jaws. However the jaws are too wide to fit on OEM and some aftermarket male terminals. The packard crimpers and copies are good but often expensive. American Wire sells and rents these crimpers.
Save the original harness. Its useful for reference and parts.
When the replacement harness on my 67 started to show some issues, I had to replace a few terminals. Some were packard 56. The original harness was 58. So I used the 58, but then the 56 connector was loose. Fortunately I could take the original connector from the original harness and all was good. Small differences, but sometimes important.
Re: Electrical Gremlin 69 Charger R/T [Re: Mattax] #2652983
05/07/19 01:34 PM
05/07/19 01:34 PM
Mattax good info
Re: Electrical Gremlin 69 Charger R/T [Re: mymcodebee] #2653018
05/07/19 02:52 PM
05/07/19 02:52 PM
Andrewh Online content
Andrewh  Online Content
I don't know if anyone answered, the circuit breaker is in the driver side kick panel.
while wiring might be causing some issues, you could probably wait for them to shut off and then try tracing back the wiring till you find voltage again.
that might help you narrow down the "bad" part to start with.
Do the high beams work when this happens?
Re: Electrical Gremlin 69 Charger R/T [Re: Andrewh] #2653240
05/08/19 01:31 AM
05/08/19 01:31 AM
Far Northeast.
mymcodebee Offline OP
Far Northeast.
No, high beams were on when I witnessed it.
Re: Electrical Gremlin 69 Charger R/T [Re: mymcodebee] #2653271
05/08/19 07:21 AM
05/08/19 07:21 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Makes it sound even more like a breaker problem, whether in headlight switch or elsewhere located.
Re: Electrical Gremlin 69 Charger R/T [Re: Andrewh] #2653594
05/09/19 08:08 AM
05/09/19 08:08 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
shake_head
An overload can not be traced by looking for voltage after a fuse has blown or a breaker opened.
Fuses open when there is too much current running through them.
This only happens when there is something drawing too much current, or a shorter path to ground downstream of the fuse.
And lets see this headlight breaker somewhere other than in the headlight switch for 69 Dodge Plymouth or Chrysler.
Re: Electrical Gremlin 69 Charger R/T [Re: Mattax] #2653788
05/09/19 06:01 PM
05/09/19 06:01 PM
that is true, but you can tell where to start looking by tracing voltage.
if it stops at the switch, or if it stops at the breaker, you know it has to be down stream.
and can eliminate something from your search.
