Re: pulsating driveline vibration?
[Re: A727Tflite]
#2653362
05/08/19 11:29 AM
05/08/19 11:29 AM
RapidRobert
^^^ Sounds like a plan. when the time comes be sure & post the outcome.
[Re: buildanother]
#2653592
05/09/19 07:56 AM
05/09/19 07:56 AM
Posts: 2,863 middle Tennessee
mopower440
middle Tennessee
so, has the "C" clips situation been addressed? all 8 installed on shaft joints? You mean have they fallen off?
[Re: buildanother]
#2653675
05/09/19 11:44 AM
05/09/19 11:44 AM
mopower440
middle Tennessee
Installed they usually do not fall off, but some installers have failed to install them. Seriously? wonder why? you would think they wouldnt get far before it all fell apart without the clips..
[Re: burdar]
#2653686
05/09/19 12:26 PM
05/09/19 12:26 PM
mopower440
middle Tennessee
At some point, the factory started adding a big weight to the back of the tail shaft. I think there was one on an 82 Cordoba I used to own. I always assumed the weight was to eliminate some unwanted harmonics. It would be interesting to see what would happen if you bolted one of those onto the tail shaft. I just cant figure out why its been fine the last 20 something years and all the sudden its got this vibration out of no where..
[Re: burdar]
#2653718
05/09/19 02:20 PM
05/09/19 02:20 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
At some point, the factory started adding a big weight to the back of the tail shaft. I think there was one on an 82 Cordoba I used to own. I always assumed the weight was to eliminate some unwanted harmonics. It would be interesting to see what would happen if you bolted one of those onto the tail shaft. on 70s I have one of those ready to be installed on my car. There are two kinds of those thought
[Re: mopars4ever]
#2654180
05/10/19 09:53 PM
05/10/19 09:53 PM
mopower440
middle Tennessee
My mysterious pulsating drive line vibration was from a cracked flex plate. Took me forever to figure it out. Can you describe how it felt?
[Re: mopars4ever]
#2654184
05/10/19 10:05 PM
05/10/19 10:05 PM
mopower440
middle Tennessee
worse around 50 mph and up. it made pulsating vibration. i found it when I pulled the trans and noticed the cracked flex plate. did it do it in neutral also? Did it rumble the whole car when it did it?
[Re: mopower440]
#2654369
05/11/19 03:58 PM
05/11/19 03:58 PM
mopower440
middle Tennessee
Well, this may not be as bad as i thought..as i said, i changed the trans mount and with it set up on jack stands, it still did it. ok, i decided to take it out for a ride and the first thing i noticed is that unless im REALLY looking for it, i didnt notice it..After driving around for an hour, im starting to think it has always been like this, but i didnt really notice it until the trans mount let go and then it was REALLY noticeable! Now, with the new mount, i really cant hear it like i was and can feel it just a little but really have to be looking for it.. I still need to figure it out but im not as worried as i was because i do believe its back to normal.
[Re: mopower440]
#2654585
05/12/19 12:41 PM
05/12/19 12:41 PM
NachoRT74
Valencia, España
The vibration could made the mount failure! So it could be not fixed but absorved
[Re: mopower440]
#2654618
05/12/19 01:31 PM
05/12/19 01:31 PM
Posts: 19,405 north of coder
moparx
Today i pulled the driveshaft back out and fired it up on the jackstands and ran it again..It did NOT do the pulsating/phasing vibration with the driveshaft removed! I checked the shaft and u-joints over again and reinstalled it....... so, if it DIDN'T pulsate without the shaft, the question comes up in my feeble mind, who balanced it, and was the shaft high speed balanced ? [higher than the normal truck shaft builder] if you mentioned before this answer, i apologize for not remembering. glad you discovered the broken mount.
[Re: moparx]
#2654621
05/12/19 01:34 PM
05/12/19 01:34 PM
RapidRobert
& on that note I remember a somewhat prior post that alot of shops dont balance for high RPM (which is something I did not know), I had assumed if it was "balanced" that it was balanced (& all good).
