Page 4 of 7 1 2 3 4 5 6 7
Re: Winter update for the Coronet [Re: AndyF] #2650963
05/01/19 04:43 PM
05/01/19 04:43 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Are you going to do one of the popular electric power steering pumps or stick with an engine driven pump?
68 Barracuda Formula S 340
Re: Winter update for the Coronet [Re: Bad340fish] #2650965
05/01/19 04:50 PM
05/01/19 04:50 PM
AndyF Offline OP
AndyF  Offline OP
I'm not brave enough to switch to electric steering just yet. My plan at the moment is to use a Corvette type of PS pump. I do not have it all figured out yet. I tried to make a Saginaw pump work but ran into clearance issues.
Re: Winter update for the Coronet [Re: AndyF] #2650966
05/01/19 04:51 PM
05/01/19 04:51 PM
AndyF Offline OP
AndyF  Offline OP
The Covette PS pump looks something like this.
Re: Winter update for the Coronet [Re: AndyF] #2651023
05/01/19 07:25 PM
05/01/19 07:25 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I went with the smaller pump also.
Re: Winter update for the Coronet [Re: CSK] #2651214
05/02/19 01:01 PM
05/02/19 01:01 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Power steering is cool for a big/wide front tire, manual trans street application.
Where you're one-handing it often and the tires fight you that much more.
Makes it easy to just throw around in parking lots and so on.
My GTX is originally 4 speed power steering, only reason I went to MS
was weight/a little easier with the headers/the pitman seal was leaking anyway.
Put on one of those B-Van adapters, thinking how simple it'd be to go back to PS someday later on.
Rich H.
Esse Quam Videri
Re: Winter update for the Coronet [Re: ZIPPY] #2651243
05/02/19 02:22 PM
05/02/19 02:22 PM
AndyF Offline OP
AndyF  Offline OP
Yeah trying to steer one handed around a corner while I'm shifting the transmission is what gets me. PS should make that a whole bunch easier. It was also a bit of a wrestling match at really slow speeds in a parking lot or parallel parking. I have the 20:1 manual box. I tried the 16:1 manual box a few years back and it was almost impossible to drive at slow speeds.
Re: Winter update for the Coronet [Re: AndyF] #2651253
05/02/19 03:02 PM
05/02/19 03:02 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
10 years ago you’re dumping all the unnecessary heavy conveniences, and now you want it all back! Yep, definitely wussified! grin
Yeah, I’m softening up too.
2 kids and a dog
Re: Winter update for the Coronet [Re: TonyS451] #2651286
05/02/19 04:36 PM
05/02/19 04:36 PM
AndyF Offline OP
AndyF  Offline OP
The Borgenson PS box is quite a bit lighter than a factory PS box. I tried to move a couple of factory PS boxes the other day and just about busted something. Those boys are heavy. The Borgenson box is only 24 lbs which is heavier than a manual box but isn't terrible. The PS pump weighs a few more pounds so I'm probably adding 20 lbs to the front end with the swap. I did pull the cast iron manifolds off this time around and replaced them with tri-y headers so I'm guessing that the total weight will be roughly the same. I swapped the heavy 11 inch rear drum brakes for disc brakes last year and that saved me some weight. I'm also in the process of removing the entire center gauge panel which was fairly heavy. I don't need it anymore now that I have the digital dash installed. So I might actually be dropping weight when everything is totaled up.
Re: Winter update for the Coronet [Re: AndyF] #2651312
05/02/19 06:12 PM
05/02/19 06:12 PM
Cottage Grove OR
WFO Offline
WFO  Offline
Cottage Grove OR
Hey Andy is there a write-up somewhere for that PS pump swap? Or are you making it up as you go?
'65 Plymouth Sport Fury
Blow thru twin turbo coming soon...
Re: Winter update for the Coronet [Re: WFO] #2651338
05/02/19 07:46 PM
05/02/19 07:46 PM
AndyF Offline OP
AndyF  Offline OP
I'm making it up as I go. I've tracked down a pump, pulley and bracket so far but I still need to figure out hoses and fittings. I'll post pictures on here as I figure it out. The Borgenson swap is interesting. Obviously I'm not the first guy to do this swap since people have been doing it for a few years now, but it isn't exactly a bolt on setup. Bergman Auto Craft has a few parts to make the swap easier so that is a good start but in my case I needed to go with the Type II pump and he didn't have the brackets for it.
http://www.bergmanautocraft.com/products.php?cat=1
Re: Winter update for the Coronet [Re: AndyF] #2651366
05/02/19 09:21 PM
05/02/19 09:21 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Where did you find the brackets? That pump and bracket looks very neat and tidy.
Kevin
Re: Winter update for the Coronet [Re: AndyF] #2651428
05/03/19 12:14 AM
05/03/19 12:14 AM
Cottage Grove OR
WFO Offline
WFO  Offline
Cottage Grove OR
Is that Bergman bracket designed for the stock style pump? I don't know if I'm going to get in to replacing my steering box but I've always hated my huge leaky stock pump. It would be nice to just modify my stock bracket. I'm going to build new brackets to swap on a high amp GM one wire alternator that I had built for my Grand National before I swapped on the later serpentine stuff.
Do you have a part # for that Corvette pump?
Re: Winter update for the Coronet [Re: Twostick] #2651529
05/03/19 11:19 AM
05/03/19 11:19 AM
AndyF Offline OP
AndyF  Offline OP
I ordered a bracket kit from Unisteer. Just about everybody and their brother sells a Type II pump so they are super easy to find. You can get cheap ones on ebay and Amazon or you can buy super expensive circle track pumps from KRC. I went middle of the road and bought a pump from Detroit Speed. I don't think I needed to spend that much money but this is my first rodeo and so I went with a vendor who I trust. Next time around I might just buy a cheap pump from Rock Auto and bolt it in.
Re: Winter update for the Coronet [Re: WFO] #2651532
05/03/19 11:21 AM
05/03/19 11:21 AM
AndyF Offline OP
AndyF  Offline OP
The Bergman bracket is really just the Hoffman's Winners Circle bracket which you can get from most anybody so nothing magic there. If you don't have the correct bracket for a Saginaw pump then you can get that one. I did learn that Saginaw pumps are cheap to rebuild. The rebuild kits are only $10 but it does require some tools to take them apart and put them back together. You can get rebuilt Saginaw pumps for $30 on Rock Auto. What killed the Saginaw pump for me was that I didn't have any room for the pressure line fitting. So that forced me to switch to the Type II pump.
Re: Winter update for the Coronet [Re: AndyF] #2651535
05/03/19 11:28 AM
05/03/19 11:28 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I like that power steering setup Andy. Looking forward to a writeup on it.
69 GTX 68 Road Runner
Re: Winter update for the Coronet [Re: AndyF] #2651772
05/03/19 11:36 PM
05/03/19 11:36 PM
AndyF Offline OP
AndyF  Offline OP
I'm making some progress on the motor mounts. Mostly I've figured out what won't work so I'll count that as progress. I have a fixture to hold the engine in the correct location while I bend up different shapes. The Borgeson PS box is in place and it seems to fit okay. I'm not so sure I like the angle that Borgeson puts these boxes at, it looks odd and it will force the couple to flex a few degrees every time the steering wheel is turned but I guess they designed it that way for a reason. I did have to trim one of the motor mount lugs on the block to clear the steering box but that didn't take too much time. The headers appear to clear the PS box by a fair amount. I did get the entire steering column rebuilt and rewired so it should be good to go. Also got new gaskets and seals for everything involved.
Re: Winter update for the Coronet [Re: AndyF] #2651834
05/04/19 10:49 AM
05/04/19 10:49 AM
moparx Offline
moparx  Offline
andy, i like your removable core support bracketry. up i will be doing the same to my charger.
beer
Re: Winter update for the Coronet [Re: AndyF] #2651862
05/04/19 12:04 PM
05/04/19 12:04 PM
fullmetaljacket Offline
Andy.
Would you consider that removable rad core brace strong as a bolted in part as apposed to the factory welded in one piece?
Re: Winter update for the Coronet [Re: fullmetaljacket] #2651875
05/04/19 12:25 PM
05/04/19 12:25 PM
AndyF Offline OP
AndyF  Offline OP
Originally Posted by fullmetaljacket
Andy.
I'm sure the bolt in design gives up some strength but I can pull the engine and trans with the shifter linkage still attached to the trans in just a few minutes. With the stock core support in place it gets very, very difficult to wiggle the whole assembly out of there, especially with a deep oil pan. I can gain the strength back in other places so that doesn't worry me. I prefer to be able to slide the engine in and out quickly since I'm constantly working on this car.
Re: Winter update for the Coronet [Re: AndyF] #2651928
05/04/19 03:50 PM
05/04/19 03:50 PM
Why are you using the C and A body BB driver side motor mounts?
