Efi pump setup to feed carb? My plan
#2651568
05/03/19 01:23 PM
05/03/19 01:23 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I am putting a 66 Mustang fuel tank in my 65 Dart. Tank is from Spectre, has a 255 ltr rating, is in tank. My plan is to run a log type return regulator (made by Moroso) very close to the tank, set at 15 psi. Close to the carb i will have a holley regulater set at 7 psi. I plan to run 3/8 line from tank to pump, bypass back to tank, and up to the holley regulator. The 3/8 line is feeding my 408 just fine , but the electric pump is noisy. If there is a flaw in my plan, please discribe.
Re: Efi pump setup to feed carb? My plan
[Re: moparx]
#2651865
05/04/19 12:13 PM
05/04/19 12:13 PM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
There are low pressure for carbs & high pressure ones for EFI. I have the QF return for a carb on my set up, DO NOT get one with a bypass jet inside, that is for mechanical pumps with a return.
[Re: AndyF]
#2651873
05/04/19 12:23 PM
05/04/19 12:23 PM
CSK
Pattison Texas
Thats cool, I see it has 2 different springs,
[Re: CSK]
#2651876
05/04/19 12:25 PM
05/04/19 12:25 PM
CSK
Pattison Texas
[Re: moparx]
#2652285
05/05/19 02:50 PM
05/05/19 02:50 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
For a return line IIRC the 440 6 pack steel fuel filter had a small 3rd nipple for a return line.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
