Re: Small Block Oil Pump Gasket [Re: John_Kunkel] #2652049
05/04/19 11:45 PM
05/04/19 11:45 PM
Washington
madscientist Offline
Washington
Originally Posted by John_Kunkel
Originally Posted by madscientist
[quote=Kindafast] I've taken apart more than my fair share of engines that had never been touched and almost every one of them had a gasket. Never had a blowout.
And yet I find no part number for a gasket and no mention of one in service manuals. Last mention of a gasket between the pump and cap was in the fifties and it was a lathe cut O ring.
Don't know what to say. The first engine I pulled apart was mine. I was the second owner. First owner never touched it. It was an early 72 Demon. Has 2.02 valve and 10.5:1 Pistons. And it had a gasket under the pump. That was just the first one.
Re: Small Block Oil Pump Gasket [Re: madscientist] #2652284
05/05/19 02:48 PM
05/05/19 02:48 PM
Washington
skrews Offline
skrews  Offline
Washington
I've pulled apart many untouched cores over the years and none of them had an oil pump gasket. 318s a few 340s and a bunch of 360s. Only time I find them is when the engine has been in to.
Re: Small Block Oil Pump Gasket [Re: skrews] #2652332
05/05/19 05:37 PM
05/05/19 05:37 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I don't use them, never had any issues. Years ago I had an all original 72 340 Duster, I knew both previous owners and it had never been apart. When I rebuilt it there was no gasket on the oil pump.
Re: Small Block Oil Pump Gasket [Re: justinp61] #2652560
05/06/19 11:29 AM
05/06/19 11:29 AM
Washington
Washington
Guess I should have taken pictures.
Re: Small Block Oil Pump Gasket [Re: madscientist] #2660054
05/28/19 03:29 PM
05/28/19 03:29 PM
Washington
skrews Offline
skrews  Offline
Washington
Pulled apart an untouched 60,000 mile 318 yesterday. No oil pump gasket found.
Re: Small Block Oil Pump Gasket [Re: skrews] #2660096
05/28/19 05:42 PM
05/28/19 05:42 PM
Cab_Burge Online work
Cab_Burge  Online Work
I wonder who put the sealer on both the block and pump mounting surfaces? work whistling
Re: Small Block Oil Pump Gasket [Re: Cab_Burge] #2660198
05/28/19 11:45 PM
05/28/19 11:45 PM
Washington
skrews Offline
skrews  Offline
Washington
Theres no sealer on this motor, just machine marks.
Re: Small Block Oil Pump Gasket [Re: skrews] #2660209
05/29/19 02:54 AM
05/29/19 02:54 AM
Are you saying the goop built up around the front oil pump bolt on the pump and block and in the machine marks on both parts is not a gasket sealer or "sealing goop" of some type?
