Page 3 of 3 1 2 3
Re: Tranny fluid dilemma. [Re: stumpy] #2651269
05/02/19 03:40 PM
05/02/19 03:40 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Originally Posted by stumpy
Originally Posted by Supercuda
Only time I ever put type F in a 727 was years ago. I had a push button 727 in my 64 300. Decided to do a band adjustment and fluid and filter change. Reading the DC books lead me to think putting in type F might be an improvement. Drained out the whatever was in it, did my band adjustments put in a new filter, filled it up with type F. Two days later it's slipping and all the friction material came off the clutches.
Coincidence?
I don't think so and the cost of even a DIY rebuild is more than I care to spend to retest the type F experiment.
Wasn't the fault of the fluid.Type F has been a mainstay in the older Mopars since the 60s.
Bought a 65 Chrysler for a winter beater sometime in the early 70's. Tranny slipped a little. Replaced the filter and put type F in it. Drove it all winter and sold it come spring. Never slipped a bit with the type F.
Re: Tranny fluid dilemma. [Re: stumpy] #2651274
05/02/19 03:59 PM
05/02/19 03:59 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Coincidence?
People keep saying that but it still happened.
Anyone willing to put up the cost of a rebuild for the OP if he goes the type F route and the trans fails?
I'm not.
Don't be the exception.
Re: Tranny fluid dilemma. [Re: John Brown] #2651275
05/02/19 04:08 PM
05/02/19 04:08 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
I normally use Type F in all my 727 and 904 applications.
I have however used TSC universal hydraulic fluid in one of my 727's. It was a beater car and my trans cooler line broke and its all I had on hand. This was a transmission that had been, and was continually beat on. The universal fluid worked perfect for the next 5 years. I then sold the car to a gentleman that pulled the motor and trans and dropped it into his 3/4 ton work van, and he drove it without incident for the next 6 years before he sold it. That van might still be going strong.
I dont think the 727 is concerned about using a specific fluid.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Tranny fluid dilemma. [Re: Supercuda] #2651284
05/02/19 04:31 PM
05/02/19 04:31 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Coincidence?
People keep saying that because it's true.shruggy
I'm not.
Re: Tranny fluid dilemma. [Re: Supercuda] #2651285
05/02/19 04:33 PM
05/02/19 04:33 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Coincidence?
I'm not.
People keep saying that because it's true. I have built a couple of hundred transmissions in my time. So it's not like I'm guessing at this. shruggy
Re: Tranny fluid dilemma. [Re: stumpy] #2651536
05/03/19 11:34 AM
05/03/19 11:34 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Once again, this thread illustrates the value or not of anecdotal experiences.
Re: Tranny fluid dilemma. [Re: John_Kunkel] #2651713
05/03/19 08:12 PM
05/03/19 08:12 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Engine oil
Blondes , Brunettes or Red Heads
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Tranny fluid dilemma. [Re: BlueRacer69] #2651727
05/03/19 08:48 PM
05/03/19 08:48 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Walmart house brand Dex/Merc HERE was my choice of fluid when I still had older stuff that used it.
Re: Tranny fluid dilemma. [Re: John_Kunkel] #2651796
05/04/19 08:15 AM
05/04/19 08:15 AM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
And it's like the proverbial train wreck, you can't help but look. laugh2 laugh2
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Tranny fluid dilemma. [Re: I_bleed_MOPAR] #2651842
05/04/19 11:11 AM
05/04/19 11:11 AM
Chicago
PurpleBeeper Offline
Chicago
Ok, it's a dog-pile so I'll jump in. I've always believed you shouldn't mix transmission fluids. I believe that a blend of type F + at least the older Dextron would cause foaming.
Side note - Someone could run [u][/u]completely type F if you drained the converter and everything + type F has a little higher friction to help older transmission shift better & drag cars to shift harder + I think B&M's "Quick Shift" stuff is type F with blue dye.
To the original poster, a very reputable transmission shop owners showed me a technical bulletin from Shell Oil. It said that if you hadn't changed your transmission fluid in a long, long time, you should only replace the pan's fluid (maybe half the fluid?) + filter and don't flush the system or do a complete fluid change.
Fluid changes over time and it's solubility changes. Waxes come out of the fluid and start to collect in the transmission which isn't much of a problem with the old fluid in there, but if you put 100% new fluid in the transmission, all these waxes will really come out of solution and start to gum up the small passages inside the transmission. Keeping a good portion of the old fluid in the transmission helps keep these waxes dissolved in the transmission fluid where they do no harm.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Tranny fluid dilemma. [Re: PurpleBeeper] #2651943
05/04/19 04:31 PM
05/04/19 04:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
All ATF's have foam inhibitors so I ain't buying the foaming from mixing.
The fluid change danger in high-mile transmissions is an ongoing debate and, again, anecdotal experience varies. Some believe that a fresh additive package will dislodge varnish buildup and cause problems while some believe that the abrasive nature of aged fluid prevents clutch/band slippage and fresh fluid, being slipperier, will cause slippage.
Page 3 of 3 1 2 3
