BB vacuum pump kit choice?
#2649078
04/25/19 10:48 PM
04/25/19 10:48 PM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
Which kit would you recommend, price and quality concerned. And which not?
Plynouth VIP '67 TT IC EFI
Re: BB vacuum pump kit choice?
[Re: racerhog]
#2649544
04/27/19 01:19 PM
04/27/19 01:19 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
I have a used enhanced GZ on the race car now, it didn't pull much vacuum ,5.0 or less : on the old motor I have both a 3 and 4 vane used Moroso pumps that I will try this year on the new motor that is built for a vacuum pump, I'll post my results as they happen
[Re: Cab_Burge]
#2649744
04/28/19 06:54 AM
04/28/19 06:54 AM
Posts: 2,924 A shed in England
Tig
A shed in England
I have a Moroso 4 Vane enhanced, pulls 7 in/hg at idle and 12 over 3000rpm though after some research I may set it to pull a little more.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: dvw]
#2650184
04/29/19 12:11 PM
04/29/19 12:11 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
I have the 4 vane Moroso on the hemi in the cuda and an older 3 vane Moroso on the Camaro and they work great. I used to run an Aerospace Components pump and it was complete JUNK.
Heard nothing but good things about the GZ and Star pumps.
[Re: an8sec70cuda]
#2650187
04/29/19 12:17 PM
04/29/19 12:17 PM
Posts: 19,373 Las Vegas
Al_Alguire
Las Vegas
Moroso 3 Vane on the dragster pulls 10 at idle and 14 down track, no regulator. My car has an enhanced 4 vane and pulls 10 or so at idle and 17-18 top end, not regulated. My experience sealing the engine is the key.
[Re: Al_Alguire]
#2650235
04/29/19 02:28 PM
04/29/19 02:28 PM
Posts: 9,848 MI, usa
dvw
MI, usa
Moroso 3 Vane on the dragster pulls 10 at idle and 14 down track, no regulator. My car has an enhanced 4 vane and pulls 10 or so at idle and 17-18 top end, not regulated. My experience sealing the engine is the key. Al do you install the rear main seal backward? Doug
[Re: Biginchmopar]
#2650505
04/30/19 11:56 AM
04/30/19 11:56 AM
Al_Alguire
Las Vegas
Doug, no my rear main seal is in the standard direction. I don't use a regulator on any of my stuff, just never been able to pull enough vacuum to worry about it.
[Re: Al_Alguire]
#2651340
05/02/19 07:48 PM
05/02/19 07:48 PM
Posts: 474 Alberta, Canada
451Guy
Alberta, Canada
I have a Star. I believed the hype and bought what I thought was the best option even though it was way more expensive than the others. I also bought the fancy separated catch can. Now to be fair my motor is not optimized for a vaccum pump but I get next to no vaccumm. I have the releif valve screwed in all the way and get 0 at idle and maybe 3 pounds going down the track. Plus as an added bonus it will fill up the puke tank and then spray oil all over my engine bay including my ceramic coated fenderwell headers. It is now collecting dust under my work bench and the old school pan evacs went back on! Now in fairness to Star my buddy has one on his Pontiac and thinks its the cats meow!!!!!
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T Best ET 11.39 @ 118.11
[Re: 451Guy]
#2651349
05/02/19 08:05 PM
05/02/19 08:05 PM
dvw
MI, usa
I have a Star. I believed the hype and bought what I thought was the best option even though it was way more expensive than the others. I also bought the fancy separated catch can. Now to be fair my motor is not optimized for a vaccum pump but I get next to no vaccumm. I have the releif valve screwed in all the way and get 0 at idle and maybe 3 pounds going down the track. Plus as an added bonus it will fill up the puke tank and then spray oil all over my engine bay including my ceramic coated fenderwell headers. It is now collecting dust under my work bench and the old school pan evacs went back on! Now in fairness to Star my buddy has one on his Pontiac and thinks its the cats meow!!!!! You are pulling air in somewhere. That will fill the tank, unless your pick up point is in liquid. Fab an adapter and put 3-4 psi in the crankcase. Then spray the motor with soapy water solution. My bet is you'll see bubbles. Doug
[Re: dvw]
#2651614
05/03/19 03:31 PM
05/03/19 03:31 PM
451Guy
Alberta, Canada
Hey Doug!
Thank you for the advice. I was thinking the exact same thing. The pick up is in the front of the driver side valve cover. It is the fitting that star provides with the kit. The opening is currently facing down. I was thinking about facing it up and then retrying it.
With regards to pressuring up the motor. I actually put a valve stem in my valve cover for that exact purpose. However, when I checked it last I pulled the motor out of the car and I borrowed my buddies smoker. When we smoked it the smoke was coming out of the rear main seal area. I pulled the pan and redid the side seals and coated it with silicone. It still leaked a little around the seal but it was better. I was hoping when it was running it would seal a little better. But now that you mention it it took a while after doing that to fill the puke tank the first time. I bet a new leak has sprung up. I guess I have a little work to do.
Thanx 451 Guy
[Re: 451Guy]
#2651620
05/03/19 03:50 PM
05/03/19 03:50 PM
Posts: 4,684 On the parachute mount
n20mstr
Hey Doug!
With regards to pressuring up the motor. I actually put a valve stem in my valve cover for that exact purpose. However, when I checked it last I pulled the motor out of the car and I borrowed my buddies smoker. When we smoked it the smoke was coming out of the rear main seal area. I pulled the pan and redid the side seals and coated it with silicone. It still leaked a little around the seal but it was better. I was hoping when it was running it would seal a little better. But now that you mention it it took a while after doing that to fill the puke tank the first time. I bet a new leak has sprung up. I guess I have a little work to do. another area to leak on a big block is the stock timing cover crank seal. IF you notice all the big blocks in this thread that pull over 10" have a jesel belt drive. That has a way better crank seal than the stock type. There are better crank seals to buy though. Also with the Star pump, they don't like ANY oil in them. Try brake cleaning your pump by spraying brake clean into it while the engine is idling. Call Star, they are helpful too and will walk you through what your doing wrong. They are some of the best vac pumps out there
....BAD A$$ STREET CAR.....
