Sp2p vs performer intake for small block? #2648311
04/23/19 11:05 PM
04/23/19 11:05 PM
woodcrest, CA
magnum440d100 Offline OP
woodcrest, CA
I have a 1968 d200 with a 1970 318. It currently has the sp2p on it.
20 years ago, when it was put on, it was discovered that it had a crack that caused an oil leak (what I was told from the previous owner) and was fixed via epoxy. I have not seen nor investigated past that statement. He is a good friend of mine, so I’ll take his word.
The motor has 30k miles on a rebuild, but it is a grease ball. It was driven the 30k miles, then parked because the owner (my friends nephew) passed away from cancer. Maybe 5 years on that rebuild...
So I assume that the intake has been leaking the whole time it was driven.
I have a performer intake that I “could” borrow from a spare motor.
Between the 2 intakes, which one is more favorable? I’m not going all out power, just a nice cruiser, and Home Depot duty. I would like more fuel mileage if anything. I’ll be running a 600 cfm carb on either intake.
So... fix sp2p or swap performer?
Re: Sp2p vs performer intake for small block? [Re: magnum440d100] #2648320
04/23/19 11:54 PM
04/23/19 11:54 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The SP2P is a real turd. The ports are smaller than a stock 2 barrel intake. You could drop a peanut down the carburetor and block 60% of the airflow in whichever port it went down.
The Performer 318/360 has ports similar to a stock iron 4 barrel intake. The main advantage it has is the reduced weight. It is a better choice than the SP2P by a mile though.
Re: Sp2p vs performer intake for small block? [Re: Kern Dog] #2648322
04/23/19 11:59 PM
04/23/19 11:59 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
The SP2P is strictly for mileage. As franky said, the ports are REALLY small. Pinch off your nose, cover your mouth, and RUN. That's basically what an SP2P does to your engine.
John
Re: Sp2p vs performer intake for small block? [Re: SattyNoCar] #2648323
04/24/19 12:18 AM
04/24/19 12:18 AM
Shopping @ HoBo Fright
340SIX Online content
Doc Flappergas's Evil Twin
340SIX  Online Content
The old performer I had looked like my 1972 340 intake.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Sp2p vs performer intake for small block? [Re: 340SIX] #2648382
04/24/19 09:39 AM
04/24/19 09:39 AM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
The performer has 318 sized ports and is ideal for that engine. If you had a 340 or 360 you would probably want to gasket match and blend a bit but it will bolt on and work fine as-is. The performer is also one of the few aftermarket intakes that will allow you to bolt up a factory AC compressor in the stock location.
Re: Sp2p vs performer intake for small block? [Re: Montclaire] #2648389
04/24/19 09:46 AM
04/24/19 09:46 AM
That is 100 percent why I used one on my old 340. A/C and easy to port is was almost like the 340 one night wise etc.
Was a better to choosecthag than others.
Re: Sp2p vs performer intake for small block? [Re: 340SIX] #2648391
04/24/19 09:52 AM
04/24/19 09:52 AM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Other than a few extra pounds, the factory 340 intake is within 15 hp or so of the performer, basically apples to apples. If you have the cast iron don't be afraid to run it.
Re: Sp2p vs performer intake for small block? [Re: Montclaire] #2648398
04/24/19 10:07 AM
04/24/19 10:07 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Quote
Boom!!!! There it is.
Truer words have never been said.
I’d run a stock 2bbl intake and carb before I put on one of those.
And their “greatness” isn’t limited to SB mopars either.
They suck on everything.
Friend of mine has a 68 Camaro ss 396.
One of the local 396 gurus gave him a recipe for a 400hp hot street build.
9.5cr, comp 280h magnum cam, Ede 750 carb..... sp2p...... no headers.
He wasn’t to impressed with it, and after taking it for a test ride I could see why.
It was absolutely “done”(and wheezing) at 4500.
It really didn’t do anything particularly well. No great throttle response....... it was just a straight up dud.
I tried a Holley on it, which ran better, but didn’t feel like it made any more power.
It did make the motor behave in a way I’ve never experienced before or since.
After about 3500rpm or so, when you rolled the throttle open, you could feel it lose power....... instantly.
Like more throttle opening was messing with what was going on under the carb.
Once he commited to making some changes, he pulled it out and I dynoed it, just as it was in the car, ex manifolds and all.
It made an earth shattering 283hp. Yeh....... that’s pretty close to 400, right?
Headers picked it up about 30hp,
Changed to a small solid cam, rpm a/g, Demon 650dp........ made another 100hp and pulled strong to 6500.
For a mild street sb Mopar, I like the std performer......on 273’s thru 360’s.
Re: Sp2p vs performer intake for small block? [Re: fast68plymouth] #2648401
04/24/19 10:28 AM
04/24/19 10:28 AM
SattyNoCar Offline
SattyNoCar  Offline
fast68plymouth, based on your story, you and your friend don't have a clue what the SP2P was designed for.
Newsflash, not every after market intake was designed for drag racing, re: high RPM.
The SP2P was made during the gas crisis, when everyone was trying to squeeze out every last MPG from their engine.
It was designed for low to mid range, NOT high RPM, so, it falling on it's face over 5,000 RPM is expected.
John
Re: Sp2p vs performer intake for small block? [Re: SattyNoCar] #2648406
04/24/19 10:36 AM
04/24/19 10:36 AM
So. Burlington, Vt.
So. Burlington, Vt.
Yup......... I’m clueless.
My impression as to the reason behind the OP’s post is that he’s wondering if one of the two manifolds he has on hand offers a performance advantage over the other.
If he really didn’t care about the performance, he would simply put the sp2p back on without giving it another thought.
My story was an illustration as to how much of a detriment to “performance” the sp2p can be.
Re: Sp2p vs performer intake for small block? [Re: fast68plymouth] #2648408
04/24/19 10:39 AM
04/24/19 10:39 AM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Re: Sp2p vs performer intake for small block? [Re: SattyNoCar] #2648528
04/24/19 03:59 PM
04/24/19 03:59 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
The SP2P wasn't even a decent MPG manifold. I'm sure it's one of those designs that Edelbrock would like to forget about. "Turd" is just the tip of the iceberg. Back in the 80's my local speed shop was having a sale on those manifolds so I bought one for a small block Chevy pickup. 3 days after installing it I put the factory intake back on. Not only did the performance drop with the SP2P, but I lost 5 MPG as well. It's a waste of good aluminum.
Re: Sp2p vs performer intake for small block? [Re: magnum440d100] #2648539
04/24/19 04:24 PM
04/24/19 04:24 PM
woodcrest, CA
woodcrest, CA
Well, alright guys! You guys have me convinced. I’m going to yank the motor to degrease and replace the rear freeze plugs, then I will replace the manifold with the performer up
Re: Sp2p vs performer intake for small block? [Re: magnum440d100] #2648545
04/24/19 04:44 PM
04/24/19 04:44 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Good choice. up
I also made the mistake of running an Sp2p on a 318 but at least it was given to me. wink I honestly think the car ran better with the stock intake and carb. shocked
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Sp2p vs performer intake for small block? [Re: I_bleed_MOPAR] #2648603
04/24/19 08:30 PM
04/24/19 08:30 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I have bought them at swaps for as low as $20 before just to scrap so it won't be used again
Re: Sp2p vs performer intake for small block? [Re: 500ciDuster] #2648650
04/24/19 10:19 PM
04/24/19 10:19 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I had a 73 Camaro with a 350 2 barrel. A buddy had a SP2P and a Holley 600 for $35. I saw the chance to swap to a 4 barrel and jumped on it. I know the car was louder when the secondaries opened but I don';t recall if the car was any faster.
Many years later, I put a mild 360 in my 67 Dart. This was a REAL budget build. Lots of junkyard scrounging, etc. A guy in our Mopar club had a LA SP2P for $40. The engine was a reringed 360 with a mild cam. It felt as if it got slower the further I pressed the accelerator. I first blamed the cam, thinking maybe I had installed it a tooth advanced. I stumbled upon a Weiand 4 barrel intake with much bigger ports at a junkyard. The car felt transformed with that Weiand. I am convinced that the design of that intake sucks ass from the crack to the sack.
Re: Sp2p vs performer intake for small block? [Re: Kern Dog] #2648747
04/25/19 10:14 AM
04/25/19 10:14 AM
So. Burlington, Vt.
So. Burlington, Vt.
Quote
That’s exactly how that 396bbc felt with the sp2p on it.
After about 3000-3500 rpm, pushing on the gas pedal felt like pushing on the brakes.
As with most things........ if you do some digging around on the net you can find people relaying their sp2p experiences, you’ll find some good and some bad.
Most I saw were negative....... but there were a few who had favorable things to say.
One I saw that stood out(probably because it had a pro and a con) was....... the car picked up 2mpg........ but was gutless.
Re: Sp2p vs performer intake for small block? [Re: Kern Dog] #2648885
04/25/19 02:38 PM
04/25/19 02:38 PM
Buford, GA
Buford, GA
Originally Posted by Frankenduster
.... I am convinced that the design of that intake sucks ass from the crack to the sack.
laugh2 laugh2 laugh2 laugh2
Tim
'71 Charger 383/727
Re: Sp2p vs performer intake for small block? [Re: fast68plymouth] #2648886
04/25/19 02:41 PM
04/25/19 02:41 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The TQ peak of the SP2P is at such a low RPM no TQ converter will stall that low, maybe if you had a crawler that you wanted to idle at 400RPM with a manual trans and never turned over 3500RPM it may be good for that, besides that I can think of no other use.
Re: Sp2p vs performer intake for small block? [Re: HotRodDave] #2648944
04/25/19 05:14 PM
04/25/19 05:14 PM
So. Burlington, Vt.
So. Burlington, Vt.
After driving my friends Camaro with one on it, I came away with the idea that it’s not even intended to be used at WOT.
It’s like the design requires there to be a high amount of vacuum in the plenum(as in throttle blades mostly closed) for it to function “properly”.
In his car, the overall driving experience was poor. There was nothing about how the motor ran that stood out at all....... other than how weak it felt when you stepped on the gas.
One would have expected fantastic throttle response with those tiny runners....... but it was not the case with that 396.
It definitely made the top 10 list of worst overall combos I’ve driven.
I would say a more realistic powerband for one of those is idle to around 2500, with light throttle openings.
Also, obviously since the runners are so tiny, the bigger the motor you put under it, the lower to usable operating range will be.
Probably not totally awful on a 273........to very unsatisfying on a 360.
