G2 Hemi AL heads MP/Edelbrock VS Edelbrock Victor
#2648830
04/25/19 12:31 PM
04/25/19 12:31 PM
Posts: 17,907 S.E. Michigan
ZIPPY
S.E. Michigan
I collected several sets of older heads, but they all need some work....and with this 572 project I have been thinking I'd probably be happier with it if I started fresh.
It seems to me, to do what the Victor heads can do, I would need to take a Mopar Performance head and put over a grand worth of porting into it. It doesn't seem very cost-effective for a big CI deal.
Does the Victor slightly tipped ex valve angle and ginormous intake valve cause any issues? Edelbrock says everything works/I haven't heard anything.
I've seen what little prep is needed to make an 800hp pump gas street engine with the Victor heads, and while I don't expect my motor will be quite that radical, I'm pretty impressed with that easy potential and capability.
The MP head seems best used as a lightweight stock replacement?
What am I missing...agree/disagree...Thoughts please?
Thx
Rich H.
Esse Quam Videri
Re: G2 Hemi AL heads MP/Edelbrock VS Edelbrock Victor
[Re: ZIPPY]
#2648836
04/25/19 12:42 PM
04/25/19 12:42 PM
fast68plymouth
So. Burlington, Vt.
for a big bore stroker, the Victors make a lot of sense.
That’s what I’d use if I were in your shoes.
[Re: DoubleD]
#2648997
04/25/19 08:02 PM
04/25/19 08:02 PM
Posts: 2,678 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
The heads and intakes available today make it a good time to be buying hemi parts. Consider yourself blessed.
And yes, the Edelbrocks are the way to go.
2011 Drag Pak Challenger
[Re: Dragula]
#2649184
04/26/19 09:24 AM
04/26/19 09:24 AM
ZIPPY
S.E. Michigan
Piston selection is done, and the rotator is balanced...I wanted to keep moving forward rather than starting over....
Okay, so I might have to buy one Victor head to mock up and see how everything looks, then.
I've sure enjoyed running the Edelbrock heads on my little Wedge.
Thanks for replies, I think I know what I am going to try next.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2649194
04/26/19 09:44 AM
04/26/19 09:44 AM
fast68plymouth
So. Burlington, Vt.
I know of a 540 that got put together with the Victor heads that used normal hemi pistons.
[Re: fast68plymouth]
#2649227
04/26/19 10:57 AM
04/26/19 10:57 AM
ZIPPY
S.E. Michigan
Cool, thanks for that comment. I'm optimistic. Maybe with my (relatively/comparatively) low lift I can get away with it, but only one way to know. Of course, this does kind of force me into going with a big box mail order place for the hassle-free return policy, as I wouldn't want to stick a small time business with a potential return like that/probably banged up packaging from shipping and so on. Have a really nice/competitive quote on the MP/Edelbrock version from a friend at a Dealer, just in case. So even if I have to go plan B, it won't be too awfully bad. It seems the pile of heads I collected just became plan C, and if the new stuff works then will be sold off. Consider yourself blessed. In many ways, yes sir I do. I might not be religious, but I can definitely chalk alot of things up to luck.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2649230
04/26/19 11:11 AM
04/26/19 11:11 AM
fast68plymouth
So. Burlington, Vt.
Lift has nothing to do with it.
It’s the lift when the piston is near tdc during overlap that causes any issues with v/p clearance....... and that’s derived from duration, rate, and lsa.
When the valve is at full lift(100-120 atdc), on your 4.5 stroke motor, the piston is like 3” away from the valve.
#2649240
04/26/19 11:33 AM
04/26/19 11:33 AM
ZIPPY
S.E. Michigan
When the valve is at full lift(100-120 atdc), on your 4.5 stroke motor, the piston is like 3” away from the valve. Okay, I will admit I am wrong by oversimplifying that thought. Substitute this, then: maybe it'll help that I'll have 272 @ .050 instead of 290. Better? Whatever it takes to keep the idea alive Either way I gotta buy it, try it and see what happens...... When the rockers show up I will order one and find out.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2649250
04/26/19 11:58 AM
04/26/19 11:58 AM
Posts: 2,299 NE Ohio
DoubleD
NE Ohio
When the valve is at full lift(100-120 atdc), on your 4.5 stroke motor, the piston is like 3” away from the valve. Okay, I will admit I am wrong by oversimplifying that thought. Substitute this, then: maybe it'll help that I'll have 272 @ .050 instead of 290. Better? Whatever it takes to keep the idea alive Either way I gotta buy it, try it and see what happens...... When the rockers show up I will order one and find out. 290 @.050 - you must be kidding right? - think 272 or maybe even slightly smaller
[Re: ZIPPY]
#2649252
04/26/19 12:01 PM
04/26/19 12:01 PM
Posts: 965 Odessa, Fl
blowndart
Odessa, Fl
I don't know what compression you'e running or cam specs, but I recently installed a set on my 477 CID hemi and had plenty of piston to valve clearance with a mild solid roller and 10.5:1 compression pistons that were made for standard valve angle heads . I have no complaints with the heads. Highly recommend.
[Re: DoubleD]
#2649285
04/26/19 01:09 PM
04/26/19 01:09 PM
ZIPPY
S.E. Michigan
Intended as bait. Worked pretty well. Thanks for saying something
Rich H.
Esse Quam Videri
[Re: blowndart]
#2649289
04/26/19 01:16 PM
04/26/19 01:16 PM
ZIPPY
S.E. Michigan
Thanks for the comments.
Should be roughly 10.2:1, but that was calculated by CCing one of the old heads + before I physically had gaskets on hand. I'll be able to get more accurate numbers as soon as the exact head is decided.
Cam specs subject to change but I'm going to start out with a solid roller 272/280 @ .050, .420 lobe lift on 112 and will see how I like it.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2649291
04/26/19 01:19 PM
04/26/19 01:19 PM
DoubleD
NE Ohio
Intended as bait. Worked pretty well. Thanks for saying something I thought so - cause at 870 HP you would be probabaly be shocked at what size cam BEST put in mine - but its a "top secret Chuck cam" and I will not give the specs - but I can tell you its mild and has really good idle & low end manors then screams up top. Something I would have never guessed would work so well in a big engine like it does.
[Re: DoubleD]
#2649307
04/26/19 02:15 PM
04/26/19 02:15 PM
ZIPPY
S.E. Michigan
Cam specs? Oh no, he would never discuss that. Not in a million years. Nope, never happen. No need to post specs. Proprietary info will be maintained and yes, no doubt Chuck has got some killer street roller grinds on deck. I have a couple ideas which nobody else seems to like (nobody totally hates the ideas, but nobody is 100% on board either and considers my ideas amazing LOL), so it may be a total dog. Well if so, I'll let it howl for awhile and will play with it later. At the end of the day, it's just a toy.
[Re: AndyF]
#2649337
04/26/19 03:52 PM
04/26/19 03:52 PM
ZIPPY
S.E. Michigan
Well 572 is a big engine but I just put a 239/245 hyd roller in my 496 wedge and it was great on the dyno. Haven't run it in the car yet but I'm thinking I'm going to like it based on how big the torque curve was on the dyno. A 272/280 cam is way out of my league!
I don't have anything useful to say on the heads other than I'm surprised you are already thinking of switching when you haven't even tried the parts you have on hand. Did you start thinking you needed a bunch more power than what the head you have will provide? Since you already have pistons I'd think you would stick with what you have but hey, if you want to step up I suppose now is the time to do it. Well as always I appreciate your comments. It's been what, 25 plus years we've been bantering back and forth? I keep going back to the old lesson not to skimp on heads. I've been looking at a little 258 @ .050 solid flat tappet also. It's available for a song and I might just get it and throw it on the shelf just in case. My car can only legally go 10 flat anyway and I'm not sure I am quite ready to add more monkey bars inside it and try to surpass that just yet. I have to drive it into the 10s first. All the heads I have on hand will require some amount of welding...some more extensive than others, to the point that some of the combustion chambers will need to be re-shaped. It seems once I pay for that, I'm more than halfway to the cost of better stuff? I am thinking I might save the nicest pair of heads I have (those only need O ring grooves welded, the rest is basic repair stuff) for a near stock cruiser 426ci I am planning in the future and off the rest....... Or I might just get rid of the whole head collection, get one pair of Victors and give the second engine more thought. Will have to start with one Victor and see if it looks like it will work.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2649408
04/26/19 08:04 PM
04/26/19 08:04 PM
Posts: 246 Cranberry Twp PA (North of Pit...
rumblefish72
Hey - that's the cam I'm running in my pump gas Hemi ... 273 on the intake and 286 on the exhaust at .050. Bullet Solid Roller. .
Screenshot from the dyno run
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
