Re: Removing power valve
[Re: fast68plymouth]
#2648766
04/25/19 10:42 AM
04/25/19 10:42 AM
Posts: 4,457 Washington
madscientist
Washington
I wouldn’t be trying to get it to idle at a low-ish rpm either........ 12-1300 in neutral, hot...... is where I’d be.
And, unless the car was moving........ it wouldn’t be in gear. I agree with this 100%.
[Re: madscientist]
#2648770
04/25/19 10:49 AM
04/25/19 10:49 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Not knowing what cam is in it I would say that should idle at 900 rpm without any issue.. see if its dripping fuel first thing EDIT is this car hard to start up.. you said the intake looks wet
[Re: varunner]
#2648788
04/25/19 11:25 AM
04/25/19 11:25 AM
Posts: 605 TN
1DGEMAN
TN
[quote=varunner]I agree, easy to do.
no site plugs
in this day and age in stock, holes in butterflys I'm not worried about.
will definately lift the carb and if it drips. fuel pump pressure is 6 lbs.
What size needle and seats? 6lbs could be too much fuel pressure. On my 6 pack 340 for stock eliminator I am experimenting with .130 needle and seats with 3/8 line and 4 psi it cleaned up the idle on the run stand. What rpm do you have it idling at? There is a lot of duration in our camshafts not meant to idle. Good Luck, Rod
Real Men shift for themselves
#2648797
04/25/19 11:41 AM
04/25/19 11:41 AM
Posts: 17,841 S.E. Michigan
ZIPPY
S.E. Michigan
An easy test is lift the carb off the manifold an inch or so, and block it up with something. Turn on the fuel pump and see if any fuel starts dripping from anywhere underneath. I’ve seen fuel dripping out from places where it theoretically “couldn’t”.
This procedure really works great, done it many times myself...found things I both did, and did not want to find. ...rotten luck with warped parts.
Rich H.
Esse Quam Videri
[Re: varunner]
#2648805
04/25/19 11:51 AM
04/25/19 11:51 AM
Posts: 31,002 Oregon
AndyF
Had you started out your thread by saying it was a stock eliminator engine it would've made more sense. Stock eliminator carbs tend to be a special breed. I've seen a few of them but I wouldn't know how to build one.
You might not have a problem, or at least not one that can be easily fixed. If the engine has a lot of reversion at idle then you'll have sooty plugs and a wet intake but the engine will run fine down the track. That is just the way it is. I've seen guys fix that by playing around with the valve job but that is another thing that I've only seen but not understood. Sometimes a very minor change to the valve job will clean up the idle without changing the power at WOT. A stock eliminator head guy might know how to do that.
[Re: AndyF]
#2648848
04/25/19 12:53 PM
04/25/19 12:53 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’ll add that my buddies Pontiac Stocker idles just fine with the Qjet....... but it was a learning process on what it took to make it that way. Lots of modifications to the low speed circuits.
He has a variety of carbs....... and on one of them we had to remove the primary metering rods to get any kind of throttle response from it(this seems to be pretty common with Stocker Qjets).
He now knows what series of things need to get plugged, what things need to get drilled, etc.......to get it to run right. It took some time to get it figured out.
I’d think/expect it to be easier with a Holley.
Thinking about it more...... Even Holleys with “2 corner idle” have a secondary idle circuit, it’s just fixed instead of adjustable. If the secondary idle circuit had been richened up too much...... that could be part of the problem.
You’re sure the ignition isn’t compromised, and you’re running hot enough plugs?
#2648966
04/25/19 06:25 PM
04/25/19 06:25 PM
Posts: 660 Virginia
varunner
Virginia
yeah it could be just a lot of mods that will be needed. ignition seems fine, locked out at 38. plugs are what you had recommended. I hadn't thought about hotter plugs..... I’ll add that my buddies Pontiac Stocker idles just fine with the Qjet....... but it was a learning process on what it took t make it that way. Lots of modifications to the low speed circuits.
[Re: varunner]
#2648971
04/25/19 06:35 PM
04/25/19 06:35 PM
Posts: 660 Virginia
varunner
Virginia
plug and carb
[Re: varunner]
#2648989
04/25/19 07:32 PM
04/25/19 07:32 PM
madscientist
Washington
For whatever reason that thing is pig rich. Everywhere. I suspect when you get the idle circuit cleaned up and work on main jet, you'll find you'll need a power valve that opens way sooner than 2.5 or even 4.5. That's too late for most engines.
[Re: madscientist]
#2649002
04/25/19 08:18 PM
04/25/19 08:18 PM
fast68plymouth
So. Burlington, Vt.
Those are 4150 carbs(rear metering block instead of metering plate) from the factory? I didn’t realize that.
The ifr situation on the primary block doesnt appear to be the same as the typical “performance” Holley carb. Does it utilize an emulsion tube in the main well?
I’m not sure if an aftermarket billet metering block would fly or not....... but I think I’d try and find out.
That plug looks as though there’s fuel “running” out of the carb....... did you try seeing if anything was dripping with the pump running?
You didn’t fog the motor after the last outing did you?
The plugs are 6’s?
[Re: BradH]
#2649069
04/25/19 09:59 PM
04/25/19 09:59 PM
fast68plymouth
So. Burlington, Vt.
I just saw you had answered a few questions......
So, if fuel isn’t leaking through the carb statically, it would point a finger at what appears to be a gross calibration issue.
With the motor warmed up and idling at 1200....... can you kill it by turning the mixture screws in?
When the idle starts to slow down from presumably being rich..... does turning those screws in help?
When you say the distributor is locked....... that means “locked”....... not there is super weak springs in it, right?
With .120 n/s, you can probably drop the pressure to 5-ish.
When it’s warmed up and idling at 1200, if you look down the Venturi there should be no fuel dribbling from the boosters.
Glad to hear you’re making headway with it.
#2649073
04/25/19 10:19 PM
04/25/19 10:19 PM
fast68plymouth
So. Burlington, Vt.
This is supposedly a pic of a 71 383HP carb.
A little out of the ordinary(if the pic is of the correct carb). 4160 series(no rear metering block), with down leg boosters.
Brian....... does yours have the same style boosters? Front and rear?
[Re: MR_P_BODY]
#2649131
04/26/19 07:29 AM
04/26/19 07:29 AM
Posts: 660 Virginia
varunner
Virginia
easy to start Not knowing what cam is in it I would say that should idle at 900 rpm without any issue.. see if its dripping fuel first thing EDIT is this car hard to start up.. you said the intake looks wet
