Re: Undiluted for Indy Slots [Re: DAYCLONA] #2647669
04/21/19 09:57 PM
04/21/19 09:57 PM
Kirkland, Washington
Pacnorthcuda Offline
Originally Posted by DAYCLONA
Originally Posted by Pacnorthcuda
I agree that the backside would tell. To me, on my ipad, they look like a unilug oval. I’m not a fan, but if that’s the case then the damage on the other side doesn’t add to the issue once mag lugs and washers are used.
If however they are NOT unilug, then they are damaged beyond use.
Being hub centric, the center hub positions the wheel, not the lugs, so the wheel is not "damaged beyond use" if the correct lugs and washers are used, even if the lug holes were "ovaled" out from improper prior hardware ....
True, I did not consider that.
Re: Undiluted for Indy Slots [Re: DAYCLONA] #2647673
04/21/19 10:14 PM
04/21/19 10:14 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
That's true if the hub is correct and not manufactured larger to be for generic use. Mopar and ford did use the same bolt pattern but the hubs are different sizes.
Re: Undiluted for Indy Slots [Re: stumpy] #2647762
04/22/19 09:38 AM
04/22/19 09:38 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Correct. IMO their are some things on a vehicle that should not be compromised, Wheel fitment is one of them beer
Re: Undiluted for Indy Slots [Re: TJP] #2647787
04/22/19 10:16 AM
04/22/19 10:16 AM
moparx Online content
moparx  Online Content
every aftermarket wheel i have ever seen with a unilug pattern were NOT hubcentric unless you used those rings to make them so. and those rings were not [readily] available until several years ago. as has already been mentioned, the ford, mopar, and GM hubs are all different in diameter, and the "common" hub bore on aftermarket wheels is roughly 3.??? ID. so they fit every possible application.
a real common way to make those wheels look like the ones the OP has, is "losing" the washers, and using the correct lugnuts, or using factory style lugnuts. i saw this ALL the time in my junkyard ownership years [1972-1984 when those wheels were new] there are several ways to simply fix those wheels, but it will require a machine shop [or a good friend that has a bridgeport and knows how to use it].
beer
Re: Unilug Indy Slots [Re: dart4forte] #2647800
04/22/19 10:54 AM
04/22/19 10:54 AM
central il.
second 70 Offline
second 70  Offline
central il.
I worked at Goodyear in the 70’s and some rims only used an offset washer on the front while others had inserts that also went in the back of rims. Here is a set of “don’t kill me” Chevy lugs from a set of Ansen Sprint rims. The inserts are about 5/8 thick and push in the rear of rim. The Chevy were in the center and you would need the other insert which would move them in or out.
Threw the Mcguard wheel locks in for nostalgia.
Mike
Wow just realized these lugs are 45 years old and the chrome is perfect!
Re: Unilug Indy Slots [Re: second 70] #2647808
04/22/19 11:26 AM
04/22/19 11:26 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mike
I believe these style lugs were Appliance brand wheels.
Doug
Re: Undiluted for Indy Slots [Re: dart4forte] #2647809
04/22/19 11:28 AM
04/22/19 11:28 AM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
Originally Posted by dart4forte
Yes, they are hub centric. Here’s another view
I have two other wheels just like this pair.
Backside
Abe Lincoln
Re: Unilug Indy Slots [Re: dvw] #2647946
04/22/19 07:11 PM
04/22/19 07:11 PM
central il.
second 70 Offline
second 70  Offline
central il.
Doug [/quote]
Doug they were called Ansen sprint 2. I bought the rims new back in high school. The original sprints weren't unilug. But come to think of it maybe Ford were center and Chevy were offset?
Re: Unilug Indy Slots [Re: second 70] #2647996
04/22/19 09:26 PM
04/22/19 09:26 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug
Doug they were called Ansen sprint 2. I bought the rims new back in high school. The original sprints weren't unilug. But come to think of it maybe Ford were center and Chevy were offset? [/quote
Sprint II were unilug only. I just remember round washers that fitted into a front recess.
Doug
Re: Unilug Indy Slots [Re: dvw] #2648043
04/22/19 11:45 PM
04/22/19 11:45 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
unless there is more side to side damage than it appears …..
with the proper mag wheel shank lug nuts properly torqued those wheels won't go anywhere
Re: Unilug Indy Slots [Re: 6bblgt] #2648082
04/23/19 08:35 AM
04/23/19 08:35 AM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
I recently put two sets of slotted mags on two of my cars. The set that I put on my van were made by US mags and they looked like the wheel posted by the OP. They used the standard shank type lugs with standard centered washers. I bought a set of them from Auto Zone, that were made by Dorman, and they are total made in China crap.They were stripping the threads out while I was installing them by hand with a socket and a ratchet. If you need to get a set,buy them from Summit Racing or Jegs,and buy American Racing, Cragar, or Mcguard lugs. How they can sell substandard lug nuts to hold the wheels on your vehicle, with poor metallurgy is beyond me! Anyway, the second set of slotted wheels consisted of a pair from American Racing which also used the standard shank type lugs and standard centered washers,and a pair of Anson slotted wheels that used the oval shaped washers that fit into a machined out recessed area around the lug holes. Those wheels used the oval washers with the offset lug holes that fit into the recessed area of the rim,with standard shank type lug nuts.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: Unilug Indy Slots [Re: chargervert] #2648086
04/23/19 08:52 AM
04/23/19 08:52 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Here's an original Ansen sprint I. They're going back on my 67 Jeep Gladiator. Real oddball, 16.5"×8.25". Its amazing what a little Scotchbrite and mineral spirits will do.
Doug
Re: Unilug Indy Slots [Re: dvw] #2648124
04/23/19 10:49 AM
04/23/19 10:49 AM
central il.
second 70 Offline
second 70  Offline
central il.
Doug those cleaned up great. Here's a picture of the back of the Ansen 2. You can see two of the inserts are installed. Who ever put them in have have at least one backwards. Lol
.jpg
Re: Unilug Indy Slots [Re: second 70] #2648131
04/23/19 11:07 AM
04/23/19 11:07 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Man this taxing my old guy memory. Worked there in 1974
Doug
Re: Unilug Indy Slots [Re: 6bblgt] #2648146
04/23/19 11:35 AM
04/23/19 11:35 AM
your picture brought back my old mind from hibernation ! back around the eary, or mid 80's, my brother bought a set of chromed steel slots. it had a ford/chevy pattern where the lugs fit as your picture suggests. once they were tightened, they weren't going anywhere. [provided the holes were not buggered up].
there may have been aluminum wheels like that, but i have never seen any to investigate the hole to lugnut fit.
beer
Re: Unilug Indy Slots [Re: dvw] #2648195
04/23/19 02:36 PM
04/23/19 02:36 PM
central il.
second 70 Offline
second 70  Offline
central il.
Doug
Tell me about it Lol I believe these rims came with 2 different bushings. A center hole for 4.75 Chevy and a .25 offset that you could use to make them 4.5 Mopar, Ford, or 5" Chevy truck.
Also there was another rim I think ET that had a one piece plastic insert with all the bushings attached like fingers that went in the back. It looked just like 6bblgt's picture. So with those rims there where 3 different inserts since they were one piece.
