Re: E Body K frame ID needed
[Re: A727Tflite]
#2647971
04/22/19 09:38 PM
04/22/19 09:38 PM
Posts: 1,908 Nebraska
4406bbl
Nebraska
How do you differentiate between an E and B body ? On a 1970, a b-body will have the steering box angled more toward the drivers frame rail, I assume to align the steering wheel with the dash that is angled in a 1970 b-body, straight dash in a e-body. It gets hard if there is not a coin welded to the front with the last 2 part # digits. If you put a bolt in steer box mount and compare side to side it is plain as day. In 1971, without a coin, hard to tell.
[Re: A727Tflite]
#2648160
04/23/19 01:04 PM
04/23/19 01:04 PM
Posts: 25,988 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I've also heard that it was the vertical angle difference, not sideways.
[Re: John_Kunkel]
#2648319
04/23/19 11:38 PM
04/23/19 11:38 PM
4406bbl
Nebraska
There are pics in a previous post of an e-body k in a 1970 b, steering box is about 3/8 further to right of framerail, and steering coupler has an angle on it when you do that. It will work but is not right. I noticed it when looking at a 1970 b,with windshield and engine out and the hood off, plain as day you notice the steering wheel over to the left, so it lines up with the angle of the dash. The height looks the same, and would cause oil pan and bump steer issues if it was raised. Btw left and right is as you are sitting in car.
[Re: 4406bbl]
#2718539
11/23/19 04:09 AM
11/23/19 04:09 AM
Posts: 406 California City, CA
dart440
California City, CA
71 B Body is the same and 440 and 440-6 cars would have had them.
When you work on Spaceships for a living, how bad can a workday be?
[Re: 4406bbl]
#2719397
11/26/19 09:49 AM
11/26/19 09:49 AM
Posts: 1,179 Canada
demon
Canada
All 62-72 B and E body V8 K frames fit big or small blocks. Having a skid plate makes it a 440 K frame. The E body and 71-72 B body do have a different angle to the steering box. This can be seen at a glance if you have a 70 B body K frame and a E body k frame side by side. The E body type has a different looking reinforcement plate. Yes, the steering box angle changed both vertically and side to side. That is why E bodies and 71-72 B bodies use that “bent”looking Center link. I installed a complete 72 B body K frame in a 66 B body once with no issues. Perhaps not the ideal angles for the coupler, but installed and operated fine.
Your K frame will be from a 70-71 440 E body, or a 71-72 440 B body.
