Re: 78 amp alternator upgrade issue
[Re: Supercuda]
#2647865
04/22/19 03:38 PM
04/22/19 03:38 PM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
Update: I ran the ammeter bypass wire from the alternator to the starter relay, and wired in a relay for the sensor wire on the voltage regulator. This morning on the way to work, headlights on it was putting out 14.0 to 14.8 volts. It seems to be fixed, thank you for all the help!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
[Re: Supercuda]
#2648782
04/25/19 11:10 AM
04/25/19 11:10 AM
Posts: 6,100 Valencia, España
NachoRT74
Valencia, España
Remember, the ONLY ammeter load on the battery side of the ammeter is supposed to be the battery. Nothing else. I fyou have anythign else there it will show up as a discharge on the ammeter. not really sure what you meant. but just in case... anything being conected to batt post will show a CHARGE reading on ammeter when engine is running. When engine is off ammeter will stay centered because load won't be running through the ammeter. One fine example is the starter motor, which is sourced straight from batt and ammeter doesn't show that. It can be showing some discharge what ignition sucks or the starter relay trigger load because ign switch is between amm and alt hence into the ammeter reading from batt but not the starter motor load itself
[Re: NachoRT74]
#2648920
04/25/19 04:04 PM
04/25/19 04:04 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Remember, the ONLY ammeter load on the battery side of the ammeter is supposed to be the battery. Nothing else. I fyou have anythign else there it will show up as a discharge on the ammeter. not really sure what you meant. but just in case... anything being conected to batt post will show a CHARGE reading on ammeter when engine is running. When engine is off ammeter will stay centered because load won't be running through the ammeter. One fine example is the starter motor, which is sourced straight from batt and ammeter doesn't show that. It can be showing some discharge what ignition sucks or the starter relay trigger load because ign switch is between amm and alt hence into the ammeter reading from batt but not the starter motor load itself You are correct, I mis-typed discharge when I meant charge. Probably too much Bushmills
[Re: Supercuda]
#2649467
04/27/19 03:33 AM
04/27/19 03:33 AM
NachoRT74
Valencia, España
LOL
And also will show Charge althought is not actually strictly charging the batt just if alt is being enough to the rest of car demand, i.e. nothing being sucked on alt side of the amm from batt. If not, will be simply a discharge process being not really registered by the amm.
