Re: 78 amp alternator upgrade issue [Re: Supercuda] #2647865
04/22/19 03:38 PM
04/22/19 03:38 PM
Laveen, Arizona
GTSDart340 Offline OP
Laveen, Arizona
Update: I ran the ammeter bypass wire from the alternator to the starter relay, and wired in a relay for the sensor wire on the voltage regulator. This morning on the way to work, headlights on it was putting out 14.0 to 14.8 volts. It seems to be fixed, thank you for all the help!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: 78 amp alternator upgrade issue [Re: Supercuda] #2648782
04/25/19 11:10 AM
04/25/19 11:10 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Originally Posted by Supercuda
Remember, the ONLY ammeter load on the battery side of the ammeter is supposed to be the battery. Nothing else. I fyou have anythign else there it will show up as a discharge on the ammeter.
not really sure what you meant. but just in case... anything being conected to batt post will show a CHARGE reading on ammeter when engine is running. When engine is off ammeter will stay centered because load won't be running through the ammeter. One fine example is the starter motor, which is sourced straight from batt and ammeter doesn't show that. It can be showing some discharge what ignition sucks or the starter relay trigger load because ign switch is between amm and alt hence into the ammeter reading from batt but not the starter motor load itself
Re: 78 amp alternator upgrade issue [Re: NachoRT74] #2648795
04/25/19 11:41 AM
04/25/19 11:41 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
We're all saying the same thing.
Electricians here call equipment that uses electricity "load."
So the load side of a device like a fuse box, or in this case the ammeter, is side with equipment that draws power.
The feed side of the same device is the side where the power is coming from.
The confusion with many cars is as you know, the battery can be both.
It is the power source when the alternator can not supply the power.
It is a load when it is recharging from the alternator.
Re: 78 amp alternator upgrade issue [Re: NachoRT74] #2648920
04/25/19 04:04 PM
04/25/19 04:04 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You are correct, I mis-typed discharge when I meant charge.
Probably too much Bushmills
Don't be the exception.
Re: 78 amp alternator upgrade issue [Re: Supercuda] #2649467
04/27/19 03:33 AM
04/27/19 03:33 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
LOL
And also will show Charge althought is not actually strictly charging the batt just if alt is being enough to the rest of car demand, i.e. nothing being sucked on alt side of the amm from batt. If not, will be simply a discharge process being not really registered by the amm.
