Re: Bent pushrod problem? [Re: plumcrazycuda] #2645055
04/14/19 02:49 PM
04/14/19 02:49 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Originally Posted by plumcrazycuda
For some reasons the lock nut came loose on the rocker. This is why the pushrod came out. Don’t know why after so long that the nut broke loose? I only ran it up to like 4K rpm and it pull hard to 6500+but to be honest I have not run it at the track for years. I had two pushrod and put them in today and it fired right up!
I am going to pull the intake and would like to replace that lifter if I can get just one form Crane cam. Don’t want to buy 8 of them to get one. I would sleep better if I can replace it! I am going to double nut the adjuster bolt. Don’t want to have it happen again and don’t want to lose my motor over it! I know one thing for sure if the lifter breaks it over quick!
I had the same issue with the jam nuts loosening several years back with a hydraulic roller cam set-up in my 493 RB. It dropped a pushrod too. In my case, the springs were loosing control of the valve train at about 5700 rpm or there abouts. There was some seriously bad harmonics going on in the valvetrain. They were so bad that it blew all the roller bearings out of my exhaust rockers.
I sought help getting to core problem from Dwayne Porter, He guided me through the analysis process, identified the root issue and then went through my heads and spec'd a mechanical roller cam. The motor has never run smoother or performed better.
I even ended up using B3 Racing to optimize my rocker geometry. Mike, the owner, is a great guy to work with.
I also found that be tightening and loosening the adjuster nuts several times to really seat the lock nut on the rocker arm helped keep them tight.
Re: Bent pushrod problem? [Re: jbc426] #2645110
04/14/19 07:12 PM
04/14/19 07:12 PM
PA
P
plumcrazycuda Offline OP
P
PA
What did they do to fix it?
Re: Bent pushrod problem? [Re: plumcrazycuda] #2645344
04/15/19 11:42 AM
04/15/19 11:42 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Basically, I swapped over to a mechanical roller so I could run enough spring pressure to control the valve train at higher rpm. With a hydraulic roller, there is a balancing act between running enough spring pressure to control the valve train with hydraulic lifters, but not so much that the lifters collapse.
On big block Mopar's the hydraulic lifter choices are pretty limited. If you plan to stay bellow 5500 rpm or there abouts, the stuff that's out there is fine. Some guys can bump the rpm up higher, but for most folks that's about the upper limit..
I needed something that is happy in the 6K+ range, so mechanical roller was my best path.
I also put in a set of Manton Stage 5, 7/16ths pushrods and custom T&D rockers with B3 Racing's geometry correction kit. The engine has never run as smooth as it does now. I think a lot of the difference is due to how stable and efficient the valve train is now.
Here's a before and after pics the B3 geometry correction kit.
Re: Bent pushrod problem? [Re: jbc426] #2645388
04/15/19 01:19 PM
04/15/19 01:19 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I have T&D rockers with B3 correction
Re: Bent pushrod problem? [Re: CSK] #2645433
04/15/19 04:25 PM
04/15/19 04:25 PM
PA
P
P
PA
I just got of the phone with Crane cam. I have a new lifter on its way! He thinks maybe the lack of maintenance is why it came loose. It runs to good to change a bunch of stuff, so I am going to replace that lifter and adjust all the valve and see if thinks stay together. Remember it has not had a valve cover off since 2001 or 02 and always fired right up and will run low 12 seconds and I shifts at 6500 rpm when I raced it. Thanks for all the help!
