9 1/4 gear change. #2643765
04/10/19 06:56 PM
04/10/19 06:56 PM
junction city oregon
V
viperblue72 Offline OP
V
I plan to replace some 3.21 gears in my 9 1/4 to 4.88. I can’t find anywhere that it requires a different carrier or thick gears. It is currently a sure grip. I decided to just order the gears but am now second guessing if they’ll work.
So my question is there only one carrier fits all for the 9 1/4?
Re: 9 1/4 gear change. [Re: viperblue72] #2644612
04/13/19 07:01 AM
04/13/19 07:01 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
There is a lot of room for movement with the side adjusters and the ring gear will be thicker, so...
Re: 9 1/4 gear change. [Re: viperblue72] #2644673
04/13/19 10:44 AM
04/13/19 10:44 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Side adjusters should do it. I've never seen a 4 series carrier for a 9 1/4.
Sheldon
