Re: G's Mopar build thread (hemi, gerst, '69 Charger)
[Re: gsmopar]
#2634114
03/18/19 04:37 PM
03/18/19 04:37 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
Gotcha...for some reason I thought you were going to run breathers on the covers. A better option than the grommets is to weld some -10 male fittings onto the covers.
[Re: an8sec70cuda]
#2634900
03/20/19 04:40 PM
03/20/19 04:40 PM
Posts: 36 Aubigny, MB Canada
69 F5 R/T
Aubigny, MB Canada
Lovin the detailed pics showing clearances! That always seems to be the hardest to find......
Bringin Back the Iron!
[Re: Cape]
#2642599
04/08/19 08:32 AM
04/08/19 08:32 AM
Posts: 1,145 Arizona, USA
gsmopar
Arizona, USA
What hood are you planning on using? And who makes that air cleaner? Thanks I don't know on the hood. Air Cleaner is from PG Classics. I modified a stock one for the 4500. It's a metal base, not fiberglass like others I've seen. https://pgclassic.com/air-cleaners-air-grabber/
[Re: gsmopar]
#2642621
04/08/19 09:04 AM
04/08/19 09:04 AM
Posts: 10,049 MN
JERICOGTX
MN
I'd get a Glasstek hood, with a Sunoco style "scoop/cowl" on it. Here is Larry Boyd's GTX with a Glasstek front and Sunoco hood.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2642648
04/08/19 10:16 AM
04/08/19 10:16 AM
gsmopar
Arizona, USA
That looks AWESOME!
*edit*
Do you have any more pics of that car?
[Re: gsmopar]
#2642729
04/08/19 12:58 PM
04/08/19 12:58 PM
Posts: 10,049 MN
JERICOGTX
MN
Larry's car has just been redone, so not many new pictures are out yet.
69 GTX
68 Road Runner
[Re: ZIPPY]
#2642802
04/08/19 03:26 PM
04/08/19 03:26 PM
gsmopar
Arizona, USA
That GTX is off the hook.
That K&N E-3840 element is on national backorder right now. I tried 4 times to buy one, not happening lol. Summit had it to my door in a couple days??? **edit** I just checked and they still show it available to ship today.
[Re: gsmopar]
#2643096
04/09/19 07:50 AM
04/09/19 07:50 AM
Posts: 17,914 S.E. Michigan
ZIPPY
S.E. Michigan
That K&N E-3840 element is on national backorder right now. I tried 4 times to buy one, not happening lol. Summit had it to my door in a couple days??? **edit** I just checked and they still show it available to ship today. Won't need it for awhile but THANK YOU, I am picking that up. Tried everywhere except there.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2647482
04/21/19 08:32 AM
04/21/19 08:32 AM
gsmopar
Arizona, USA
I managed to get one side of the exhaust buzzed up. Waiting on a couple bends for the other side. I went under the axle as I mentioned in a separate thread. This is the first time the car has had exhaust past the rear axle in ~20 years... May have to install a stereo if it works out! ![smoke smoke](/ubbthreads/images/graemlins/custom/smoke.gif) Tacked together: Untitled by Greg Ault, on Flickr All buzzed up! Untitled by Greg Ault, on Flickr
[Re: gsmopar]
#2647556
04/21/19 01:06 PM
04/21/19 01:06 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
What are you doing to allow the motor to breathe? I see one outlet with no inlet for breathing ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) I would and do use a PCV on all my non vacuum pump motors to help suck moisture out of them as well as allow the motor to breath when revved up above 3000 RPM ![work work](/ubbthreads/images/graemlins/custom/work.gif)
[Re: Cab_Burge]
#2647985
04/22/19 10:05 PM
04/22/19 10:05 PM
gsmopar
Arizona, USA
What are you doing to allow the motor to breathe? I see one outlet with no inlet for breathing ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) I would and do use a PCV on all my non vacuum pump motors to help suck moisture out of them as well as allow the motor to breath when revved up above 3000 RPM PVC valve connected to a Jegs Breather tank on one valve cover. Untitled by Greg Ault, on Flickr
[Re: gsmopar]
#2651783
05/04/19 05:06 AM
05/04/19 05:06 AM
Posts: 10,049 MN
JERICOGTX
MN
I remember seeing a Charger a while back with a Sunoco style hood. Well I just came across it on Facebook, and here it is.
69 GTX
68 Road Runner
